[mapserver-commits] r8498 - trunk/mapserver
Wed Feb 4 15:39:37 EST 2009
Author: aboudreault
Date: 2009-02-04 15:39:36 -0500 (Wed, 04 Feb 2009)
New Revision: 8498
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwms.c
WMS request with LAYERS parameter: may cause segmentation fault (#2871)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-02-04 16:59:31 UTC (rev 8497)
+++ trunk/mapserver/HISTORY.TXT	2009-02-04 20:39:36 UTC (rev 8498)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- Fixed WMS request with LAYERS parameter: may cause segmentation fault (#2871)
 - fix when layer status = DEFAULT and passing list of layers (#2066)
 - Fixed msAddLabel may cause access violation in certain conditions
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-02-04 16:59:31 UTC (rev 8497)
+++ trunk/mapserver/mapwms.c	2009-02-04 20:39:36 UTC (rev 8498)
@@ -415,6 +415,7 @@
     if (strcasecmp(names[i], "LAYERS") == 0)
       int  j, k, iLayer;
+      int *layerOrder = (int*)malloc(map->numlayers * sizeof(int));
       layers = msStringSplit(values[i], ',', &numlayers);
       if (layers==NULL || strlen(values[i]) <=0 ||   numlayers < 1) {
@@ -425,7 +426,10 @@
       for (iLayer=0; iLayer < map->numlayers; iLayer++)
           map->layerorder[iLayer] = iLayer;
+          layerOrder[iLayer] = 0;
       for(j=0; j<map->numlayers; j++)
@@ -434,7 +438,10 @@
         if (GET_LAYER(map, j)->status != MS_DEFAULT)
            GET_LAYER(map, j)->status = MS_OFF;
         else
            map->layerorder[nLayerOrder++] = j;
+           layerOrder[j] = 1;
       for (k=0; k<numlayers; k++)
@@ -450,8 +457,12 @@
-                      map->layerorder[nLayerOrder++] = j;
-                      GET_LAYER(map, j)->status = MS_ON;
+                     if (layerOrder[j] == 0)
+                        map->layerorder[nLayerOrder++] = j;
+                        GET_LAYER(map, j)->status = MS_ON;
                   validlayers++;
                   layerfound = 1;
@@ -466,9 +477,11 @@
       for (j=0; j<map->numlayers; j++)
          if (GET_LAYER(map, j)->status == MS_OFF)
+      free(layerOrder);
       msFreeCharArray(layers, numlayers);
     else if (strcasecmp(names[i], "STYLES") == 0) {
