[mapserver-commits] r9142 - sandbox/davidK
svn at osgeo.org
svn at osgeo.org
Tue Jul 7 01:57:47 EDT 2009
Author: davidK
Date: 2009-07-07 01:57:46 -0400 (Tue, 07 Jul 2009)
New Revision: 9142
sandbox/davidK/mapkml.cpp
sandbox/davidK/mapkml.h
sandbox/davidK/mapkmlrenderer.cpp
sandbox/davidK/mapkmlrenderer.h
Added ground overlay support
Modified: sandbox/davidK/mapkml.cpp
--- sandbox/davidK/mapkml.cpp 2009-07-06 20:27:43 UTC (rev 9141)
+++ sandbox/davidK/mapkml.cpp 2009-07-07 05:57:46 UTC (rev 9142)
@@ -1,6 +1,8 @@
#include "mapserver.h"
#include "mapkmlrenderer.h"
+#include "mapkml.h"
#ifdef __cplusplus
extern "C" {
#endif
@@ -108,7 +110,7 @@
return NULL;
-void msRenderTileKml(imageObj *img, imageObj *tile, double x, double y)
+void msRenderTileKml(imageObj *img, imageObj *tile, double x, double y, double angle)
@@ -145,6 +147,12 @@
void msFreeImageKml(imageObj *image)
+ KmlRenderer* renderer = getKmlRenderer(image);
+ if (renderer)
+ delete renderer;
+ image->img.plugin=NULL;
void msFreeTileKml(void *tile)
Modified: sandbox/davidK/mapkml.h
--- sandbox/davidK/mapkml.h 2009-07-06 20:27:43 UTC (rev 9141)
+++ sandbox/davidK/mapkml.h 2009-07-07 05:57:46 UTC (rev 9142)
@@ -50,8 +50,8 @@
int msGetTruetypeTextBBoxKml(imageObj *img,char *font, double size, char *string,
rectObj *rect, double **advances);
-void msStartNewLayerKml(imageObj *img, double opacity);
-void msCloseNewLayerKml(imageObj *img, double opacity);
+void msStartNewLayerKml(imageObj *img, layerObj *layer);
+void msCloseNewLayerKml(imageObj *img, layerObj *layer);
void msTransformShapeKml(shapeObj *shape, rectObj extend, double cellsize);
void msFreeImageKml(imageObj *image);
void msFreeTileKml(void *tile);
Modified: sandbox/davidK/mapkmlrenderer.cpp
--- sandbox/davidK/mapkmlrenderer.cpp 2009-07-06 20:27:43 UTC (rev 9141)
+++ sandbox/davidK/mapkmlrenderer.cpp 2009-07-07 05:57:46 UTC (rev 9142)
@@ -9,8 +9,9 @@
#define LAYER_FOLDER_STYLE_URL "#LayerFolder"
KmlRenderer::KmlRenderer(int width, int height, colorObj* color/*=NULL*/)
- : XmlDoc(NULL), LayerNode(NULL), FirstLayer(true), RasterizerOutputFormat(NULL),
- UseInternalRasterizer(false)
+ : XmlDoc(NULL), LayerNode(NULL), Width(width), Height(height),
+ FirstLayer(true), RasterizerOutputFormat(NULL),
+ VectorMode(true), RasterMode(false), MapCellsize(1.0)
// Create document.
