[mapserver-commits] r8959 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Apr 24 11:07:55 EDT 2009
Author: assefa
Date: 2009-04-24 11:07:54 -0400 (Fri, 24 Apr 2009)
New Revision: 8959
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/maplegend.c
Fix Getlegendgraphic when sizeunit is set (#2983)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2009-04-23 21:45:44 UTC (rev 8958)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2009-04-24 15:07:54 UTC (rev 8959)
@@ -9,11 +9,16 @@
For a complete change history, please see the Subversion log comments.
+Current Version:
+- Fix Getlegendgraphic when sizeunit is set
+- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
Version 5.4.0 (2009-04-22):
-- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
Version 5.4.0-rc2 (2009-04-15):
Modified: branches/branch-5-4/mapserver/maplegend.c
--- branches/branch-5-4/mapserver/maplegend.c 2009-04-23 21:45:44 UTC (rev 8958)
+++ branches/branch-5-4/mapserver/maplegend.c 2009-04-24 15:07:54 UTC (rev 8959)
@@ -351,8 +351,10 @@
/* set the scale factor so that scale dependant symbols are drawn in the legend with their default size */
if(cur->layer->sizeunits != MS_PIXELS)
+ map->cellsize = msAdjustExtent(&(map->extent), map->width, map->height);
cur->layer->scalefactor = (msInchesPerUnit(cur->layer->sizeunits,0)/msInchesPerUnit(map->units,0)) / map->cellsize;
if(msDrawLegendIcon(map, cur->layer, cur->theclass, map->legend.keysizex, map->legend.keysizey, image, HMARGIN, (int) pnt.y) != MS_SUCCESS)
return NULL;
More information about the mapserver-commits
