[mapserver-commits] r8516 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Feb 7 15:00:14 EST 2009
Author: tomkralidis
Date: 2009-02-07 15:00:14 -0500 (Sat, 07 Feb 2009)
New Revision: 8516
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapogcsos.c
SOS XML validity fixes (#2646)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-02-07 02:20:24 UTC (rev 8515)
+++ trunk/mapserver/HISTORY.TXT 2009-02-07 20:00:14 UTC (rev 8516)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- SOS XML validity fixes (#2646)
- add WFS calls for schema resolution (#2646)
- add gml:id to om:Observation (#2646)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2009-02-07 02:20:24 UTC (rev 8515)
+++ trunk/mapserver/mapogcsos.c 2009-02-07 20:00:14 UTC (rev 8516)
@@ -259,7 +259,7 @@
return psNode;
-void msSOSAddPropertyNode(xmlNsPtr psNsSwe, xmlNsPtr psNsXLink,xmlNodePtr psParent, layerObj *lp, xmlNsPtr psNsGml)
+void msSOSAddPropertyNode(xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, layerObj *lp, xmlNsPtr psNsGml, char *pszCompositePhenomenonId)
const char *pszValue = NULL;
char *pszTmpVal = NULL, *pszFullName = NULL;
@@ -274,10 +274,18 @@
psCompNode = xmlNewChild(psNode, psNsSwe, BAD_CAST "CompositePhenomenon", NULL);
pszValue = msOWSLookupMetadata(&(lp->metadata), "S",
"observedproperty_id");
- if (pszValue)/*should always be true */
- xmlNewNsProp(psCompNode, psNsGml,
- BAD_CAST "id", BAD_CAST pszValue);
+ pszTmpVal = strdup(pszValue);
+ if (pszCompositePhenomenonId != NULL) { /* unique value needs to be constructed */
+ pszTmpVal = msStringConcatenate(pszTmpVal, "_");
+ pszTmpVal = msStringConcatenate(pszTmpVal, pszCompositePhenomenonId);
+ if (pszTmpVal)/*should always be true */ {
+ xmlNewNsProp(psCompNode, psNsGml, BAD_CAST "id", BAD_CAST pszTmpVal);
+ msFree(pszTmpVal);
"observedproperty_name");
if (pszValue)
@@ -347,7 +355,7 @@
/* from gmlWriteGeometry_GML2. Should be merged at one point if */
/* possible. */
-void msSOSAddGeometryNode(xmlNsPtr psNsGml, xmlNodePtr psParent, mapObj *map, layerObj *lp, shapeObj *psShape,
+void msSOSAddGeometryNode(xmlNsPtr psNsGml, xmlNsPtr psNsMs, xmlNodePtr psParent, mapObj *map, layerObj *lp, shapeObj *psShape,
const char *pszEpsg)
char *pszTmp = NULL;
@@ -366,7 +374,7 @@
case(MS_SHAPE_POINT):
psNode = xmlNewChild(psParent, NULL, BAD_CAST "msGeometry", NULL);
- xmlSetNs(psNode,xmlNewNs(psNode, NULL, NULL));
+ xmlSetNs(psNode, psNsMs);
if (psShape->line[0].numpoints > 1)
psPointNode = xmlNewChild(psNode, NULL, BAD_CAST "MultiPoint", NULL);
@@ -641,7 +649,7 @@
/* called on it. */
void msSOSAddMemberNode(xmlNsPtr psNsGml, xmlNsPtr psNsOm, xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNsPtr psNsMs, xmlNodePtr psParent, mapObj *map, layerObj *lp,
- int iFeatureId, char *script_url, char *opLayerName)
+ int iFeatureId, const char *script_url, const char *opLayerName)
xmlNodePtr psObsNode, psNode, psSubNode, psLayerNode = NULL;
const char *pszEpsg = NULL, *pszValue = NULL;
@@ -685,7 +693,6 @@
pszOid = msStringConcatenate(pszOid, "o_");
pszOid = msStringConcatenate(pszOid, sShape.values[j]);
xmlNewNsProp(psObsNode, psNsGml, BAD_CAST "id", BAD_CAST pszOid);
- msFree(pszOid);
@@ -774,13 +781,13 @@
if (pszValue)
- msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lp, psNsGml);
+ msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lp, psNsGml, pszOid);
/*TODO add featureofinterest*/
- pszTmp = msStringConcatenate(pszTmp, script_url);
+ pszTmp = msStringConcatenate(pszTmp, (char *) script_url);
pszTmp = msStringConcatenate(pszTmp, "service=WFS&version=1.1.0&request=DescribeFeatureType&typename=");
