[mapserver-commits] r8868 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Apr 1 23:44:09 EDT 2009
Author: sdlime
Date: 2009-04-01 23:44:09 -0400 (Wed, 01 Apr 2009)
New Revision: 8868
trunk/mapserver/mapserv.c
trunk/mapserver/mapserver.h
trunk/mapserver/maptemplate.c
Added magic string detection for templates. Added MS_MAP_PATTERN and MS_MAP_NO_PATH env support to CGI.
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2009-04-02 03:42:47 UTC (rev 8867)
+++ trunk/mapserver/mapserv.c 2009-04-02 03:44:09 UTC (rev 8868)
@@ -197,10 +197,23 @@
writeError();
} else {
- if(getenv(mapserv->request->ParamValues[i])) /* an environment references the actual file to use */
+ if(getenv(mapserv->request->ParamValues[i])) /* an environment variable references the actual file to use */
map = msLoadMap(getenv(mapserv->request->ParamValues[i]), NULL);
- else
+ else {
+ /* by here we know the request isn't for something in an environment variable */
+ if(getenv("MS_MAP_NO_PATH")) {
+ msSetError(MS_WEBERR, "Mapfile not found in environment variables and this server is not configured for full paths.", "loadMap()");
+ writeError();
+ if(getenv("MS_MAP_PATTERN") && msEvalRegex(getenv("MS_MAP_PATTERN"), mapserv->request->ParamValues[i]) != MS_TRUE) {
+ msSetError(MS_WEBERR, "Parameter 'map' value fails to validate.", "loadMap()");
+ writeError();
+ /* ok to try to load now */
map = msLoadMap(mapserv->request->ParamValues[i], NULL);
if(!map) writeError();
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-04-02 03:42:47 UTC (rev 8867)
+++ trunk/mapserver/mapserver.h 2009-04-02 03:44:09 UTC (rev 8868)
@@ -164,8 +164,10 @@
/* General defines, not wrapable */
#ifndef SWIG
#define MS_DEFAULT_MAPFILE_PATTERN "\\.map$"
-#define MS_TEMPLATE_EXPR "\\.(jsp|asp|cfm|xml|wml|html|htm|shtml|phtml|php|svg|kml|gml|js|tmpl)$"
+#define MS_TEMPLATE_MAGIC_STRING "MapServer Template"
+#define MS_TEMPLATE_EXPR "\\.(xml|wml|html|htm|svg|kml|gml|js|tmpl)$"
#define MS_INDEX_EXTENSION ".qix"
#define MS_QUERY_EXTENSION ".qy"
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2009-04-02 03:42:47 UTC (rev 8867)
+++ trunk/mapserver/maptemplate.c 2009-04-02 03:44:09 UTC (rev 8868)
@@ -41,6 +41,20 @@
static char *processLine(mapservObj *mapserv, char *instr, FILE *stream, int mode);
+static int isValidTemplate(FILE *stream, const char *filename)
+ char buffer[MS_BUFFER_LENGTH];
+ if(fgets(buffer, MS_BUFFER_LENGTH, stream) != NULL) {
+ if(!msCaseFindSubstring(buffer, MS_TEMPLATE_MAGIC_STRING)) {
+ msSetError(MS_WEBERR, "Missing magic string, %s doesn't look like a MapServer template.", "isValidTemplate()", filename);
+ return MS_FALSE;
+ return MS_TRUE;
* Redirect to (only use in CGI)
@@ -1040,6 +1054,11 @@
return MS_FAILURE;
+ if(isValidTemplate(includeStream, src) != MS_TRUE) {
+ fclose(includeStream);
+ return MS_FAILURE;
while(fgets(buffer, MS_BUFFER_LENGTH, includeStream) != NULL)
content = msStringConcatenate(content, buffer);
@@ -2867,6 +2886,11 @@
return(NULL);
+ if(isValidTemplate(stream, join->header) != MS_TRUE) {
+ fclose(stream);
+ return NULL;
/* echo file to the output buffer, no substitutions */
while(fgets(line, MS_BUFFER_LENGTH, stream) != NULL) outbuf = msStringConcatenate(outbuf, line);
@@ -2878,6 +2902,11 @@
return(NULL);
+ if(isValidTemplate(stream, join->template) != MS_TRUE) {
+ fclose(stream);
+ return NULL;
records = MS_TRUE;
@@ -2892,6 +2921,7 @@
rewind(stream);
+ fgets(line, MS_BUFFER_LENGTH, stream); /* skip the first line since it's the magic string */
} /* next record */
if(records==MS_TRUE && join->footer) {
@@ -2900,6 +2930,11 @@
return(NULL);
+ if(isValidTemplate(stream, join->footer) != MS_TRUE) {
+ fclose(stream);
+ return NULL;
@@ -3443,6 +3478,11 @@
return MS_FAILURE;
+ if(isValidTemplate(stream, html) != MS_TRUE) {
+ fclose(stream);
if(papszBuffer) {
if((*papszBuffer) == NULL) {
(*papszBuffer) = (char *)malloc(MS_TEMPLATE_BUFFER);
More information about the mapserver-commits
