[mapserver-commits] r8598 - trunk/docs/utilities
Thu Feb 19 12:48:05 EST 2009
Author: jmckenna
Date: 2009-02-19 12:48:04 -0500 (Thu, 19 Feb 2009)
New Revision: 8598
   trunk/docs/utilities/shptree.txt
add mapfile code block to improve appearance
Modified: trunk/docs/utilities/shptree.txt
--- trunk/docs/utilities/shptree.txt	2009-02-19 15:10:12 UTC (rev 8597)
+++ trunk/docs/utilities/shptree.txt	2009-02-19 17:48:04 UTC (rev 8598)
@@ -63,17 +63,17 @@
 in the DATA path of the LAYER.  In fact, in order for MapServer to use the *.qix*
 extension you MUST NOT specify the extension, for example:
+.. code-block:: mapfile
     LAYER
-      DATA us_states    #MapServer will search for us_states.qix and will use it
+      DATA "us_states"    #MapServer will search for us_states.qix and will use it
     END
     LAYER
-      DATA us_states.shp    #MapServer will search for us_states.shp.qix and won't find it
+      DATA "us_states.shp"    #MapServer will search for us_states.shp.qix and won't find it
     END