- pszTmp = msStringConcatenate(pszTmp, opLayerName);
+ pszTmp = msStringConcatenate(pszTmp, (char *) opLayerName);
psNode = xmlNewChild(psObsNode, psNsOm, BAD_CAST "featureOfInterest", NULL);
xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST pszTmp);
@@ -825,7 +832,7 @@
psNode = xmlAddChild(psLayerNode, msGML3BoundedBy(psNsGml, sShape.bounds.minx, sShape.bounds.miny, sShape.bounds.maxx, sShape.bounds.maxy, pszEpsg));
/*geometry*/
- msSOSAddGeometryNode(psNsGml, psLayerNode, map, lp, &sShape, pszEpsg);
+ msSOSAddGeometryNode(psNsGml, psNsMs, psLayerNode, map, lp, &sShape, pszEpsg);
/*attributes */
/* TODO only output attributes where there is a sos_%s_alias (to be discussed)*/
@@ -984,8 +991,7 @@
/* Add a member node used for getObservation request using */
/* Observation as the result format. */
-xmlNodePtr msSOSAddMemberNodeObservation(xmlNsPtr psNsGml, xmlNsPtr psNsSos, xmlNsPtr psNsOm, xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, mapObj *map,
- layerObj *lp, const char *pszProcedure)
+xmlNodePtr msSOSAddMemberNodeObservation(xmlNsPtr psNsGml, xmlNsPtr psNsSos, xmlNsPtr psNsOm, xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, mapObj *map, layerObj *lp, const char *pszProcedure)
xmlNodePtr psNode=NULL, psObsNode=NULL, psMemberNode=NULL;
@@ -1048,11 +1054,11 @@
if (lp != lpfirst &&
msLayerOpen(lpfirst) == MS_SUCCESS && msLayerGetItems(lpfirst) == MS_SUCCESS)
- msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lpfirst, psNsGml);
+ msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lpfirst, psNsGml, NULL);
msLayerClose(lpfirst);
else
/* result definition*/
psNode = xmlNewChild(psObsNode, NULL, BAD_CAST "resultDefinition", NULL);
@@ -1162,7 +1168,7 @@
char *schemalocation = NULL;
char *xsi_schemaLocation = NULL;
- char *script_url=NULL;
+ const char *script_url=NULL;
const char *updatesequence=NULL;
int i,j,k;
@@ -1312,17 +1318,17 @@
psMainNode = xmlAddChild(psRootNode, msOWSCommonOperationsMetadata(psNsOws));
- psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetCapabilities", OWS_METHOD_GETPOST, script_url));
+ psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetCapabilities", OWS_METHOD_GETPOST, (char *) script_url));
psTmpNode = xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,"Parameter", "service", "SOS"));
psTmpNode = xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,"Parameter", "version", (char *)pszSOSVersion));
- psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"DescribeSensor", OWS_METHOD_GETPOST, script_url));
+ psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"DescribeSensor", OWS_METHOD_GETPOST, (char *) script_url));
psTmpNode = xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,"Parameter", "sensorid", "urn:ogc:object:procedure"));
psTmpNode = xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,"Parameter", "outputFormat", (char *)pszSOSDescribeSensorMimeType));
- psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetObservation", OWS_METHOD_GETPOST, script_url));
+ psNode = xmlAddChild(psMainNode, msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetObservation", OWS_METHOD_GETPOST, (char *) script_url));
psTmpNode = xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,"Parameter", "offering", "urn:ogc:object:offering"));
@@ -1638,7 +1644,7 @@
if (msLayerOpen(lpTmp) == MS_SUCCESS && msLayerGetItems(lpTmp) == MS_SUCCESS)
msSOSAddPropertyNode(psNsSwe, psNsXLink, psOfferingNode,
- lpTmp, psNsGml);
+ lpTmp, psNsGml, NULL);
msLayerClose(lpTmp);
@@ -1705,7 +1711,6 @@
xmlFreeNs(psNsOgc);
