[mapserver-commits] r9581 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Dec 4 17:40:21 EST 2009
Author: warmerdam
Date: 2009-12-04 17:40:19 -0500 (Fri, 04 Dec 2009)
New Revision: 9581
trunk/mapserver/mapogr.cpp
add support for label positioning with ogr autostyling
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp 2009-12-04 22:24:21 UTC (rev 9580)
+++ trunk/mapserver/mapogr.cpp 2009-12-04 22:40:19 UTC (rev 9581)
@@ -2778,6 +2778,28 @@
// OGR default is anchor point = LL, so label is at UR of anchor
c->label.position = MS_UR;
+ int nPosition = OGR_ST_GetParamNum(hLabelStyle,
+ OGRSTLabelAnchor,
+ &bIsNull);
+ if( !bIsNull )
+ switch( nPosition ) {
+ case 1: c->label.position = MS_UR; break;
+ case 2: c->label.position = MS_UC; break;
+ case 3: c->label.position = MS_UL; break;
+ case 4: c->label.position = MS_CR; break;
+ case 5: c->label.position = MS_CC; break;
+ case 6: c->label.position = MS_CL; break;
+ case 7: c->label.position = MS_LR; break;
+ case 8: c->label.position = MS_LC; break;
+ case 9: c->label.position = MS_LL; break;
+ case 10: c->label.position = MS_LR; break; /*approximate*/
+ case 11: c->label.position = MS_LC; break;
+ case 12: c->label.position = MS_LL; break;
+ default: break;
const char *pszColor = OGR_ST_GetParamStr(hLabelStyle,
OGRSTLabelFColor,
&bIsNull);
More information about the mapserver-commits