XmlDoc = xmlNewDoc(BAD_CAST "1.0");
@@ -46,6 +47,14 @@
msFreeOutputFormat(RasterizerOutputFormat);
+imageObj* KmlRenderer::createInternalImage()
+ renderObj *r = RasterizerOutputFormat->r;
+ imageObj *img = r->createImage(Width, Height, RasterizerOutputFormat, NULL);
+ return img;
imageObj* KmlRenderer::createImage(int width, int height, outputFormatObj *format, colorObj* bg)
return NULL;
@@ -53,6 +62,13 @@
int KmlRenderer::saveImage(imageObj *img, FILE *fp, outputFormatObj *format)
+ if (InternalImg)
+ //sprintf(mapserv->Id, "%ld%d", (long)time(NULL), (int)getpid());
+ createGroundOverlayNode();
/* Write out the document. */
@@ -165,6 +181,10 @@
FirstLayer = false;
+ // map rect for ground overlay
+ MapExtent = layer->map->extent;
+ MapCellsize = layer->map->cellsize;
if (layer->map->name)
xmlNewChild(DocNode, NULL, BAD_CAST "name", BAD_CAST layer->map->name);
@@ -177,6 +197,7 @@
if(!strcasecmp(iFormat->driver,"cairo/png"))
RasterizerOutputFormat = msCloneOutputFormat(iFormat);
+ InternalImg = createInternalImage();
@@ -197,7 +218,7 @@
return placemarkNode;
-void KmlRenderer::renderLine(imageObj *img, shapeObj *p, strokeStyleObj *style)
+void KmlRenderer::renderLineVector(imageObj *img, shapeObj *p, strokeStyleObj *style)
xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, lookupLineStyle(style));
@@ -219,8 +240,30 @@
-void KmlRenderer::renderPolygon(imageObj *img, shapeObj *p, colorObj *color)
+void KmlRenderer::renderLine(imageObj *img, shapeObj *p, strokeStyleObj *style)
+ if (VectorMode)
+ renderLineVector(img, p, style);
+ if (RasterMode)
+ shapeObj rasShape;
+ // internal renderer used for rasterizing
+ msInitShape(&rasShape);
+ msCopyShape(p,&rasShape);
+ r->transformShape(&rasShape, MapExtent, MapCellsize);
+ r->renderLine(InternalImg, &rasShape, style);
+ msFreeShape(&rasShape);
+void KmlRenderer::renderPolygonVector(imageObj *img, shapeObj *p, colorObj *color)
xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, lookupPolyStyle(color));
xmlNodePtr polygonNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Polygon", NULL);
@@ -239,6 +282,28 @@
+void KmlRenderer::renderPolygon(imageObj *img, shapeObj *p, colorObj *color)
+ if (VectorMode)
+ renderPolygonVector(img, p, color);
+ if (RasterMode)
+ r->renderPolygon(InternalImg, rasShape, color);
void KmlRenderer::addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts)
char lineBuf[128];
@@ -353,7 +418,7 @@
return NULL;
-void KmlRenderer::renderGlyphs(imageObj *img, double x, double y, labelStyleObj *style, char *text)
+void KmlRenderer::renderGlyphsVector(imageObj *img, double x, double y, labelStyleObj *style, char *text)
xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, lookupPointStyle(&style->color));
xmlNewChild(placemarkNode, NULL, BAD_CAST "name", BAD_CAST text);
@@ -366,14 +431,37 @@
addCoordsNode(pointNode, &pt, 1);
+void KmlRenderer::renderGlyphs(imageObj *img, double x, double y, labelStyleObj *style, char *text)
+ if (VectorMode)
+ renderGlyphsVector(img, x, y, style, text);
+ if (RasterMode)
+ r->renderGlyphs(InternalImg, x, y, style, text);
int KmlRenderer::getTruetypeTextBBox(imageObj *img,char *font, double size, char *string,
- rect->minx=0.0;
- rect->maxx=0.0;
- rect->miny=0.0;
- rect->maxy=0.0;
+ if (VectorMode)
+ // TODO
+ rect->minx=0.0;
+ rect->maxx=0.0;
+ rect->miny=0.0;
+ rect->maxy=0.0;
+ if (RasterMode)
+ r->getTruetypeTextBBox(InternalImg, font, size, string, rect, advances);
return true;
@@ -399,31 +487,6 @@
xmlNewChild(node, NULL, BAD_CAST "altitudeMode", BAD_CAST "clampToGround");
-void KmlRenderer::renderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
- if (RasterizerOutputFormat)
- if (UseInternalRasterizer)
- else
- char *symbolUrl = lookupSymbolStyle(symbol, style);
- xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, symbolUrl);
- xmlNewChild(placemarkNode, NULL, BAD_CAST "name", NULL);
- xmlNodePtr pointNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Point", NULL);
- addAddRenderingSpecifications(pointNode);
- pointObj pt;
- pt.x = x; pt.y = y;
- addCoordsNode(pointNode, &pt, 1);
