[mapserver-commits] r8573 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Feb 18 00:40:39 EST 2009
Author: sdlime
Date: 2009-02-18 00:40:39 -0500 (Wed, 18 Feb 2009)
New Revision: 8573
trunk/mapserver/mapserv.c
Allow setting qstring validation via the VALIDATION hash.
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2009-02-18 05:19:18 UTC (rev 8572)
+++ trunk/mapserver/mapserv.c 2009-02-18 05:40:39 UTC (rev 8573)
@@ -209,7 +209,7 @@
/* services can take advantage of these "vendor specific" extensions */
for(i=0;i<mapserv->request->NumParams;i++) {
- ** a few CGI variables should be skipped altogether
+ ** a few CGI variables should be skipped altogether
** qstring: there is separate per layer validation for attribute queries and the substitution checks
** below conflict with that so we avoid it here
@@ -1111,7 +1111,7 @@
int main(int argc, char *argv[]) {
int i,j, iArg;
- char buffer[1024], *value=NULL;
+ char buffer[1024];
imageObj *img=NULL;
int status;
int sendheaders = MS_TRUE;
@@ -1539,15 +1539,12 @@
GET_LAYER(mapserv->map, SelectLayerIndex)->status = MS_ON;
- value = msLookupHashTable(&(GET_LAYER(mapserv->map, SelectLayerIndex)->metadata), "qstring_validation_pattern");
- if(value) { /* validate qstring value */
- if(msEvalRegex(value, QueryString) == MS_FALSE) {
- msSetError(MS_WEBERR, "Parameter 'qstring' value fails to validate.", "mapserv()");
- writeError();
- } else { /* throw an error since a validation pattern is required */
- msSetError(MS_WEBERR, "Metadata qstring_validation_pattern is not set.", "mapserv()");
- writeError();
+ /* validate the qstring parameter */
+ if(msValidateParameter(QueryString, msLookupHashTable(&(GET_LAYER(mapserv->map, SelectLayerIndex)->validation), "qstring"),
+ msLookupHashTable(&(mapserv->map->web.validation), "qstring"),
+ msLookupHashTable(&(GET_LAYER(mapserv->map, SelectLayerIndex)->metadata), "qstring_validation_pattern"), NULL) != MS_SUCCESS) {
+ msSetError(MS_WEBERR, "Parameter 'qstring' value fails to validate.", "mapserv()");
+ writeError();
if(QueryCoordSource != NONE && !mapserv->UseShapes)
@@ -1621,14 +1618,11 @@
writeError();
- value = msLookupHashTable(&(GET_LAYER(mapserv->map, QueryLayerIndex)->metadata), "qstring_validation_pattern");
- writeError();
+ if(msValidateParameter(QueryString, msLookupHashTable(&(GET_LAYER(mapserv->map, QueryLayerIndex)->validation), "qstring"),
+ msLookupHashTable(&(GET_LAYER(mapserv->map, QueryLayerIndex)->metadata), "qstring_validation_pattern"), NULL) != MS_SUCCESS) {
writeError();
More information about the mapserver-commits
