[mapserver-commits] r8389 - in trunk/mapserver: . mapscript/php3
mapscript/python/tests/cases mapscript/swiginc
svn at osgeo.org
svn at osgeo.org
Tue Jan 6 10:27:12 EST 2009
Author: aboudreault
Date: 2009-01-06 10:27:12 -0500 (Tue, 06 Jan 2009)
New Revision: 8389
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/php3/mapscript_i.c
trunk/mapserver/mapscript/php3/php_mapscript.c
trunk/mapserver/mapscript/php3/php_mapscript.h
trunk/mapserver/mapscript/python/tests/cases/maptest.py
trunk/mapserver/mapscript/swiginc/projection.i
Added getUnits() methods to projectionObj in Mapscript (#2798)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/HISTORY.TXT 2009-01-06 15:27:12 UTC (rev 8389)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- Added getUnits() methods to projectionObj in Mapscript (#2798)
- Improved Tag parsing in template code. (#2781)
- Added hashtable object and metadata methods for php-mapscript (#2773)
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c 2009-01-06 15:27:12 UTC (rev 8389)
@@ -1169,6 +1169,10 @@
return proj;
+int projectionObj_getUnits(projectionObj *self)
+ return GetMapserverUnitUsingProj(self);
void projectionObj_destroy(projectionObj *self) {
msFreeProjection(self);
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2009-01-06 15:27:12 UTC (rev 8389)
@@ -324,6 +324,7 @@
DLEXPORT void php3_ms_referenceMap_setProperty(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_projection_new(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_projection_getunits(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_projection_free(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_scalebar_setProperty(INTERNAL_FUNCTION_PARAMETERS);
@@ -912,6 +913,7 @@
function_entry php_projection_class_functions[] = {
+ {"getunits", php3_ms_projection_getunits, NULL},
{"free", php3_ms_projection_free, NULL},
{NULL, NULL, NULL}
@@ -13624,6 +13626,45 @@
+ * projection->getunits()
+/* {{{ proto int projection.getunits()
+ Returns the units of a projection object */
+ pval *pThis;
+ projectionObj *self;
+ long lValue = -1;
+ HashTable *list=NULL;
+ pThis = getThis();
+ if (pThis == NULL ||
+ ARG_COUNT(ht) > 0)
+ WRONG_PARAM_COUNT;
+ self = (projectionObj *)_phpms_fetch_handle2(pThis,
+ PHPMS_GLOBAL(le_msprojection_new),
+ PHPMS_GLOBAL(le_msprojection_ref),
+ list TSRMLS_CC);
+ if (self)
+ lValue = projectionObj_getUnits(self);
+ } else {
+ php3_error(E_ERROR, "Invalid projection object.");
+ RETURN_LONG(lValue);
* projection->free()
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h 2009-01-06 15:27:12 UTC (rev 8389)
@@ -281,6 +281,7 @@
int shapefileObj_addPoint(shapefileObj *self, pointObj *point);
projectionObj *projectionObj_new(char *string);
+int projectionObj_getUnits(projectionObj *self);
void projectionObj_destroy(projectionObj *self);
void labelCacheObj_freeCache(labelCacheObj *self);
Modified: trunk/mapserver/mapscript/python/tests/cases/maptest.py
--- trunk/mapserver/mapscript/python/tests/cases/maptest.py 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/mapscript/python/tests/cases/maptest.py 2009-01-06 15:27:12 UTC (rev 8389)
@@ -287,6 +287,7 @@
assert proj4.find( '+proj=aea' ) != -1
assert proj4.find( '+ellps=WGS84' ) != -1
+ assert (mapscript.projectionObj(proj4)).getUnits() != mapscript.MS_DD
def testESRIWKT(self):
self.map.setWKTProjection('ESRI::PROJCS["Pulkovo_1995_GK_Zone_2",GEOGCS["GCS_Pulkovo_1995",DATUM["D_Pulkovo_1995",SPHEROID["Krasovsky_1940",6378245,298.3]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Gauss_Kruger"],PARAMETER["False_Easting",2500000],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",9],PARAMETER["Scale_Factor",1],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]')
@@ -294,14 +295,15 @@
assert proj4.find( '+proj=tmerc' ) != -1
assert proj4.find( '+ellps=krass' ) != -1
def testWellKnownGEOGCS(self):
self.map.setWKTProjection('WGS84')
proj4 = self.map.getProjection()
assert proj4.find( '+proj=longlat' ) != -1, proj4
assert proj4.find( '+ellps=WGS84' ) != -1, proj4
+ assert (mapscript.projectionObj(proj4)).getUnits() != mapscript.MS_METERS
# Run the tests outside of the main suite
Modified: trunk/mapserver/mapscript/swiginc/projection.i
--- trunk/mapserver/mapscript/swiginc/projection.i 2009-01-05 18:36:43 UTC (rev 8388)
+++ trunk/mapserver/mapscript/swiginc/projection.i 2009-01-06 15:27:12 UTC (rev 8389)
@@ -61,6 +61,10 @@
/* no debug output here */
return msOGCWKT2ProjectionObj(wkt, self, MS_FALSE);
+ int getUnits() {
More information about the mapserver-commits
