[mapserver-commits] r8489 - trunk/mapserver
Tue Feb 3 15:35:25 EST 2009
Author: tomkralidis
Date: 2009-02-03 15:35:24 -0500 (Tue, 03 Feb 2009)
New Revision: 8489
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/shp2img.c
   trunk/mapserver/shp2pdf.c
fix when layer status = DEFAULT and passing list of layers (#2066)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-02-03 15:04:16 UTC (rev 8488)
+++ trunk/mapserver/HISTORY.TXT	2009-02-03 20:35:24 UTC (rev 8489)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- fix when layer status = DEFAULT and passing list of layers (#2066)
 - Fixed msAddLabel may cause access violation in certain conditions
 - Changed base type of labelObj size, minsize and maxsize from int to double (#2766)
Modified: trunk/mapserver/shp2img.c
--- trunk/mapserver/shp2img.c	2009-02-03 15:04:16 UTC (rev 8488)
+++ trunk/mapserver/shp2img.c	2009-02-03 20:35:24 UTC (rev 8489)
@@ -253,30 +253,38 @@
     if(strcmp(argv[i],"-l") == 0) { /* load layer list */
       layers = msStringSplit(argv[i+1], ' ', &(num_layers));
-      layer_found=0;
+      for(j=0; j<num_layers; j++) { /* loop over -l */
+        layer_found=0;
+        for(k=0; k<map->numlayers; k++) {
+          if(GET_LAYER(map, k)->name && strcmp(GET_LAYER(map, k)->name, layers[j]) == 0) {
+            layer_found=1;
+            break;
+          else {
+            invalid_layer = strdup(layers[j]);
+        if (layer_found==0) {
+          fprintf(stderr, "Layer (-l) %s not found\n", invalid_layer);
+          msCleanup();
+          exit(0);
       for(j=0; j<map->numlayers; j++) {
 	if(GET_LAYER(map, j)->status == MS_DEFAULT)
-	  continue;
+          continue;
 	else {
 	  GET_LAYER(map, j)->status = MS_OFF;
 	  for(k=0; k<num_layers; k++) {
 	    if(GET_LAYER(map, j)->name && strcmp(GET_LAYER(map, j)->name, layers[k]) == 0) {
 	      GET_LAYER(map, j)->status = MS_ON;
-              layer_found=1;
 	      break;
-            else {
-              invalid_layer = strdup(layers[k]);
-      if (layer_found == 0) {
-        fprintf(stderr, "Layer (-l) %s not found\n", invalid_layer);
-        msCleanup();
-        exit(0);
       msFreeCharArray(layers, num_layers);
Modified: trunk/mapserver/shp2pdf.c
--- trunk/mapserver/shp2pdf.c	2009-02-03 15:04:16 UTC (rev 8488)
+++ trunk/mapserver/shp2pdf.c	2009-02-03 20:35:24 UTC (rev 8489)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Commandline shape to pdf converter.
@@ -154,8 +154,25 @@
     if(strncmp(argv[i],"-l",2) == 0) { /* load layer list */
-      layer_found=0;
+        layer_found=0;
+            layer_found=1;
+            break;
+          else {
+          msCleanup();
+          exit(0);
           continue;
@@ -164,21 +181,11 @@
             if(strcmp(GET_LAYER(map, j)->name, layers[k]) == 0) {
-              layer_found=1;
               break;
-            else {
-        msCleanup();
-        exit(0);
       i+=1;
