[mapserver-commits] r8622 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Feb 26 08:50:14 EST 2009
Author: assefa
Date: 2009-02-26 08:50:14 -0500 (Thu, 26 Feb 2009)
New Revision: 8622
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapogcsld.c
Fix build problem with mapogcsld.c when ows services are not available
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-02-26 12:55:04 UTC (rev 8621)
+++ trunk/mapserver/HISTORY.TXT 2009-02-26 13:50:14 UTC (rev 8622)
@@ -12,6 +12,8 @@
Current Version (SVN trunk):
+- Fix build problem with mapogcsld.c when OWS services are not available (#473)
- Fix build on windows (maputil.c)
Version 5.4.0-beta2 (2009-2-25):
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c 2009-02-26 12:55:04 UTC (rev 8621)
+++ trunk/mapserver/mapogcsld.c 2009-02-26 13:50:14 UTC (rev 8622)
@@ -3311,6 +3311,8 @@
char *msSLDGetGraphicSLD(styleObj *psStyle, layerObj *psLayer,
int bNeedMarkSybol, int nVersion)
+#if defined(USE_WMS_SVR) || defined (USE_WFS_SVR) || defined (USE_WCS_SVR) || defined(USE_SOS_SVR)
char *pszSLD = NULL;
int nSymbol = -1;
symbolObj *psSymbol = NULL;
@@ -3651,6 +3653,12 @@
return pszSLD;
+#else
+ return NULL;
+#endif
@@ -3663,6 +3671,8 @@
char *msSLDGenerateLineSLD(styleObj *psStyle, layerObj *psLayer, int nVersion)
char szTmp[100];
char szHexColor[7];
@@ -3785,6 +3795,9 @@
return pszSLD;
+#else
+ return NULL;
+#endif
@@ -3795,6 +3808,8 @@
char *msSLDGeneratePolygonSLD(styleObj *psStyle, layerObj *psLayer, int nVersion)
char szTmp[100];
char szHexColor[7];
@@ -3918,6 +3933,10 @@
pszSLD = msStringConcatenate(pszSLD, szTmp);
return pszSLD;
+#else
+ return NULL;
+#endif
@@ -3927,6 +3946,7 @@
char *msSLDGeneratePointSLD(styleObj *psStyle, layerObj *psLayer, int nVersion)
char *pszGraphicSLD = NULL;
char szTmp[100];
@@ -3950,6 +3970,11 @@
return pszSLD;
+#else
+ return NULL;
+#endif
@@ -3962,6 +3987,7 @@
char *msSLDGenerateTextSLD(classObj *psClass, layerObj *psLayer, int nVersion)
char szTmp[100];
@@ -4190,6 +4216,9 @@
return pszSLD;
+#else
+ return NULL;
+#endif
More information about the mapserver-commits
