[mapserver-commits] r8909 - sandbox/graphics
svn at osgeo.org
svn at osgeo.org
Tue Apr 14 13:32:37 EDT 2009
Author: assefa
Date: 2009-04-14 13:32:36 -0400 (Tue, 14 Apr 2009)
New Revision: 8909
sandbox/graphics/mapcairo.c
sandbox/graphics/mapimageio.c
sandbox/graphics/mapoutput.c
sandbox/graphics/maprendering.c
sandbox/graphics/mapserver.h
sandbox/graphics/maputil.c
Build on windows
Modified: sandbox/graphics/mapcairo.c
--- sandbox/graphics/mapcairo.c 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/mapcairo.c 2009-04-14 17:32:36 UTC (rev 8909)
@@ -31,8 +31,14 @@
#include "mapserver.h"
#include <cairo.h>
+#if defined(_WIN32) && !defined(__CYGWIN__)
+#include <cairo-pdf.h>
+#include <cairo-svg.h>
+#else
#include <cairo/cairo-pdf.h>
#include <cairo/cairo-svg.h>
+#endif
# include <cairo-ft.h>
#include <pango/pangocairo.h>
@@ -90,16 +96,18 @@
cairo_font_face_t *getFontFace(cairo_renderer *r, char *font) {
+ faceCacheObj *newface = NULL;
+ FT_Face face;// = malloc(sizeof(FT_Face));
faceCacheObj *cur=r->facecache;
static const cairo_user_data_key_t key;
while(cur) {
if(cur->path == font) return cur->face;
cur = cur->next;
- faceCacheObj *newface = malloc(sizeof(faceCacheObj));
+ newface = malloc(sizeof(faceCacheObj));
newface->next = r->facecache;
r->facecache = newface;
- FT_Face face;// = malloc(sizeof(FT_Face));
FT_New_Face(r->library, font, 0, &face);
newface->face = cairo_ft_font_face_create_for_ft_face(face, 0);
@@ -168,20 +176,21 @@
void msDrawPolygonTiledCairo(imageObj *img, shapeObj *p,colorObj *oc, double outlineWidth, void *tile) {
- cairo_renderer *r = getCairoRenderer(img);
- cairo_pattern_t *pattern = cairo_pattern_create_for_surface(tile);
- cairo_pattern_set_extend(pattern, CAIRO_EXTEND_REPEAT);
- int i,j;
- cairo_set_source(r->cr, pattern);
- for (i = 0; i < p->numlines; i++) {
- lineObj *l = &(p->line[i]);
- cairo_move_to(r->cr, l->point[0].x, l->point[0].y);
- for (j = 1; j < l->numpoints; j++) {
- cairo_line_to(r->cr, l->point[j].x, l->point[j].y);
- //cairo_close_path(r->cr);
- cairo_fill(r->cr);
+ int i,j;
+ cairo_renderer *r = getCairoRenderer(img);
+ cairo_pattern_t *pattern = cairo_pattern_create_for_surface(tile);
+ cairo_pattern_set_extend(pattern, CAIRO_EXTEND_REPEAT);
+ cairo_set_source(r->cr, pattern);
+ for (i = 0; i < p->numlines; i++) {
+ lineObj *l = &(p->line[i]);
+ cairo_move_to(r->cr, l->point[0].x, l->point[0].y);
+ for (j = 1; j < l->numpoints; j++) {
+ cairo_line_to(r->cr, l->point[j].x, l->point[j].y);
+ //cairo_close_path(r->cr);
+ cairo_fill(r->cr);
cairo_surface_t *createSurfaceFromBuffer(rasterBufferObj *b) {
@@ -299,17 +308,18 @@
void renderTruetypeSymbolCairo(imageObj *img, double x, double y, symbolObj *symbol,
symbolStyleObj *s) {
+ cairo_font_face_t *ff = getFontFace(r,symbol->full_font_path);
+ cairo_text_extents_t extents;
+ cairo_matrix_t trans;
+ double ox,oy;
cairo_save(r->cr);
- cairo_font_face_t *ff = getFontFace(r,symbol->full_font_path);
- cairo_text_extents_t extents;
cairo_set_font_face(r->cr, ff);
cairo_set_font_size(r->cr, s->scale * 96 / 72.0);
cairo_text_extents(r->cr, symbol->character, &extents);
- cairo_matrix_t trans;
cairo_matrix_init_rotate(&trans,-s->rotation);
- double ox,oy;
ox=extents.x_bearing+extents.width/2.;
oy=extents.y_bearing+extents.height/2.;
cairo_matrix_transform_point(&trans,&ox,&oy);
@@ -336,25 +346,31 @@
colorObj *bc,
colorObj *oc, double ow) {
+ int w,h;
