[mapserver-commits] r9635 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Dec 20 17:40:20 EST 2009
Author: assefa
Date: 2009-12-20 17:40:19 -0500 (Sun, 20 Dec 2009)
New Revision: 9635
trunk/mapserver/mapows.c
trunk/mapserver/mapows.h
trunk/mapserver/mapwms.c
Expose templated format list to WMS GetFeatureInfo #3172
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c 2009-12-19 14:37:54 UTC (rev 9634)
+++ trunk/mapserver/mapows.c 2009-12-20 22:40:19 UTC (rev 9635)
@@ -1863,6 +1863,47 @@
return -1;
+/* msOwsIsOutputFormatValid */
+/* Utlity function to parse a comma separated list in a */
+/* metedata object and select and outputformat. */
+outputFormatObj* msOwsIsOutputFormatValid(mapObj *map, const char *format,
+ hashTableObj *metadata,
+ const char *namespaces, const char *name)
+ int bValid = MS_FALSE;
+ char **tokens=NULL;
+ int i,n;
+ outputFormatObj *psFormat = NULL;
+ const char * format_list=NULL;
+ if (map && format && metadata && namespaces && name)
+ format_list = msOWSLookupMetadata(metadata, namespaces, name);
+ n = 0;
+ if ( format_list)
+ tokens = msStringSplit(format_list, ',', &n);
+ if (tokens && n > 0)
+ for (i=0; i<n; i++)
+ msStringTrim(tokens[i]);
+ if (strcasecmp(tokens[i], format) == 0)
+ break;
+ msFreeCharArray(tokens, n);
+ if (i < n)
+ psFormat = msSelectOutputFormat( map, format);
+ return psFormat;
#endif /* USE_WMS_SVR || USE_WFS_SVR || USE_WCS_SVR */
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h 2009-12-19 14:37:54 UTC (rev 9634)
+++ trunk/mapserver/mapows.h 2009-12-20 22:40:19 UTC (rev 9635)
@@ -303,6 +303,8 @@
int msOWSNegotiateUpdateSequence(const char *requested_updateSequence, const char *updatesequence);
+outputFormatObj *msOwsIsOutputFormatValid(mapObj *map, const char *format, hashTableObj *metadata,
+ const char *namespaces, const char *name);
#endif
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2009-12-19 14:37:54 UTC (rev 9634)
+++ trunk/mapserver/mapwms.c 2009-12-20 22:40:19 UTC (rev 9635)
@@ -397,17 +397,15 @@
char srsbuffer[100];
int epsgvalid = MS_FALSE;
const char *projstring;
- char **tokens;
- int n,j = 0;
int timerequest = 0;
char *stime = NULL;
+ int n,j;
int srsfound = 0;
int bboxfound = 0;
int formatfound = 0;
int widthfound = 0;
int heightfound = 0;
char *request = NULL;
int status = 0;
@@ -665,29 +663,22 @@
else if (strcasecmp(names[i], "FORMAT") == 0) {
const char *format_list = NULL;
+ outputFormatObj *psFormat=NULL;
formatfound = 1;
/*check to see if a predefined list is given*/
format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getmap_formatlist");
- n = 0;
- if ( format_list)
- tokens = msStringSplit(format_list, ',', &n);
- if (tokens && n > 0)
+ if (format_list)
- for (j=0; j<n; j++)
+ psFormat = msOwsIsOutputFormatValid(map, values[i], &(map->web.metadata),
+ "M", "getmap_formatlist");
+ if (psFormat == NULL)
- if (strcasecmp(tokens[j], values[i]) == 0)
- break;
- msFreeCharArray(tokens, n);
- if (j == n || (format = msSelectOutputFormat( map, values[i])) == NULL)
- msSetError(MS_IMGERR,
+ msSetError(MS_IMGERR,
"Unsupported output format (%s).",
"msWMSLoadGetMapParams()",
values[i] );
- return msWMSException(map, nVersion, "InvalidFormat");
+ return msWMSException(map, nVersion, "InvalidFormat");
else
@@ -1842,6 +1833,7 @@
* msWMSIsSubGroup
@@ -1937,7 +1929,7 @@
char *dtd_url = NULL;
char *script_url=NULL, *script_url_encoded=NULL;
- const char *pszMimeType=NULL;
char szVersionBuf[OWS_VERSION_MAXLEN];
char *schemalocation = NULL;
const char *updatesequence=NULL;
@@ -1945,7 +1937,11 @@
const char *encoding;
char *pszTmp=NULL;
int i;
+ const char *format_list=NULL;
+ char *final_format_list=NULL;
+ char **tokens = NULL;
+ int numtokens = 0;
updatesequence = msOWSLookupMetadata(&(map->web.metadata), "MO", "updatesequence");
