[mapserver-commits] r8522 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 9 13:26:50 EST 2009
Author: aboudreault
Date: 2009-02-09 13:26:49 -0500 (Mon, 09 Feb 2009)
New Revision: 8522
branches/branch-5-2/mapserver/HISTORY.TXT
branches/branch-5-2/mapserver/mapfile.c
Fixed memory leaks when using msUpdate*FromString methods. (#2857)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT 2009-02-09 18:24:43 UTC (rev 8521)
+++ branches/branch-5-2/mapserver/HISTORY.TXT 2009-02-09 18:26:49 UTC (rev 8522)
@@ -13,6 +13,8 @@
Current Version (SVN branch-5-2)
+- Fixed memory leaks when using msUpdate*FromString methods. (#2857)
- Fixed endianness issues with wide character strings for ArcSDE (#2878).
Thanks Russell McOrmond
Modified: branches/branch-5-2/mapserver/mapfile.c
--- branches/branch-5-2/mapserver/mapfile.c 2009-02-09 18:24:43 UTC (rev 8521)
+++ branches/branch-5-2/mapserver/mapfile.c 2009-02-09 18:26:49 UTC (rev 8522)
@@ -1251,6 +1251,8 @@
if(symbol == MS_NUMBER)
label->angle = msyynumber;
else if(symbol == MS_BINDING) {
+ if (label->bindings[MS_LABEL_BINDING_ANGLE].item != NULL)
+ msFree(label->bindings[MS_LABEL_BINDING_ANGLE].item);
label->bindings[MS_LABEL_BINDING_ANGLE].item = strdup(msyytext);
label->numbindings++;
} else if ( symbol == MS_FOLLOW ) {
@@ -1305,8 +1307,12 @@
return(-1);
if(symbol == MS_STRING) {
+ if (label->font != NULL)
+ msFree(label->font);
label->font = strdup(msyytext);
} else {
+ if (label->bindings[MS_LABEL_BINDING_FONT].item != NULL)
+ msFree(label->bindings[MS_LABEL_BINDING_FONT].item);
label->bindings[MS_LABEL_BINDING_FONT].item = strdup(msyytext);
@@ -1367,7 +1373,9 @@
return(-1);
} else {
- label->bindings[MS_LABEL_BINDING_PRIORITY].item = strdup(msyytext);
+ if (label->bindings[MS_LABEL_BINDING_PRIORITY].item != NULL)
+ msFree(label->bindings[MS_LABEL_BINDING_PRIORITY].item);
+ label->bindings[MS_LABEL_BINDING_PRIORITY].item = strdup(msyytext);
break;
@@ -1386,6 +1394,8 @@
if(symbol == MS_NUMBER) {
label->size = (int) msyynumber;
} else if(symbol == MS_BINDING) {
+ if (label->bindings[MS_LABEL_BINDING_SIZE].item != NULL)
+ msFree(label->bindings[MS_LABEL_BINDING_SIZE].item);
label->bindings[MS_LABEL_BINDING_SIZE].item = strdup(msyytext);
} else
@@ -1534,6 +1544,8 @@
int loadExpression(expressionObj *exp)
if((exp->type = getSymbol(5, MS_STRING,MS_EXPRESSION,MS_REGEX,MS_ISTRING,MS_IREGEX)) == -1) return(-1);
+ if (exp->string != NULL)
+ msFree(exp->string);
exp->string = strdup(msyytext);
if(exp->type == MS_ISTRING)
@@ -1796,6 +1808,8 @@
style->angle = (double) msyynumber;
else {
+ if (style->bindings[MS_STYLE_BINDING_ANGLE].item != NULL)
+ msFree(style->bindings[MS_STYLE_BINDING_ANGLE].item);
style->bindings[MS_STYLE_BINDING_ANGLE].item = strdup(msyytext);
style->numbindings++;
@@ -1856,6 +1870,8 @@
style->size = (int) msyynumber;
else {
+ if (style->bindings[MS_STYLE_BINDING_SIZE].item != NULL)
+ msFree(style->bindings[MS_STYLE_BINDING_SIZE].item);
style->bindings[MS_STYLE_BINDING_SIZE].item = strdup(msyytext);
@@ -1867,8 +1883,14 @@
style->symbol = (int) msyynumber;
else if(symbol == MS_STRING)
- style->symbolname = strdup(msyytext);
+ if (style->symbolname != NULL)
+ msFree(style->symbolname);
+ style->symbolname = strdup(msyytext);
else {
+ if (style->bindings[MS_STYLE_BINDING_SYMBOL].item != NULL)
+ msFree(style->bindings[MS_STYLE_BINDING_SYMBOL].item);
style->bindings[MS_STYLE_BINDING_SYMBOL].item = strdup(msyytext);
@@ -2015,7 +2037,8 @@
* to msGrowClassStyles()
class->numstyles = 0;
- class->maxstyles = 0;
+ class->maxstyles = 0;
class->styles = NULL;
class->keyimage = NULL;
@@ -2287,8 +2310,12 @@
if(state == MS_NUMBER)
class->styles[0]->symbol = (int) msyynumber;
else
+ if (class->styles[0]->symbolname != NULL)
+ msFree(class->styles[0]->symbolname);
class->styles[0]->symbolname = strdup(msyytext);
- class->numstyles = 1;
+ class->numstyles = 1;
break;
@@ -2325,8 +2352,12 @@
if((state = getSymbol(2, MS_NUMBER,MS_STRING)) == -1) return(-1);
class->styles[1]->symbol = (int) msyynumber;
- else
+ else
+ if (class->styles[1]->symbolname != NULL)
+ msFree(class->styles[1]->symbolname);
class->styles[1]->symbolname = strdup(msyytext);
class->numstyles = 2;
break;
default:
@@ -3135,7 +3166,11 @@
ref->marker = (int) msyynumber;
else
+ if (ref->markername != NULL)
+ msFree(ref->markername);
ref->markername = strdup(msyytext);
break;
case(MARKERSIZE):
if(getInteger(&(ref->markersize)) == -1) return(-1);
More information about the mapserver-commits