//cairo_font_face_t *ff = getFontFace(r,font);
+ cairo_surface_t *surface;
+ cairo_t *cr;
+ double ox,oy;
//cairo_set_font_face(r->cr, ff);
cairo_set_font_size(r->cr, size * 96 / 72.0);
cairo_text_extents(r->cr, text, &extents);
- int w=extents.width*1.5,h=extents.height*1.5;
- cairo_surface_t *surface = cairo_image_surface_create (CAIRO_FORMAT_ARGB32,
+ w=extents.width*1.5;
+ h=extents.height*1.5;
+ surface = cairo_image_surface_create (CAIRO_FORMAT_ARGB32,
w,h);
- cairo_t *cr = cairo_create(surface);
+ cr = cairo_create(surface);
if (bc && MS_VALID_COLOR(*bc)) {
msCairoSetSourceColor(cr, bc);
cairo_paint(cr);
cairo_matrix_init_rotate(&trans,-angle);
- double ox,oy;
@@ -501,13 +517,13 @@
cairo_renderer *r = getCairoRenderer(image);
cairo_font_face_t *ff = getFontFace(r,style->font);
+ const char *string_ptr;
+ char s[11];
+ int i = 0;
cairo_set_font_face(r->cr,ff);
cairo_set_font_size(r->cr,style->size*96/72.0);
- const char *string_ptr;
- char s[11];
- int i = 0;
if (&style->outlinecolor != NULL && MS_VALID_COLOR(style->outlinecolor)) {
msCairoSetSourceColor(r->cr, &style->outlinecolor);
@@ -565,6 +581,7 @@
imageObj* msImageCreateCairo(int width, int height, outputFormatObj *format,colorObj* bg) {
imageObj *image = NULL;
+ cairo_renderer *r=NULL;
if (format->imagemode != MS_IMAGEMODE_RGB && format->imagemode!= MS_IMAGEMODE_RGBA) {
msSetError(MS_MISCERR,
"Cairo driver only supports RGB or RGBA pixel models.","msImageCreateCairo()");
@@ -572,7 +589,7 @@
if (width > 0 && height > 0) {
image = (imageObj *) calloc(1, sizeof(imageObj));
- cairo_renderer *r = (cairo_renderer*)malloc(sizeof(cairo_renderer));
+ r = (cairo_renderer*)malloc(sizeof(cairo_renderer));
if(!strcasecmp(format->driver,"cairo/pdf")) {
r->outputStream = (bufferObj*)malloc(sizeof(bufferObj));
msBufferInit(r->outputStream);
Modified: sandbox/graphics/mapimageio.c
--- sandbox/graphics/mapimageio.c 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/mapimageio.c 2009-04-14 17:32:36 UTC (rev 8909)
@@ -88,6 +88,8 @@
struct jpeg_compress_struct cinfo;
struct jpeg_error_mgr jerr;
ms_destination_mgr *dest;
+ JSAMPLE *rowdata;
+ unsigned int row;
cinfo.err = jpeg_std_error(&jerr);
jpeg_create_compress(&cinfo);
@@ -121,8 +123,7 @@
jpeg_set_quality(&cinfo, quality, TRUE);
jpeg_start_compress(&cinfo, TRUE);
- JSAMPLE *rowdata = (JSAMPLE*)malloc(data->width*cinfo.input_components*sizeof(JSAMPLE));
- unsigned int row;
+ rowdata = (JSAMPLE*)malloc(data->width*cinfo.input_components*sizeof(JSAMPLE));
for(row=0;row<data->height;row++) {
JSAMPLE *pixptr = rowdata;
int col;
@@ -150,13 +151,16 @@
int saveAsPNG(rasterBufferObj *data, streamInfo *info) {
+ png_infop info_ptr;
+ int color_type;
+ int row;
+ unsigned int *rowdata;
png_structp png_ptr = png_create_write_struct(
PNG_LIBPNG_VER_STRING, NULL,NULL,NULL);
if (!png_ptr)
return (MS_FAILURE);
- png_infop info_ptr = png_create_info_struct(png_ptr);
+ info_ptr = png_create_info_struct(png_ptr);
if (!info_ptr)
png_destroy_write_struct(&png_ptr,
@@ -174,7 +178,6 @@
else
png_set_write_fn(png_ptr,info, png_write_data_to_buffer, png_flush_data);
- int color_type;
if(data->a)
color_type = PNG_COLOR_TYPE_RGB_ALPHA;
else
@@ -189,8 +192,7 @@
if(!data->a && data->pixel_step==4)
png_set_filler(png_ptr, 0, PNG_FILLER_AFTER);
- int row;
- unsigned int *rowdata = (unsigned int*)malloc(data->width*sizeof(unsigned int));
+ rowdata = (unsigned int*)malloc(data->width*sizeof(unsigned int));
