[mapserver-commits] r9588 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Dec 7 12:00:43 EST 2009
Author: aboudreault
Date: 2009-12-07 12:00:41 -0500 (Mon, 07 Dec 2009)
New Revision: 9588
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maplegend.c
Fixed HTML legend image samples truncated (#2636)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-12-07 16:10:12 UTC (rev 9587)
+++ trunk/mapserver/HISTORY.TXT 2009-12-07 17:00:41 UTC (rev 9588)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed HTML legend image samples truncated (#2636)
- WMS GetFeatureInfo should respect the scale like GetMap does (#842)
- Filter encoding: simple filters using propertyislike not applied properly
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c 2009-12-07 16:10:12 UTC (rev 9587)
+++ trunk/mapserver/maplegend.c 2009-12-07 17:00:41 UTC (rev 9588)
@@ -44,6 +44,7 @@
int width, int height, imageObj *image, int dstX, int dstY)
int i, type;
+ double offset;
shapeObj box, zigzag;
pointObj marker;
char szPath[MS_MAXPATHLEN];
@@ -54,7 +55,6 @@
if(MS_VALID_COLOR(map->legend.outlinecolor))
gdImageSetClip(image->img.gd, dstX, dstY, dstX + width - 1, dstY + height - 1);
/* initialize the box used for polygons and for outlines */
box.line = (lineObj *)malloc(sizeof(lineObj));
box.numlines = 1;
@@ -137,19 +137,24 @@
break;
case MS_LAYER_LINE:
+ offset = 1;
+ /* To set the offset, we only check the size/width parameter of the first style */
+ if (theclass->numstyles > 0) {
+ offset = (theclass->styles[0]->size != -1) ? theclass->styles[0]->size/2 : theclass->styles[0]->width/2;
zigzag.line = (lineObj *)malloc(sizeof(lineObj));
zigzag.numlines = 1;
zigzag.line[0].point = (pointObj *)malloc(sizeof(pointObj)*4);
zigzag.line[0].numpoints = 4;
- zigzag.line[0].point[0].x = dstX;
- zigzag.line[0].point[0].y = dstY + height - 1;
+ zigzag.line[0].point[0].x = dstX + offset;
+ zigzag.line[0].point[0].y = dstY + height - offset;
zigzag.line[0].point[1].x = dstX + MS_NINT(width / 3.0) - 1;
- zigzag.line[0].point[1].y = dstY;
+ zigzag.line[0].point[1].y = dstY + offset;
zigzag.line[0].point[2].x = dstX + MS_NINT(2.0 * width / 3.0) - 1;
- zigzag.line[0].point[2].y = dstY + height - 1;
- zigzag.line[0].point[3].x = dstX + width - 1;
- zigzag.line[0].point[3].y = dstY;
+ zigzag.line[0].point[2].y = dstY + height - offset;
+ zigzag.line[0].point[3].x = dstX + width - offset;
+ zigzag.line[0].point[3].y = dstY + offset;
for(i=0; i<theclass->numstyles; i++)
msDrawLineSymbol(&map->symbolset, image, &zigzag, theclass->styles[i], lp->scalefactor);
More information about the mapserver-commits
