[mapserver-commits] r8898 - trunk/docs/_static
Fri Apr 10 06:42:35 EDT 2009
Author: tbonfort
Date: 2009-04-10 06:42:34 -0400 (Fri, 10 Apr 2009)
New Revision: 8898
   trunk/docs/_static/map.vim
update syntax file to current version
Modified: trunk/docs/_static/map.vim
--- trunk/docs/_static/map.vim	2009-04-09 18:35:40 UTC (rev 8897)
+++ trunk/docs/_static/map.vim	2009-04-10 10:42:34 UTC (rev 8898)
@@ -1,7 +1,8 @@
 " Vim syntax file
 " Language:     map (umn mapserver config file)
 " Maintainer:   Andreas Hirner <andreas.hirner at dlr.de>
-" Last Change:  $Date: 2004/05/25 19:19:37 $
+" Maintainer:   Thomas Bonfort
+" Last Change:  $Date: 2009/04/10$
 " Filenames:    *.map
 " Note:         The definitions below are taken from TextPad syntax definitions (*.syn) by Chris Thorne (thorne at dmsolutions.ca) as of May 2004, for version 4.0 MapServer
@@ -21,35 +22,35 @@
 syn keyword mapDefine       PROJECTION QUERYMAP REFERENCE SCALEBAR STYLE SYMBOL WEB
 " General keywords second order
-syn keyword mapIdentifier   ALPHACOLOR ANGLE ANTIALIAS
+syn keyword mapIdentifier   ALIGN ALPHACOLOR ANGLE ANTIALIAS
 syn keyword mapIdentifier   BACKGROUNDCOLOR BACKGROUNDSHADOWCOLOR BACKGROUNDSHADOWSIZE BUFFER
-syn keyword mapIdentifier   CHARACTER CLASSITEM COLOR CONNECTION CONNECTIONTYPE
+syn keyword mapIdentifier   CENTER CHARACTER CLASSITEM COLOR CONFIG CONNECTION CONNECTIONTYPE
 syn keyword mapIdentifier   DATA DATAPATTERN DEBUG DRIVER DUMP
-syn keyword mapIdentifier   EMPTY ERROR EXPRESSION EXTENSION EXTENT
+syn keyword mapIdentifier   EMPTY ENCODING ERROR EXPRESSION EXTENSION EXTENT
 syn keyword mapIdentifier   FEATURE FILLED FILTER FILTERITEM FONT FONTSET FOOTER FORCE FORMATOPTION FROM
-syn keyword mapIdentifier   GAP GRATICULE GRID GROUP HEADER
+syn keyword mapIdentifier   GAP GEOMTRANSFORM GRATICULE GRID GROUP HEADER
 syn keyword mapIdentifier   IMAGE IMAGECOLOR IMAGEMODE IMAGEPATH IMAGEQUALITY IMAGETYPE IMAGEURL INDEX INTERLACE INTERVALS
 syn keyword mapIdentifier   KEYIMAGE KEYSIZE KEYSPACING
-syn keyword mapIdentifier   LABELANGLEITEM LABELCACHE LABELFORMAT LABELITEM LABELMAXSCALE LABELMINSCALE LABELREQUIRES LABELSIZEITEM LATLON LINECAP LINEJOIN LINEJOINMAXSIZE LOG
-syn keyword mapIdentifier   MARKER MARKERSIZE MAXARCS MAXBOXSIZE MAXFEATURES MAXINTERVAL MAXSCALE MAXSIZE MAXSUBDIVIDE MAXTEMPLATE MIMETYPE
-syn keyword mapIdentifier   MINARCS MINBOXSIZE MINDISTANCE MINFEATURESIZE MININTERVAL MINSCALE MINSIZE MINSUBDIVIDE MINTEMPLATE