sldenabled = msOWSLookupMetadata(&(map->web.metadata), "MO", "sld_enabled");
@@ -2169,7 +2165,8 @@
else
char *mime_list[20];
+ int mime_count = 0;
+ int max_mime = 20;
/* WMS 1.1.0 and later */
/* Note changes to the request names, their ordering, and to the formats */
@@ -2191,30 +2188,74 @@
mime_list[16], mime_list[17], mime_list[18], mime_list[19],
NULL );
- pszMimeType = msOWSLookupMetadata(&(map->web.metadata), "MO",
- "feature_info_mime_type");
+ format_list = msOWSLookupMetadata(&(map->web.metadata), "M",
+ "getfeatureinfo_formatlist");
+ /*feature_info_mime_type depricated for MapServer 6.0*/
+ if (!format_list)
+ format_list = msOWSLookupMetadata(&(map->web.metadata), "MO",
+ "feature_info_mime_type");
+ if (format_list && strlen(format_list) > 0)
+ tokens = msStringSplit(format_list, ',', &numtokens);
+ if (tokens && numtokens > 0)
+ mime_count = 0;
+ for(i=0; i < numtokens; i++ )
+ /*text plain and gml do not need to be a format and accepted by default*/
+ /*can not really validate since the old way of using template
+ with wei->header, layer->template ... should be kept*/
+ if (strlen(tokens[i]) > 0 && mime_count<max_mime)
+ mime_list[mime_count++] = tokens[i];
+ /*add text/plain and gml */
+ if (msCaseFindSubstring(format_list, "GML") == 0 &&
+ msCaseFindSubstring(format_list, "application/vnd.ogc.gml") == 0)
+ if (mime_count<max_mime)
+ mime_list[mime_count++] = "application/vnd.ogc.gml";
+ if (msCaseFindSubstring(format_list, "text/plain") == 0 &&
+ msCaseFindSubstring(format_list, "MIME") == 0)
+ mime_list[mime_count++] = "text/plain";
+ else /*force always this format*/
+ mime_list[max_mime-1] = "text/plain";
+ if (mime_count>0)
+ mime_list[mime_count] = NULL;
+ msWMSPrintRequestCap(nVersion, "GetFeatureInfo", script_url_encoded,
+ mime_list[0], mime_list[1], mime_list[2], mime_list[3],
+ mime_list[4], mime_list[5], mime_list[6], mime_list[7],
+ mime_list[8], mime_list[9], mime_list[10], mime_list[11],
+ mime_list[12], mime_list[13], mime_list[14], mime_list[15],
+ mime_list[16], mime_list[17], mime_list[18], mime_list[19],
+ NULL);
+ /*if all formats given are invalid go to default*/
+ else
+ "text/plain",
+ "application/vnd.ogc.gml",
+ NULL);
- if (pszMimeType) {
- if (strcasecmp(pszMimeType, "text/plain") == 0) {
+ if (numtokens>0)
+ msFreeCharArray(tokens, numtokens);
+ else
- pszMimeType,
- "application/vnd.ogc.gml",
- NULL);
- else {
- msWMSPrintRequestCap(nVersion, "GetFeatureInfo", script_url_encoded,
"text/plain",
- pszMimeType,
NULL);
- else {
- "text/plain",
- NULL);
if (strcasecmp(sldenabled, "true") == 0) {
if (nVersion == OWS_1_3_0)
@@ -2803,13 +2844,13 @@
double cellx, celly;
errorObj *ms_error = msGetErrorObj();
int query_status=MS_NOERR;
int query_layer = 0;
+ int valid_format=MS_FALSE;
+ int format_found = MS_FALSE;
- pszMimeType = msOWSLookupMetadata(&(map->web.metadata), "MO", "FEATURE_INFO_MIME_TYPE");
encoding = msOWSLookupMetadata(&(map->web.metadata), "MO", "encoding");
for(i=0; map && i<numentries; i++) {
@@ -2843,7 +2884,13 @@
msFreeCharArray(layers, numlayers);
} else if (strcasecmp(names[i], "INFO_FORMAT") == 0)
- info_format = values[i];
+ if (values[i] && strlen(values[i]) > 0)
+ info_format = values[i];
+ format_found = MS_TRUE;
else if (strcasecmp(names[i], "FEATURE_COUNT") == 0)
feature_count = atoi(values[i]);
else if(strcasecmp(names[i], "X") == 0 || strcasecmp(names[i], "I") == 0)
@@ -2934,6 +2981,46 @@
if(msQueryByPoint(map) != MS_SUCCESS)
if((query_status=ms_error->code) != MS_NOTFOUND) return msWMSException(map, nVersion, NULL);
+ /*validate the INFO_FORMAT*/
+ valid_format = MS_FALSE;
+ if (!format_list)
+ if (format_list)
+ /*can not really validate if it is a valid output format
+ since old way of using template with web->header/footer and
+ layer templates need to still be supported.
