[mapserver-commits] r8376 - trunk/docs/ogc
Fri Jan 2 10:13:17 EST 2009
Author: tomkralidis
Date: 2009-01-02 10:13:17 -0500 (Fri, 02 Jan 2009)
New Revision: 8376
   trunk/docs/ogc/wfs_server.txt
remove mime type info, WFS always returns text/xml
Modified: trunk/docs/ogc/wfs_server.txt
--- trunk/docs/ogc/wfs_server.txt	2009-01-02 15:12:14 UTC (rev 8375)
+++ trunk/docs/ogc/wfs_server.txt	2009-01-02 15:13:17 UTC (rev 8376)
@@ -224,10 +224,6 @@
 http://www2.dmsolutions.ca/cgi-bin/mswfs_gmap?SERVICE=WFS&VERSION=1.0.0&REQUEST=getcapabilities
-This should return a document of MIME type application/vnd.ogc.wfs_xml, so your
-browser is likely going to prompt you to save the file. Save it and open it in a
-text editor (Emacs, Notepad, etc.)
 If everything went well, you should have a complete XML capabilities document.
 Search it for the word "WARNING"... MapServer inserts XML comments starting
 with "<!--WARNING: " in the XML output if it detects missing mapfile parameters
