[mapserver-commits] r7910 - trunk/mapserver
Tue Sep 16 11:20:46 EDT 2008
Author: aboudreault
Date: 2008-09-16 11:20:45 -0400 (Tue, 16 Sep 2008)
New Revision: 7910
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapogr.cpp
Fixed bug: GetFeature query through tileindex layer doesn't return correct
information
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-09-11 21:22:52 UTC (rev 7909)
+++ trunk/mapserver/HISTORY.TXT	2008-09-16 15:20:45 UTC (rev 7910)
@@ -12,6 +12,9 @@
 Current Version (5.3-dev, SVN trunk):
+- Fixed GetFeature through tileindex bug: the tileindex of the shape found
+  wasn't set properly in the resultcache object. (#2359)
 - Removed comma to correct WCS 1.1 Coverages formatting in payload directory.
   (#2764)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2008-09-11 21:22:52 UTC (rev 7909)
+++ trunk/mapserver/mapogcfilter.c	2008-09-16 15:20:45 UTC (rev 7910)
@@ -603,7 +603,7 @@
         else
           nClassIndex = msShapeGetClass(psLayer, &shape, map->scaledenom, NULL, 0);
-        addResult(psLayer->resultcache, nClassIndex, anValues[i], -1);
+        addResult(psLayer->resultcache, nClassIndex, anValues[i], shape.tileindex);
 #ifdef USE_PROJ
       if(psLayer->project && msProjectionsDiffer(&(psLayer->projection),
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2008-09-11 21:22:52 UTC (rev 7909)
+++ trunk/mapserver/mapogr.cpp	2008-09-16 15:20:45 UTC (rev 7910)
@@ -1393,6 +1393,7 @@
   shape->index = OGR_F_GetFID( hFeature );
+  shape->tileindex = psInfo->nTileId;
   // Keep ref. to last feature read in case we need style info.
   if (psInfo->hLastFeature)