+ We can only validate if it was part of the format list*/
+ if (msCaseFindSubstring(format_list, info_format))
+ valid_format = MS_TRUE;
+ /*check to see if the format passed is text/plain or GML and if is
+ defined in the formatlist. If that is the case, It is a valid format*/
+ if (strcasecmp(info_format, "MIME") == 0 ||
+ strcasecmp(info_format, "text/plain") == 0 ||
+ strncasecmp(info_format, "GML", 3) == 0 ||
+ strcasecmp(info_format, "application/vnd.ogc.gml") == 0)
+ /*last case: if the info_format is not part of the request, it defaults to MIME*/
+ if (!valid_format && format_found == MS_FALSE)
+ valid_format =MS_TRUE;
+ if (!valid_format)
+ msSetError(MS_WMSERR, "Unsupported INFO_FORMAT value (%s).",
+ "msWMSFeatureInfo()", info_format);
+ if (nVersion >= OWS_1_3_0)
+ else
+ return msWMSException(map, nVersion, NULL);
/* Generate response */
strcasecmp(info_format, "text/plain") == 0) {
@@ -2967,8 +3054,8 @@
msGMLWriteQuery(map, NULL, "GMO"); /* default is stdout */
- } else
- if (pszMimeType && (strcmp(pszMimeType, info_format) == 0))
+ else
mapservObj *msObj;
@@ -2990,7 +3077,7 @@
if(msReturnURL(msObj, msObj->map->web.empty, BROWSE) != MS_SUCCESS)
- else if (msReturnTemplateQuery(msObj, (char*)pszMimeType, NULL) != MS_SUCCESS)
+ else if (msReturnTemplateQuery(msObj, (char *)info_format, NULL) != MS_SUCCESS)
/* We don't want to free the map, and param names/values since they */
@@ -3002,14 +3089,6 @@
msFreeMapServObj(msObj);
- else
- msSetError(MS_WMSERR, "Unsupported INFO_FORMAT value (%s).", "msWMSFeatureInfo()", info_format);
- if (nVersion >= OWS_1_3_0)
- else
- return msWMSException(map, nVersion, NULL);
return(MS_SUCCESS);
@@ -3236,8 +3315,6 @@
char *sld_version = NULL;
const char *sldenabled = NULL;
- char **tokens;
- int n,j = 0;
if (sldenabled == NULL)
@@ -3323,25 +3400,17 @@
/* validate format */
- format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getlegendgraphic_formatlist");
- n = 0;
- if ( format_list)
+ format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getlegendgraphic_formatlist");
+ if (format_list)
+ psFormat = msOwsIsOutputFormatValid(map, pszFormat, &(map->web.metadata),
+ "M", "getlegendgraphic_formatlist");
- if (strcasecmp(tokens[j], pszFormat) == 0)
- break;
- if (j == n || (psFormat = msSelectOutputFormat( map, pszFormat)) == NULL)
"msWMSGetLegendGraphic()",
- values[i] );
+ pszFormat);
More information about the mapserver-commits
