[mapserver-commits] r8530 - trunk/mapserver
Wed Feb 11 23:41:24 EST 2009
Author: sdlime
Date: 2009-02-11 23:41:24 -0500 (Wed, 11 Feb 2009)
New Revision: 8530
   trunk/mapserver/maptemplate.c
Applied patch to all projection of [...ext] tags in template output.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2009-02-12 00:00:58 UTC (rev 8529)
+++ trunk/mapserver/maptemplate.c	2009-02-12 04:41:24 UTC (rev 8530)
@@ -1247,11 +1247,8 @@
 ** Function process any number of MapServer extent tags (e.g. shpext, mapext, etc...).
-** TODO: Add projection support (see shpxy tag).
-**       Allow percentage expansion (e.g. 10%).
-static int processExtentTag(mapservObj *mapserv, char **line, char *name, rectObj *extent)
+static int processExtentTag(mapservObj *mapserv, char **line, char *name, rectObj *extent, projectionObj *rectProj)
   char *argValue;
@@ -1271,6 +1268,8 @@
   int precision=-1;
   int escape=ESCAPE_HTML;
+  char *projectionString=NULL;
   if(!*line) {
     msSetError(MS_WEBERR, "Invalid line pointer.", "processExtentTag()");
     return(MS_FAILURE);
@@ -1312,6 +1311,9 @@
       argValue = msLookupHashTable(tagArgs, "precision");
       if(argValue) precision = atoi(argValue);
+      argValue = msLookupHashTable(tagArgs, "proj");
+      if(argValue) projectionString = argValue;
     tempExtent.minx = extent->minx - xExpand;
@@ -1319,6 +1321,29 @@
     tempExtent.maxx = extent->maxx + xExpand;
     tempExtent.maxy = extent->maxy + yExpand;
+    /* no big deal to convert from file to image coordinates, but what are the image parameters */
+    if(rectProj && projectionString && strcasecmp(projectionString,"image") == 0) {
+      precision = 0;
+      /* if necessary, project the shape to match the map */
+      if(msProjectionsDiffer(rectProj, &(mapserv->map->projection)))
+        msProjectRect(rectProj, &mapserv->map->projection, &tempExtent);
+      /* convert tempExtent to image coordinates based on the map extent and cellsize */
+      tempExtent.minx = MS_MAP2IMAGE_X(tempExtent.minx, mapserv->map->extent.minx, mapserv->map->cellsize);
+      tempExtent.miny = MS_MAP2IMAGE_Y(tempExtent.miny, mapserv->map->extent.maxy, mapserv->map->cellsize);
+      tempExtent.maxx = MS_MAP2IMAGE_X(tempExtent.minx, mapserv->map->extent.minx, mapserv->map->cellsize);
+      tempExtent.maxy = MS_MAP2IMAGE_Y(tempExtent.miny, mapserv->map->extent.maxy, mapserv->map->cellsize);
+    } else if(rectProj && projectionString) {
+       projectionObj projection;
+       msInitProjection(&projection);
+       if(MS_SUCCESS != msLoadProjectionString(&projection, projectionString)) return MS_FAILURE;
+       if(msProjectionsDiffer(rectProj, &projection))
+         msProjectRect(rectProj, &projection, &tempExtent);
     tagValue = strdup(format);
     if(precision != -1)
@@ -3114,9 +3139,9 @@
   sprintf(repstr, "%f", mapserv->map->extent.maxy);
   outstr = msReplaceSubstring(outstr, "[maxy]", repstr);
-  if(processExtentTag(mapserv, &outstr, "mapext", &(mapserv->map->extent)) != MS_SUCCESS)
+  if(processExtentTag(mapserv, &outstr, "mapext", &(mapserv->map->extent), &(mapserv->map->projection)) != MS_SUCCESS)
