[mapserver-commits] r8400 - branches/branch-5-2/mapserver
Thu Jan 8 14:28:49 EST 2009
Author: tbonfort
Date: 2009-01-08 14:28:49 -0500 (Thu, 08 Jan 2009)
New Revision: 8400
   branches/branch-5-2/mapserver/HISTORY.TXT
   branches/branch-5-2/mapserver/mapagg.cpp
mapagg.cpp: fix center of rotation for truetype marker symbols (#2848)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT	2009-01-08 19:26:57 UTC (rev 8399)
+++ branches/branch-5-2/mapserver/HISTORY.TXT	2009-01-08 19:28:49 UTC (rev 8400)
@@ -12,6 +12,7 @@
 Current Version (SVN branch-5-2)
+- mapagg.cpp: fix center of rotation for truetype marker symbols (#2848)
 - mapowscommon.c: output version string correctly (#2821)
Modified: branches/branch-5-2/mapserver/mapagg.cpp
--- branches/branch-5-2/mapserver/mapagg.cpp	2009-01-08 19:26:57 UTC (rev 8399)
+++ branches/branch-5-2/mapserver/mapagg.cpp	2009-01-08 19:28:49 UTC (rev 8400)
@@ -740,17 +740,34 @@
     int renderGlyphs(double x, double y, agg::rgba8 &color, agg::rgba8 &outlinecolor,
             double size, char *font, char *thechars, double angle,
             agg::rgba8 &shadowcolor, double shdx, double shdy,
-            int outlinewidth) {
+            int outlinewidth, bool isMarker=false) {
         if(!m_feng.load_font(font, 0, agg::glyph_ren_outline)) {
             msSetError(MS_TTFERR, "AGG error loading font (%s)", "renderGlyphs()", font);
             return MS_FAILURE;
         ras_aa.filling_rule(agg::fill_non_zero);
-        agg::trans_affine mtx;
-        mtx *= agg::trans_affine_translation(-x,-y);
-        /*agg angles are antitrigonometric*/
-        mtx *= agg::trans_affine_rotation(-angle);
-        mtx *= agg::trans_affine_translation(x,y);
+        const agg::glyph_cache* glyph;
+        int unicode;
+        double ox = 0, oy = 0;
+		if (isMarker) {
+			//is we're rendering a marker symbol, it has to be centered
+			//on the label point (the default is the lower left of the
+			//text)
+			//this block computes the offset between the lower left corner
+			//of the character and it's center for the given rotaion. this
+			//offset will then be used in the following agg::trans_affine_translation
+			msUTF8ToUniChar(thechars, &unicode);
+			glyph = m_fman.glyph(unicode);
+			ox = glyph->bounds.x1 + (glyph->bounds.x2 - glyph->bounds.x1) / 2.;
+			oy = glyph->bounds.y1 + (glyph->bounds.y2 - glyph->bounds.y1) / 2.;
+			agg::trans_affine_rotation(-angle).transform(&ox, &oy);
+		agg::trans_affine mtx;
+		mtx *= agg::trans_affine_translation(-x, -y);
+		/*agg angles are antitrigonometric*/
+		mtx *= agg::trans_affine_rotation(-angle);
+		mtx *= agg::trans_affine_translation(x - ox, y - oy);
@@ -759,8 +776,7 @@
         m_feng.resolution(96);
         m_feng.flip_y(true);
         font_curve_type m_curves(m_fman.path_adaptor());
-        const agg::glyph_cache* glyph;
-        int unicode;
         double fx=x,fy=y;
@@ -1233,14 +1249,10 @@
     case(MS_SYMBOL_TRUETYPE): {
         char* font = msLookupHashTable(&(symbolset->fontset->fonts), symbol->font);
         if(!font) return;
-        double x,y;
-        rectObj bounds;
-        if(ren->getLabelSize(symbol->character,font,size,&bounds)!=MS_SUCCESS)
-            return;
-        x = p->x + ox - bounds.minx - (bounds.maxx-bounds.minx)/2.;
-        y = p->y + oy - bounds.maxy + (bounds.maxy-bounds.miny)/2.;
-        ren->renderGlyphs(x,y,agg_color,agg_ocolor,
-                size,font,symbol->character,angle_radians,AGG_NO_COLOR,0,0,style->width);
+        ren->renderGlyphs(p->x+ox,p->y+oy,agg_color,agg_ocolor,
+                size,font,symbol->character,angle_radians,AGG_NO_COLOR,0,0,
+                MS_NINT(style->width),true);
     break;
     case(MS_SYMBOL_PIXMAP): {
