[mapserver-commits] r9645 - in trunk/msautotest: gdal mspython
svn at osgeo.org
svn at osgeo.org
Thu Dec 31 12:52:45 EST 2009
Author: warmerdam
Date: 2009-12-31 12:52:43 -0500 (Thu, 31 Dec 2009)
New Revision: 9645
trunk/msautotest/gdal/tileindex.map
trunk/msautotest/mspython/rqtest.py
added testing of queryByShape with a line (#3248)
Modified: trunk/msautotest/gdal/tileindex.map
--- trunk/msautotest/gdal/tileindex.map 2009-12-31 16:20:14 UTC (rev 9644)
+++ trunk/msautotest/gdal/tileindex.map 2009-12-31 17:52:43 UTC (rev 9645)
@@ -1,6 +1,8 @@
# REQUIRES: SUPPORTS=PROJ
+# This map is also used by ../mspython/rqtest.py
MAP
NAME TEST
Modified: trunk/msautotest/mspython/rqtest.py
--- trunk/msautotest/mspython/rqtest.py 2009-12-31 16:20:14 UTC (rev 9644)
+++ trunk/msautotest/mspython/rqtest.py 2009-12-31 17:52:43 UTC (rev 9645)
@@ -385,6 +385,105 @@
return 'success'
+# Execute a shape query without any tolerance and a line query region.
+def rqtest_9_1():
+ line = mapscript.lineObj()
+ line.add( mapscript.pointObj( 35, 25 ) )
+ line.add( mapscript.pointObj( 45, 25 ) )
+ line.add( mapscript.pointObj( 45, 35 ) )
+ poly = mapscript.shapeObj( mapscript.MS_SHAPE_LINE )
+ poly.add( line )
+ pmstestlib.layer.queryByShape( pmstestlib.map, poly )
+ return 'success'
+# Scan results, checking count and the first shape information.
+def rqtest_9_2():
+ layer = pmstestlib.layer
+ # Check result count.
+ layer.open()
+ count = 0
+ for i in range(1000):
+ result = layer.getResult( i )
+ if result is None:
+ break
+ count = count + 1
+ if count != 47:
+ pmstestlib.post_reason( 'got %d results instead of expected %d.' \
+ % (count, 47) )
+ return 'fail'
+ # Check first shape attributes.
+ result = layer.getResult( 0 )
+ s = layer.getFeature( result.shapeindex, result.tileindex )
+ if pmstestlib.check_items( layer, s,
+ [('value_0','115'),
+ ('red','115'),
+ ('green','115'),
+ ('blue','115'),
+ ('value_list','115'),
+ ('x','39.5'),
+ ('y','29.5')] ) == 0:
+ return 'fail'
+ # Check first shape geometry.
+ if s.type != mapscript.MS_SHAPE_POINT:
+ pmstestlib.post_reason( 'raster query result is not a point.' )
+ return 'fail'
+ if s.numlines != 1:
+ pmstestlib.post_reason( 'raster query has other than 1 lines.' )
+ return 'fail'
+ try:
+ l = s.getLine( 0 )
+ except:
+ l = s.get( 0 )
+ if l.numpoints != 1:
+ pmstestlib.post_reason( 'raster query has other than 1 points.' )
+ return 'fail'
+ try:
+ p = l.getPoint(0)
+ except:
+ p = l.get(0)
+ if p.x != 39.5 or p.y != 29.5:
+ pmstestlib.post_reason( 'got wrong point location.' )
+ return 'fail'
+ # Check last shape attributes.
+ result = layer.getResult( 46 )
+ [('value_0','148'),
+ ('x','44.5'),
+ ('y','24.5')] ) == 0:
+ return 'fail'
+ layer.close()
+ layer.close() # discard resultset.
+ return 'success'
# Close old map, and open a classified map and post a point query.
def rqtest_10():
@@ -579,6 +678,8 @@
rqtest_7,
rqtest_8,
rqtest_9,
+ rqtest_9_1,
+ rqtest_9_2,
rqtest_10,
rqtest_11,
rqtest_12,
More information about the mapserver-commits
