[mapserver-commits] r8555 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Feb 15 12:43:35 EST 2009
Author: tamas
Date: 2009-02-15 12:43:35 -0500 (Sun, 15 Feb 2009)
New Revision: 8555
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscale.c
Fixed a scalebar rounding problem causing to draw zero scalebar width (#2890)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-02-15 14:28:20 UTC (rev 8554)
+++ trunk/mapserver/HISTORY.TXT 2009-02-15 17:43:35 UTC (rev 8555)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- Fixed a scalebar rounding problem causing to draw zero scalebar width (#2890)
- SLD: if it conatins a Filer Encoding tag, try to always set the
layer's FILTER element (#2889)
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c 2009-02-15 14:28:20 UTC (rev 8554)
+++ trunk/mapserver/mapscale.c 2009-02-15 17:43:35 UTC (rev 8555)
@@ -63,6 +63,10 @@
return(MS_NINT(d/1000) * 1000);
if(d<1000000)
return(MS_NINT(d/10000) * 10000);
+ if(d<10000000)
+ return(MS_NINT(d/100000) * 100000);
+ if(d<100000000)
+ return(MS_NINT(d/1000000) * 1000000);
return(-1);
More information about the mapserver-commits
