[mapserver-commits] r8977 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Apr 29 23:37:25 EDT 2009
Author: sdlime
Date: 2009-04-29 23:37:25 -0400 (Wed, 29 Apr 2009)
New Revision: 8977
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maptemplate.c
Fixed template argument initialization for item, shpxy and extent tags. (#2990)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-04-29 13:06:17 UTC (rev 8976)
+++ trunk/mapserver/HISTORY.TXT 2009-04-30 03:37:25 UTC (rev 8977)
@@ -12,8 +12,11 @@
Current Version (SVN trunk):
-- - Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
+- Fixed template code for item, shpxy and extent tags to properly initialize tag arguments in cases
+ where there are mutiple tags in one chunk of template (#2990)
+- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
- Rework Python MapScript's setup.py to be more like Python's to fix
a number of issues including (#2637) and to use mapserver-config
and ditch the old mapscriptvars approach
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2009-04-29 13:06:17 UTC (rev 8976)
+++ trunk/mapserver/maptemplate.c 2009-04-30 03:37:25 UTC (rev 8977)
@@ -513,6 +513,8 @@
/* msReturnTemplateQuerycheck all argument if they have values */
for (i=0; i<nArgs; i++) {
+ if(strlen(papszArgs[i]) == 0) continue;
if(strchr(papszArgs[i], '='))
papszVarVal = msStringTokenize(papszArgs[i], "=", &nDummy, MS_FALSE);
@@ -1110,18 +1112,14 @@
int tagOffset, tagLength;
char *encodedTagValue=NULL, *tagValue=NULL;
- char *argValue;
+ char *argValue=NULL;
- char *name=NULL;
- char *pattern=NULL;
- int precision=-1; /* don't change */
- char *format="$value";
- char *nullFormat="";
- int uc=MS_FALSE, lc=MS_FALSE, commify=MS_FALSE;
+ char *name=NULL, *pattern=NULL;
+ char *format=NULL, *nullFormat=NULL;
+ int precision;
+ int uc, lc, commify;
+ int escape;
- /* int substr=MS_FALSE, substrStart, substrLength; */
- int escape=ESCAPE_HTML;
if(!*line) {
msSetError(MS_WEBERR, "Invalid line pointer.", "processItemTag()");
return(MS_FAILURE);
@@ -1132,6 +1130,13 @@
if(!tagStart) return(MS_SUCCESS); /* OK, just return; */
while (tagStart) {
+ format = "$value"; /* initialize the tag arguments */
+ nullFormat = "";
+ precision=-1;
+ name = pattern = NULL;
+ uc = lc = commify = MS_FALSE;
+ escape=ESCAPE_HTML;
tagOffset = tagStart - *line;
/* check for any tag arguments */
@@ -1278,14 +1283,14 @@
rectObj tempExtent;
- double xExpand=0, yExpand=0;
+ double xExpand, yExpand;
char number[64]; /* holds a single number in the extent */
- char numberFormat[16]="%f";
- char *format="$minx $miny $maxx $maxy";
+ char numberFormat[16];
+ char *format;
- int precision=-1;
+ int precision;
+ int escape;
char *projectionString=NULL;
@@ -1303,6 +1308,15 @@
if(strstr(name, "_esc")) escape = ESCAPE_URL;
while(tagStart) {
+ xExpand = yExpand = 0; /* set tag argument defaults */
+ precision = -1;
+ format = "$minx $miny $maxx $maxy";
+ if(strstr(name, "_esc"))
+ escape = ESCAPE_URL;
+ else
+ escape = ESCAPE_HTML;
+ projectionString = NULL;
@@ -1367,6 +1381,8 @@
if(precision != -1)
snprintf(numberFormat, 16, "%%.%dlf", precision);
+ else
+ snprintf(numberFormat, 16, "%%f");
snprintf(number, 64, numberFormat, tempExtent.minx);
tagValue = msReplaceSubstring(tagValue, "$minx", number);
@@ -1436,31 +1452,31 @@
hashTableObj *tagArgs=NULL;
- char *argValue;
- char *pointFormat1, *pointFormat2;
+ char *pointFormat1=NULL, *pointFormat2=NULL;
int pointFormatLength;
- /* h = header, f=footer, s=seperator */
- char *xh="", *xf=",";
- char *yh="", *yf="";
- char *cs=" "; /* coordinate */
- char *ph="", *pf="", *ps=" "; /* part: works for multi-point/multi-linestring and simple polygons */
+ ** Pointers to static strings, naming convention is:
+ ** char 1 - x=x, y=y, c=coordinate, p=part, s=shape
+ ** char 2 - h=header, f=footer, s=seperator
+ char *xh, *xf, *yh, *yf;
+ char *cs;
+ char *ph, *pf, *ps;
+ char *sh, *sf;
/* char *irh="", *irf="", *irs=""; // inner ring: necessary for complex polygons */
/* char *orh="", *orf="", *ors=""; // outer ring */
- char *sh="", *sf=""; /* shape */
+ int centroid;
+ int precision;
- int centroid=MS_FALSE; /* output just the centroid */
- int precision=0;
+ double buffer;
+ int bufferUnits;
- double buffer=0; /* no buffer */
- int bufferUnits=-1;
+ char *projectionString=NULL;
shapeObj tShape;
- char *projectionString=NULL;
char *coords=NULL, point[128];
if(!*line) {
@@ -1481,7 +1497,19 @@
return(MS_FAILURE);
- while (tagStart) {
+ while (tagStart) {
+ xh = yh = yf = ph = pf = sh = sf = ""; /* initialize the tag arguments */
+ xf= ",";
+ ps = cs = " ";
+ centroid = MS_FALSE;
+ precision = 0;
+ buffer = 0;
+ bufferUnits = -1;
@@ -1658,9 +1686,9 @@
/* clean up */
free(tag); tag = NULL;
msFreeHashTable(tagArgs); tagArgs=NULL;
- free(pointFormat1);
- free(pointFormat2);
- free(coords);
+ free(pointFormat1); pointFormat1 = NULL;
+ free(pointFormat2); pointFormat2 = NULL;
+ free(coords); coords = NULL;
if((*line)[tagOffset] != '\0')
tagStart = findTag(*line+tagOffset+1, "shpxy");
More information about the mapserver-commits