unsigned int *pixptr = rowdata;
int col;
Modified: sandbox/graphics/mapoutput.c
--- sandbox/graphics/mapoutput.c 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/mapoutput.c 2009-04-14 17:32:36 UTC (rev 8909)
@@ -393,6 +393,17 @@
if( msSelectOutputFormat( map, "svg" ) == NULL )
msCreateDefaultOutputFormat( map, "svg" );
+#if defined(USE_CAIRO)
+ if( msSelectOutputFormat( map, "cairopng24" ) == NULL )
+ msCreateDefaultOutputFormat( map, "CAIRO/PNG" );
+ if( msSelectOutputFormat( map, "cairojpeg" ) == NULL )
+ msCreateDefaultOutputFormat( map, "CAIRO/JPEG" );
+ if( msSelectOutputFormat( map, "cairopdf" ) == NULL )
+ msCreateDefaultOutputFormat( map, "CAIRO/PDF" );
+ if( msSelectOutputFormat( map, "cairosvg" ) == NULL )
+ msCreateDefaultOutputFormat( map, "CAIRO/SVG" );
+#endif
if( map->imagetype != NULL )
free( map->imagetype );
map->imagetype = saved_imagetype;
Modified: sandbox/graphics/maprendering.c
--- sandbox/graphics/maprendering.c 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/maprendering.c 2009-04-14 17:32:36 UTC (rev 8909)
@@ -300,6 +300,7 @@
rasterBufferObj *loadGDImg(gdImagePtr img) {
rasterBufferObj *b = malloc(sizeof(rasterBufferObj));
+ int row,col;
b->width = img->sx;
b->height = img->sy;
b->pixelbuffer = (unsigned char*)malloc(b->width*b->height*sizeof(int));
@@ -310,7 +311,6 @@
b->b = &b->pixelbuffer[2];
b->a = &b->pixelbuffer[3];
- int row,col;
for (row = 0; row < b->height; row++) {
unsigned char* rowptr = &(b->pixelbuffer[row*b->row_step]);
for (col = 0; col < b->width; col++) {
@@ -717,14 +717,14 @@
int msDrawText(imageObj *image, pointObj labelPnt, char *string,
labelObj *label, fontSetObj *fontset, double scalefactor) {
int nReturnVal = -1;
- if (image) {
+ labelStyleObj s;
+ if (image) {
if (MS_RENDERER_PLUGIN(image->format)) {
renderObj *r = image->format->r;
double x, y;
if (!string || !strlen(string))
return (0); // not errors, just don't want to do anything
- labelStyleObj s;
computeLabelStyle(&s,label,fontset,scalefactor);
x = labelPnt.x;
@@ -758,14 +758,13 @@
int msDrawTextLine(imageObj *image, char *string, labelObj *label, labelPathObj *labelpath, fontSetObj *fontset, double scalefactor)
if(image) {
+ labelStyleObj s;
- labelStyleObj s;
if (label->type == MS_TRUETYPE) {
Modified: sandbox/graphics/mapserver.h
--- sandbox/graphics/mapserver.h 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/mapserver.h 2009-04-14 17:32:36 UTC (rev 8909)
@@ -2579,8 +2579,8 @@
inline void msBufferInit(bufferObj *buffer);
inline void msBufferResize(bufferObj *buffer, size_t target_size);
-inline void msBufferFree(bufferObj *buffer);
-inline void msBufferAppend(bufferObj *buffer, void *data, size_t length);
+MS_DLL_EXPORT inline void msBufferFree(bufferObj *buffer);
+MS_DLL_EXPORT inline void msBufferAppend(bufferObj *buffer, void *data, size_t length);
struct renderer{
void *renderer_data;
Modified: sandbox/graphics/maputil.c
--- sandbox/graphics/maputil.c 2009-04-14 13:39:42 UTC (rev 8908)
+++ sandbox/graphics/maputil.c 2009-04-14 17:32:36 UTC (rev 8909)
@@ -773,11 +773,11 @@
*size_ptr = 0;
if( MS_RENDERER_PLUGIN(image->format)){
+ rasterBufferObj data;
if(r->supports_pixel_buffer) {
bufferObj buffer;
msBufferInit(&buffer);
- rasterBufferObj data;
r->getRasterBuffer(image,&data);
msSaveRasterBufferToBuffer(&data,&buffer,format);
return buffer.data;
More information about the mapserver-commits
