[mapserver-commits] r8500 - branches/branch-5-2/mapserver
Wed Feb 4 20:22:59 EST 2009
Author: aboudreault
Date: 2009-02-04 20:22:59 -0500 (Wed, 04 Feb 2009)
New Revision: 8500
   branches/branch-5-2/mapserver/HISTORY.TXT
   branches/branch-5-2/mapserver/mapwms.c
Fixed WMS request with LAYERS parameter: may cause segmentation fault (#2871)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT	2009-02-05 01:04:26 UTC (rev 8499)
+++ branches/branch-5-2/mapserver/HISTORY.TXT	2009-02-05 01:22:59 UTC (rev 8500)
@@ -13,6 +13,8 @@
 Current Version (SVN branch-5-2)
+- Fixed WMS request with LAYERS parameter: may cause segmentation fault (#2871)
 - fix when layer status = DEFAULT and passing list of layers (#2066)
 - Fixed Blobs not filtered in OracleSpatial Attribute/WFS queries (#2829)
Modified: branches/branch-5-2/mapserver/mapwms.c
--- branches/branch-5-2/mapserver/mapwms.c	2009-02-05 01:04:26 UTC (rev 8499)
+++ branches/branch-5-2/mapserver/mapwms.c	2009-02-05 01:22:59 UTC (rev 8500)
@@ -414,7 +414,14 @@
     if (strcasecmp(names[i], "LAYERS") == 0)
-      int  j, k, iLayer;
+      int  j, k, iLayer, *layerOrder;
+      layerOrder = (int*)malloc(map->numlayers * sizeof(int));
+      if (layerOrder == NULL)
+        msSetError(MS_MEMERR, NULL, "msWMSLoadGetMapParams()");
+        return MS_FAILURE;
       layers = msStringSplit(values[i], ',', &numlayers);
       if (layers==NULL || numlayers < 1) {
@@ -425,7 +432,10 @@
       for (iLayer=0; iLayer < map->numlayers; iLayer++)
           map->layerorder[iLayer] = iLayer;
+          layerOrder[iLayer] = 0;
       for(j=0; j<map->numlayers; j++)
@@ -434,7 +444,10 @@
         if (GET_LAYER(map, j)->status != MS_DEFAULT)
            GET_LAYER(map, j)->status = MS_OFF;
         else
            map->layerorder[nLayerOrder++] = j;
+           layerOrder[j] = 1;
       for (k=0; k<numlayers; k++)
@@ -450,8 +463,12 @@
-                      map->layerorder[nLayerOrder++] = j;
-                      GET_LAYER(map, j)->status = MS_ON;
+                     if (layerOrder[j] == 0)
+                        map->layerorder[nLayerOrder++] = j;
+                        GET_LAYER(map, j)->status = MS_ON;
                   validlayers++;
                   layerfound = 1;
@@ -466,9 +483,11 @@
       for (j=0; j<map->numlayers; j++)
          if (GET_LAYER(map, j)->status == MS_OFF)
+      free(layerOrder);
       msFreeCharArray(layers, numlayers);
     else if (strcasecmp(names[i], "STYLES") == 0) {