     return(NULL);
-  if(processExtentTag(mapserv, &outstr, "mapext_esc", &(mapserv->map->extent)) != MS_SUCCESS) /* depricated */
+  if(processExtentTag(mapserv, &outstr, "mapext_esc", &(mapserv->map->extent), &(mapserv->map->projection)) != MS_SUCCESS) /* depricated */
     return(NULL);
   sprintf(repstr, "%f", (mapserv->map->extent.maxx-mapserv->map->extent.minx)); /* useful for creating cachable extents (i.e. 0 0 dx dy) with legends and scalebars */
@@ -3133,9 +3158,9 @@
   sprintf(repstr, "%f", mapserv->RawExt.maxy);
   outstr = msReplaceSubstring(outstr, "[rawmaxy]", repstr);
-  if(processExtentTag(mapserv, &outstr, "rawext", &(mapserv->RawExt)) != MS_SUCCESS)
+  if(processExtentTag(mapserv, &outstr, "rawext", &(mapserv->RawExt), &(mapserv->map->projection)) != MS_SUCCESS)
     return(NULL);
-  if(processExtentTag(mapserv, &outstr, "rawext_esc", &(mapserv->RawExt)) != MS_SUCCESS) /* depricated */
+  if(processExtentTag(mapserv, &outstr, "rawext_esc", &(mapserv->RawExt), &(mapserv->map->projection)) != MS_SUCCESS) /* depricated */
     return(NULL);
 #ifdef USE_PROJ
@@ -3161,9 +3186,9 @@
     sprintf(repstr, "%f", llextent.maxy);
     outstr = msReplaceSubstring(outstr, "[maxlat]", repstr);
-    if(processExtentTag(mapserv, &outstr, "mapext_latlon", &(llextent)) != MS_SUCCESS)
+    if(processExtentTag(mapserv, &outstr, "mapext_latlon", &(llextent), NULL) != MS_SUCCESS)
       return(NULL);
-    if(processExtentTag(mapserv, &outstr, "mapext_latlon_esc", &(llextent)) != MS_SUCCESS) /* depricated */
+    if(processExtentTag(mapserv, &outstr, "mapext_latlon_esc", &(llextent), NULL) != MS_SUCCESS) /* depricated */
       return(NULL);
 #endif
@@ -3179,9 +3204,9 @@
     sprintf(repstr, "%f", mapserv->map->reference.extent.maxy);
     outstr = msReplaceSubstring(outstr, "[refmaxy]", repstr);
-    if(processExtentTag(mapserv, &outstr, "refext", &(mapserv->map->reference.extent)) != MS_SUCCESS)
+    if(processExtentTag(mapserv, &outstr, "refext", &(mapserv->map->reference.extent), &(mapserv->map->projection)) != MS_SUCCESS)
       return(NULL);
-    if(processExtentTag(mapserv, &outstr, "refext_esc", &(mapserv->map->reference.extent)) != MS_SUCCESS) /* depricated */
+    if(processExtentTag(mapserv, &outstr, "refext_esc", &(mapserv->map->reference.extent), &(mapserv->map->projection)) != MS_SUCCESS) /* depricated */
       return(NULL);
@@ -3265,9 +3290,9 @@
     sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
     outstr = msReplaceSubstring(outstr, "[shpmidy]", repstr);
-    if(processExtentTag(mapserv, &outstr, "shpext", &(mapserv->resultshape.bounds)) != MS_SUCCESS)
+    if(processExtentTag(mapserv, &outstr, "shpext", &(mapserv->resultshape.bounds), &(mapserv->resultlayer->projection)) != MS_SUCCESS)
       return(NULL);
-    if(processExtentTag(mapserv, &outstr, "shpext_esc", &(mapserv->resultshape.bounds)) != MS_SUCCESS) /* depricated */
+    if(processExtentTag(mapserv, &outstr, "shpext_esc", &(mapserv->resultshape.bounds), &(mapserv->resultlayer->projection)) != MS_SUCCESS) /* depricated */
       return(NULL);
     sprintf(repstr, "%d", mapserv->resultshape.classindex);
