[mapserver-commits] r8880 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Apr 4 15:56:00 EDT 2009
Author: warmerdam
Date: 2009-04-04 15:55:59 -0400 (Sat, 04 Apr 2009)
New Revision: 8880
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maprasterquery.c
trunk/mapserver/mapwcs.c
do not alter filename if path prefixing does not point to real file (#2901)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-04-03 22:23:41 UTC (rev 8879)
+++ trunk/mapserver/HISTORY.TXT 2009-04-04 19:55:59 UTC (rev 8880)
@@ -12,6 +12,9 @@
Current Version (SVN trunk):
+- Fix filename path processing for raster queries and WCS get coverage so
+ that non-filesystem filenames are not altered (#2901)
- Improved security relative to untrusted directories and mapfiles (RFC 56)
- Fixed several security issues found in an audit of the CGI application (#2939, #2941, #2942, #2943, #2944)
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c 2009-04-03 22:23:41 UTC (rev 8879)
+++ trunk/mapserver/maprasterquery.c 2009-04-04 19:55:59 UTC (rev 8880)
@@ -782,7 +782,7 @@
msBuildPath(szPath, tiAbsDirPath, filename);
free(tiAbsDirPath);
} else {
- msBuildPath3(szPath, map->mappath, map->shapepath, filename);
+ msTryBuildPath3(szPath, map->mappath, map->shapepath, filename);
msAcquireLock( TLOCK_GDAL );
@@ -1328,7 +1328,7 @@
if( map == NULL )
return MS_FAILURE;
- msBuildPath3(szPath, map->mappath, map->shapepath, layer->data);
+ msTryBuildPath3(szPath, map->mappath, map->shapepath, layer->data);
hDS = GDALOpen(szPath, GA_ReadOnly );
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2009-04-03 22:23:41 UTC (rev 8879)
+++ trunk/mapserver/mapwcs.c 2009-04-04 19:55:59 UTC (rev 8880)
@@ -2042,7 +2042,7 @@
msGDALInitialize();
- hDS = GDALOpen(msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data) , GA_ReadOnly );
+ hDS = GDALOpen(msTryBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data) , GA_ReadOnly );
if( hDS == NULL ) {
msReleaseLock( TLOCK_GDAL );
msSetError( MS_IOERR, "%s", "msWCSGetCoverageMetadata()", CPLGetLastErrorMsg() );
More information about the mapserver-commits