xmlFreeNs(psNsSwe);
- free(script_url);
free(xsi_schemaLocation);
free(schemalocation);
@@ -1759,8 +1764,7 @@
const char *pszTmp = NULL, *pszTmp2 = NULL;
const char *user_namespace_uri = "http://mapserver.gis.umn.edu/mapserver";
const char *user_namespace_prefix = "ms";
- char *user_namespace_uri_encoded = NULL;
int i, j, k, bLayerFound = 0;
layerObj *lp = NULL, *lpfirst = NULL;
const char *pszTimeExtent=NULL, *pszTimeField=NULL, *pszValue=NULL;
@@ -1776,8 +1780,10 @@
xmlNsPtr psNsSwe = NULL;
xmlNsPtr psNsXLink = NULL;
xmlNsPtr psNsSos = NULL;
+ xmlNsPtr psNsOws = NULL;
+ xmlNsPtr psNsXsi = NULL;
xmlNsPtr psNsMs = NULL;
- char *opLayerName = NULL;
+ const char *opLayerName = NULL;
char *pszBuffer = NULL;
const char *pszProcedureItem = NULL;
int bSpatialDB = 0;
@@ -1799,18 +1805,10 @@
/* establish local namespace */
pszTmp = msOWSLookupMetadata(&(map->web.metadata), "SFO", "namespace_uri");
if(pszTmp) user_namespace_uri = pszTmp;
- user_namespace_uri_encoded = msEncodeHTMLEntities(user_namespace_uri);
pszTmp = msOWSLookupMetadata(&(map->web.metadata), "SFO", "namespace_prefix");
if(pszTmp) user_namespace_prefix = pszTmp;
- psNsSos = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/sos/1.0", BAD_CAST "sos");
- psNsGml = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml");
- psNsOm = xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix);
- psNsSwe = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/swe/1.0.1", BAD_CAST "swe");
- psNsXLink = xmlNewNs(NULL, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
- psNsMs = xmlNewNs(NULL, BAD_CAST user_namespace_uri_encoded, BAD_CAST user_namespace_prefix);
/* validates mandatory request elements */
if (!sosparams->pszOffering) {
msSetError(MS_SOSERR, "Missing OFFERING parameter.", "msSOSGetObservation()");
@@ -1869,7 +1867,8 @@
for (j=0; j<n; j++) {
if(strcasecmp(pszTmp2, tokens[j]) == 0) {
GET_LAYER(map, i)->status = MS_ON;
- opLayerName = strdup(GET_LAYER(map, i)->name);
+ //opLayerName = strdup(GET_LAYER(map, i)->name);
+ opLayerName = GET_LAYER(map, i)->name;
/* Force setting a template to enable query. */
if (!GET_LAYER(map, i)->template)
GET_LAYER(map, i)->template = strdup("ttt.html");
@@ -2298,16 +2297,27 @@
/* build xml return tree*/
+ psNsSos = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/sos/1.0", BAD_CAST "sos");
+ psNsGml = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml");
+ psNsOm = xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix);
+ psNsOws = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/ows/1.1", BAD_CAST "ows");
+ psNsSwe = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/swe/1.0.1", BAD_CAST "swe");
+ psNsXLink = xmlNewNs(NULL, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
+ psNsXsi = xmlNewNs(NULL, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX);
+ psNsMs = xmlNewNs(NULL, BAD_CAST user_namespace_uri, BAD_CAST user_namespace_prefix);
psDoc = xmlNewDoc(BAD_CAST "1.0");
psRootNode = xmlNewNode(NULL, BAD_CAST "ObservationCollection");
xmlDocSetRootElement(psDoc, psRootNode);
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml"));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/ows/1.1", BAD_CAST "ows"));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/swe/1.0.1", BAD_CAST "swe"));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST pszSOSNamespaceUri, BAD_CAST pszSOSNamespacePrefix));
- xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST user_namespace_uri_encoded, BAD_CAST user_namespace_prefix));
+ xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST user_namespace_uri, BAD_CAST user_namespace_prefix));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/om/1.0", BAD_CAST "om"));
xmlNewNsProp(psRootNode, psNsGml, BAD_CAST "id", BAD_CAST sosparams->pszOffering);
@@ -2320,9 +2330,9 @@
xsi_schemaLocation = strdup("http://www.opengis.net/om/1.0 ");
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, schemalocation);
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "/om/1.0.0/om.xsd ");
- xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, user_namespace_uri_encoded);
+ xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, (char *) user_namespace_uri);
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, " ");
- xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, script_url);
+ xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, (char *) script_url);
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "service=WFS&version=1.1.0&request=DescribeFeatureType&typename=");
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, (char *) opLayerName);
xmlNewNsProp(psRootNode, NULL, BAD_CAST "xsi:schemaLocation", BAD_CAST xsi_schemaLocation);
@@ -2433,7 +2443,6 @@
if (j == n1-1)
break;
- msFree(opLayerName);
else /*assuming here that pszResultModel = observation */
@@ -2700,17 +2709,59 @@
-/* msSOSDescribeObsrvationType */
+/* msSOSDescribeObservationType */
-/* DescribeObservationType request handler */
+/* DescribeObserrvationType request handler */
-int msSOSDescribeObservationType(mapObj *map, sosParamsObj *sosparams) {
+int msSOSDescribeObservationType(mapObj *map, sosParamsObj *sosparams, cgiRequestObj *req) {
+ int i, j, n = 0, bLayerFound = 0;
+ char **tokens = NULL;
+ const char *pszTmp = NULL;
+ char *pszTmp2=NULL;
if (!sosparams->pszObservedProperty) {
msSetError(MS_SOSERR, "Missing mandatory parameter observedproperty", "msSOSDescribeObservationType()");
return msSOSException(map, "observedproperty", "MissingParameterValue");
- msSetError(MS_SOSERR, "Not yet implemented", "msSOSDescribeObservationType()");
- return msSOSException(map, "mapserv", "NoApplicableCode");
+ tokens = msStringSplit(sosparams->pszObservedProperty, ',', &n);
+ for (i=0; i<map->numlayers; i++) {
+ pszTmp = msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), "S", "observedproperty_id");
+ if (pszTmp) {
+ if (strcasecmp(pszTmp, sosparams->pszObservedProperty) == 0) {
+ if (tokens && n > 0) {
+ for (j=0; j<n; j++) {
+ if(strcasecmp(pszTmp, tokens[j]) == 0) {
+ bLayerFound = 1;
+ break;
+ msFreeCharArray(tokens, n);
+ if (bLayerFound == 0) {
+ msSetError(MS_SOSERR, "ObservedProperty %s not found.", "msSOSGetObservation()", sosparams->pszObservedProperty);
+ return msSOSException(map, "observedproperty", "InvalidParameterValue");
+ if ((script_url=msOWSGetOnlineResource(map, "SO", "onlineresource", req)) == NULL)
+ return msSOSException(map, "NoApplicableCode", "NoApplicableCode");
+ pszTmp2 = msStringConcatenate(pszTmp2, (char *) script_url);
+ pszTmp2 = msStringConcatenate(pszTmp2, "service=WFS&version=1.1.0&request=DescribeFeatureType&typename=");
+ pszTmp2 = msStringConcatenate(pszTmp2, (char *) opLayerName);
+ msIO_printf("Location: %s\n\n", pszTmp2);
+ msFree(pszTmp2);
+ return(MS_SUCCESS);
@@ -2775,7 +2826,7 @@
returnvalue = msSOSGetObservation(map, paramsObj, req);
else if (strcasecmp(paramsObj->pszRequest, "DescribeObservationType") == 0)
- returnvalue = msSOSDescribeObservationType(map, paramsObj);
+ returnvalue = msSOSDescribeObservationType(map, paramsObj, req);
msSOSFreeParamsObj(paramsObj);
free(paramsObj);
More information about the mapserver-commits