+syn keyword mapIdentifier   LABELCACHE_MAP_EDGE_BUFFER LABELANGLEITEM LABELCACHE LABELFORMAT LABELITEM LABELMAXSCALEDENOM LABELMINSCALEDENOM LABELREQUIRES LABELSIZEITEM LATLON LINECAP LINEJOIN LINEJOINMAXSIZE LOG
+syn keyword mapIdentifier   MARKER MARKERSIZE MAXARCS MAXBOXSIZE MAXFEATURES MAXINTERVAL MAXLENGTH MAXSCALEDENOM MAXSIZE MAXSUBDIVIDE MAXTEMPLATE MAXWIDTH MIMETYPE
+syn keyword mapIdentifier   MINARCS MINBOXSIZE MINDISTANCE MINFEATURESIZE MININTERVAL MINSCALEDENOM MINSIZE MINSUBDIVIDE MINTEMPLATE MINWIDTH
 syn keyword mapIdentifier   NAME
-syn keyword mapIdentifier   OFFSET OFFSITE OUTLINECOLOR OVERLAYBACKGROUNDCOLOR OVERLAYCOLOR OVERLAYMAXSIZE OVERLAYMINSIZE OVERLAYOUTLINECOLOR OVERLAYSIZE OVERLAYSYMBOL
-syn keyword mapIdentifier   PARTIALS POINTS POSITION POSTLABELCACHE PROCESSING
+syn keyword mapIdentifier   OFFSET OFFSITE OPACITY OUTLINECOLOR OUTLINEWIDTH OVERLAYBACKGROUNDCOLOR OVERLAYCOLOR OVERLAYMAXSIZE OVERLAYMINSIZE OVERLAYOUTLINECOLOR OVERLAYSIZE OVERLAYSYMBOL
+syn keyword mapIdentifier   PARTIALS PATTERN POINTS POSITION POSTLABELCACHE PRIORITY PROCESSING
 syn keyword mapIdentifier   REQUIRES RESOLUTION
-syn keyword mapIdentifier   SCALE SHADOWCOLOR SHADOWSIZE SHAPEPATH SIZE SIZEUNITS STATUS STYLEITEM SYMBOLSCALE SYMBOLSET
+syn keyword mapIdentifier   SCALE SHADOWCOLOR SHADOWSIZE SHAPEPATH SIZE SIZEUNITS STATUS STYLEITEM SYMBOLSCALEDENOM SYMBOLSET
 syn keyword mapIdentifier   TABLE TEMPLATE TEMPLATEPATTERN TEXT TILEINDEX TILEITEM TITLE TO TOLERANCE TOLERANCEUNITS TRANSFORM TRANSPARENCY TRANSPAREN[T] TYPE
-syn keyword mapIdentifier   UNITS WMS_ABSTRACT WMS_ACCESSCONSTRAINTS WMS_ONLINERESOURCE WMS_SRS WMS_TITLE WRAP
+syn keyword mapIdentifier   UNITS WIDTH WMS_ABSTRACT WMS_ACCESSCONSTRAINTS WMS_ONLINERESOURCE WMS_SRS WMS_TITLE WRAP
 " General keywords third order
 syn keyword mapKeyword      ANNOTATION AUTO BEVEL BITMAP BUTT
 syn keyword mapKeyword      CARTOLINE CC CIRCLE CL CR CSV DD DEFAULT
-syn keyword mapKeyword      ELLIPSE EMBED FALSE FEET GIANT HILITE INCHES
+syn keyword mapKeyword      ELLIPSE EMBED FALSE FEET FOLLOW GIANT HILITE INCHES
 syn keyword mapKeyword      KILOMETERS LARGE LC LINE LL LR
 syn keyword mapKeyword      MEDIUM METERS MILES MITER MULTIPLE MYGIS NORMAL
 syn keyword mapKeyword      OFF OGR ON ONE-TO-MANY ONE-TO-ONE ORACLESPATIAL
 syn keyword mapKeyword      PIXELS PIXMAP POINT POLYGON POSTGIS QUERY RASTER ROUND
-syn keyword mapKeyword      SDE SELECTED SIMPLE SINGLE SMALL SQUARE
+syn keyword mapKeyword      RGB RGBA SDE SELECTED SIMPLE SINGLE SMALL SQUARE
 syn keyword mapKeyword      TINY TRIANGLE TRUE TRUETYPE UC UL UR VECTOR WFS WMS
 " keywords for other purposes
