[mapserver-commits] r8431 - trunk/docs/mapfile
Tue Jan 13 16:28:19 EST 2009
Author: jmckenna
Date: 2009-01-13 16:28:19 -0500 (Tue, 13 Jan 2009)
New Revision: 8431
   trunk/docs/mapfile/map.txt
add ms_errorfile path note. ticket:2854
Modified: trunk/docs/mapfile/map.txt
--- trunk/docs/mapfile/map.txt	2009-01-13 21:16:06 UTC (rev 8430)
+++ trunk/docs/mapfile/map.txt	2009-01-13 21:28:19 UTC (rev 8431)
@@ -46,7 +46,9 @@
     MS_ERRORFILE [filename]
        The CONFIG parameter can be used to write MapServer errors to a file
-       (as of MapServer 5.0). For more on this see the DEBUG parameter below.
+       (as of MapServer 5.0). A full path (absolute reference) is
+       required, including the filename.  For more on this see the DEBUG
+       parameter below.
     MS_NONSQUARE [yes|no]
        The CONFIG parameter can be used to allow non-square WMS requests.
