[mapserver-commits] r7899 - trunk/mapserver/mapscript/python/examples
Mon Sep 8 21:27:28 EDT 2008
Author: tomkralidis
Date: 2008-09-08 21:27:27 -0400 (Mon, 08 Sep 2008)
New Revision: 7899
Added:
   trunk/mapserver/mapscript/python/examples/project_csv.py
Initial implementation
Added: trunk/mapserver/mapscript/python/examples/project_csv.py
--- trunk/mapserver/mapscript/python/examples/project_csv.py	                        (rev 0)
+++ trunk/mapserver/mapscript/python/examples/project_csv.py	2008-09-09 01:27:27 UTC (rev 7899)
@@ -0,0 +1,50 @@
+#!/usr/bin/python
+# Script : project_csv.py
+# Purpose: Simple example to read a csv file and reproject point x/y data
+# $Id$
+import sys
+import csv
+import mapscript
+# example invocation
+# ./reproj.py ./foo.csv 2 3 EPSG:32619 EPSG:4326
+# check input parameters
+if (len(sys.argv) != 6):
+    print sys.argv[0] + \
+        " <csvfile> <x_col> <y_col> <epsg_code_in> <epsg_code_out>"
+    sys.exit(1)
+else:
+    # set x and y indices
+    x = int(sys.argv[2])
+    y = int(sys.argv[3])
+    # set input and output projections
+    projObjIn  = mapscript.projectionObj("init="+sys.argv[4].lower())
+    projObjOut = mapscript.projectionObj("init="+sys.argv[5].lower())
+    # open file
+    fCsv = open(sys.argv[1], 'r')
+    # read csv
+    csvIn  = csv.reader(fCsv)
+    # setup output
+    csvOut = csv.writer(sys.stdout)
+    for aRow in csvIn: # each record
+        # set pointObj
+        point = mapscript.pointObj(float(aRow[x]), float(aRow[y]))
+        # project
+        point.project(projObjIn, projObjOut)
+        # update with reprojected coordinates
+        aRow[x] = point.x
+        aRow[y] = point.y
+        csvOut.writerow(aRow)
+    fCsv.close()
Property changes on: trunk/mapserver/mapscript/python/examples/project_csv.py
___________________________________________________________________
