[mapserver-commits] r8580 - trunk/docs/mapfile
svn at osgeo.org
svn at osgeo.org
Wed Feb 18 17:03:28 EST 2009
Author: jmckenna
Date: 2009-02-18 17:03:28 -0500 (Wed, 18 Feb 2009)
New Revision: 8580
trunk/docs/mapfile/label.txt
add position cc for polygons (ticket:2770)
Modified: trunk/docs/mapfile/label.txt
--- trunk/docs/mapfile/label.txt 2009-02-18 21:42:51 UTC (rev 8579)
+++ trunk/docs/mapfile/label.txt 2009-02-18 22:03:28 UTC (rev 8580)
@@ -171,12 +171,13 @@
Position of the label relative to the labeling point (layers only). First
letter is "Y" position, second letter is "X" position. "Auto" tells
MapServer to calculate a label position that will not interfere with other
- labels. With points and polygons, MapServer selects from the 8 outer
- positions (i.e. excluding cc). With lines, it only uses lc or uc, until it
- finds a position that doesn't collide with labels that have already been
- drawn. If all positions cause a conflict, then the label is not drawn
- (Unless the label's FORCE_ a parameter is set to "true"). "Auto" placement
- is only available with cached labels.
+ labels. With points, MapServer selects from the 8 outer
+ positions (i.e. excluding cc). With polygons, MapServer selects from
+ cc, uc, lc, cl and cr as possible positions. With lines, it only uses
+ lc or uc, until it finds a position that doesn't collide with labels that
+ have already been drawn. If all positions cause a conflict, then the
+ label is not drawn (Unless the label's FORCE_ a parameter is set to "true").
+ "Auto" placement is only available with cached labels.
PRIORITY [integer]|[item_name]
The priority parameter (added in v5.0) takes an integer value between 1
More information about the mapserver-commits
