[mapserver-commits] r8559 - trunk/mapserver
Mon Feb 16 13:04:25 EST 2009
Author: assefa
Date: 2009-02-16 13:04:25 -0500 (Mon, 16 Feb 2009)
New Revision: 8559
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapwms.c
add wms 1.3.0 auto2 proj support #473
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2009-02-16 13:25:30 UTC (rev 8558)
+++ trunk/mapserver/mapfile.c	2009-02-16 18:04:25 UTC (rev 8559)
@@ -875,20 +875,32 @@
     /* WMS/WFS AUTO projection: "AUTO:proj_id,units_id,lon0,lat0" */
     args = msStringSplit(p->args[0], ',', &numargs);
-    if (numargs != 4 || strncasecmp(args[0], "AUTO:", 5) != 0)
+    if (numargs != 4 ||
+        (strncasecmp(args[0], "AUTO:", 5) != 0 &&
+         strncasecmp(args[0], "AUTO2:", 6) != 0))
         msSetError(MS_PROJERR,
-                   "WMS/WFS AUTO PROJECTION must be in the format "
-                   "'AUTO:proj_id,units_id,lon0,lat0' (got '%s').\n",
+                   "WMS/WFS AUTO/AUTO2 PROJECTION must be in the format "
+                   "'AUTO:proj_id,units_id,lon0,lat0' or 'AUTO2:crs_id,factor,lon0,lat0'(got '%s').\n",
                    "_msProcessAutoProjection()", p->args[0]);
         return -1;
-    nProjId = atoi(args[0]+5);
+    if (strncasecmp(args[0], "AUTO:", 5)==0)
+      nProjId = atoi(args[0]+5);
+    else
+      nProjId = atoi(args[0]+6);
     nUnitsId = atoi(args[1]);
     dLon0 = atof(args[2]);
     dLat0 = atof(args[3]);
+    /*There is no unit parameter for AUTO2. The 2nd parameter is
+     factor. Set the units to always be meter*/
+    if (strncasecmp(args[0], "AUTO2:", 6) == 0)
+      nUnitsId = 9001;
     msFreeCharArray(args, numargs);
     /* Handle EPSG Units.  Only meters for now. */
@@ -998,9 +1010,11 @@
         return 0;
-    if (strncasecmp(p->args[0], "AUTO:", 5) == 0)
+    if (strncasecmp(p->args[0], "AUTO:", 5) == 0 ||
+        strncasecmp(p->args[0], "AUTO2:", 6) == 0)
+        /*WMS 1.3.0: AUTO2:auto_crs_id,factor,lon0,lat0*/
         return _msProcessAutoProjection(p);
     msAcquireLock( TLOCK_PROJ );
@@ -1147,11 +1161,13 @@
       p->args = msStringSplit(trimmed,'+', &p->numargs);
       free( trimmed );
-  else if (strncasecmp(value, "AUTO:", 5) == 0)
+  else if (strncasecmp(value, "AUTO:", 5) == 0 ||
+           strncasecmp(value, "AUTO2:", 6) == 0)
-      /* WMS/WFS AUTO projection: "AUTO:proj_id,units_id,lon0,lat0" */
-      /* Keep the projection defn into a single token for writeProjection() */
-      /* to work fine. */
+     /* WMS/WFS AUTO projection: "AUTO:proj_id,units_id,lon0,lat0" */
+     /* WMS 1.3.0 projection: "AUTO2:auto_crs_id,factor,lon0,lat0"*/
+     /* Keep the projection defn into a single token for writeProjection() */
+     /* to work fine. */
       p->args = (char**)malloc(sizeof(char*));
       p->args[0] = strdup(value);
       p->numargs = 1;
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-02-16 13:25:30 UTC (rev 8558)
+++ trunk/mapserver/mapwms.c	2009-02-16 18:04:25 UTC (rev 8559)
@@ -711,6 +711,28 @@
             msFreeProjection( &proj );
+       /*if the CRS is AUTO2:auto_crs_id,factor,lon0,lat0,
+        we need to grab the factor patameter and use it with the bbox*/
+       if (strlen(srsbuffer) > 1 && strncasecmp(srsbuffer, "AUTO2:", 6) == 0)
+           char **args;
+           int numargs;
+           double factor;
+           args = msStringSplit(srsbuffer, ',', &numargs);
+           if (numargs == 4)
+               factor = atof(args[1]);
+               if (factor > 0 && factor != 1.0)
+                   rect.minx = rect.minx*factor;
+                   rect.miny = rect.miny*factor;
+                   rect.maxx = rect.maxx*factor;
+                   rect.maxx = rect.maxy*factor;
+           msFreeCharArray(args, numargs);
        map->extent.minx = rect.minx;
        map->extent.miny = rect.miny;
        map->extent.maxx = rect.maxx;