char* KmlRenderer::lookupSymbolStyle(symbolObj *symbol, symbolStyleObj *style)
@@ -461,7 +524,7 @@
xmlNewChild(iconStyleNode, NULL, BAD_CAST "scale", BAD_CAST scale);
char iconFileName[512];
- sprintf(iconFileName, "symbol_%s_%.1f", symbol->name, style->scale); // __TODO__ add WEB IMAGEURL path
+ sprintf(iconFileName, "symbol_%s_%.1f.%s", symbol->name, style->scale, MS_IMAGE_EXTENSION(RasterizerOutputFormat)); // __TODO__ add WEB IMAGEURL path
if (createIconImage(iconFileName, symbol, style) != MS_SUCCESS)
char errMsg[512];
@@ -534,4 +597,117 @@
return status;
+void KmlRenderer::createSymbolPlacemark(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+ char *symbolUrl = lookupSymbolStyle(symbol, style);
+ xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, symbolUrl);
+ xmlNewChild(placemarkNode, NULL, BAD_CAST "name", NULL);
+ xmlNodePtr pointNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Point", NULL);
+ addAddRenderingSpecifications(pointNode);
+ pointObj pt;
+ pt.x = x; pt.y = y;
+ addCoordsNode(pointNode, &pt, 1);
+void KmlRenderer::renderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+ if (VectorMode)
+ createSymbolPlacemark(img, x, y, symbol, style);
+ if (RasterMode)
+ r->renderPixmapSymbol(InternalImg, x, y, symbol, style);
+void KmlRenderer::renderVectorSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+ if (VectorMode)
+ if (RasterMode)
+ r->renderVectorSymbol(InternalImg, x, y, symbol, style);
+void KmlRenderer::renderEllipseSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+ if (VectorMode)
+ if (RasterMode)
+ r->renderEllipseSymbol(InternalImg, x, y, symbol, style);
+void KmlRenderer::renderTruetypeSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+ if (VectorMode)
+ if (RasterMode)
+ r->renderTruetypeSymbol(InternalImg, x, y, symbol, style);
+void KmlRenderer::createGroundOverlayNode(char *imageHref)
+ <?xml version="1.0" encoding="UTF-8"?>
+ <kml xmlns="http://www.opengis.net/kml/2.2">
+ <GroundOverlay>
+ <name>GroundOverlay.kml</name>
+ <color>7fffffff</color>
+ <drawOrder>1</drawOrder>
+ <Icon>
+ <href>http://www.google.com/intl/en/images/logo.gif</href>
+ <refreshMode>onInterval</refreshMode>
+ <refreshInterval>86400</refreshInterval>
+ <viewBoundScale>0.75</viewBoundScale>
+ </Icon>
+ <LatLonBox>
+ <north>37.83234</north>
+ <south>37.832122</south>
+ <east>-122.373033</east>
+ <west>-122.373724</west>
+ <rotation>45</rotation>
+ </LatLonBox>
+ </GroundOverlay>
+ </kml>
+ xmlNodePtr groundOverlayNode = xmlNewChild(DocNode, NULL, BAD_CAST "GroundOverlay", NULL);
+ xmlNewChild(groundOverlayNode, NULL, BAD_CAST "color", BAD_CAST "ffffffff");
+ xmlNewChild(groundOverlayNode, NULL, BAD_CAST "drawOrder", BAD_CAST "1");
+ xmlNodePtr iconNode = xmlNewChild(groundOverlayNode, NULL, BAD_CAST "Icon", NULL);
+ xmlNewChild(iconNode, NULL, BAD_CAST "href", BAD_CAST imageHref);
+ char crdStr[64];
+ xmlNodePtr latLonBoxNode = xmlNewChild(groundOverlayNode, NULL, BAD_CAST "LatLonBox", NULL);
+ sprintf(crdStr, "%.8f", MapExtent.maxy);
+ xmlNewChild(latLonBoxNode, NULL, BAD_CAST "north", BAD_CAST crdStr);
+ sprintf(crdStr, "%.8f", MapExtent.miny);
+ xmlNewChild(latLonBoxNode, NULL, BAD_CAST "south", BAD_CAST crdStr);
+ sprintf(crdStr, "%.8f", MapExtent.minx);
+ xmlNewChild(latLonBoxNode, NULL, BAD_CAST "west", BAD_CAST crdStr);
+ sprintf(crdStr, "%.8f", MapExtent.maxx);
+ xmlNewChild(latLonBoxNode, NULL, BAD_CAST "east", BAD_CAST crdStr);
+ xmlNewChild(latLonBoxNode, NULL, BAD_CAST "rotation", BAD_CAST "0.0");
#endif
\ No newline at end of file
Modified: sandbox/davidK/mapkmlrenderer.h
--- sandbox/davidK/mapkmlrenderer.h 2009-07-06 20:27:43 UTC (rev 9141)
+++ sandbox/davidK/mapkmlrenderer.h 2009-07-07 05:57:46 UTC (rev 9142)
@@ -15,6 +15,8 @@
xmlNodePtr DocNode;
xmlNodePtr LayerNode;
+ int Width, Height;
hashTableObj *StyleHashTable;
int AltitudeMode;
@@ -25,15 +27,24 @@
// internal output format containing cairo renderer used for rasterizing and rendering symbols
outputFormatObj *RasterizerOutputFormat;
+ imageObj *InternalImg;
- // true - features are rasterized, false - features are written directly in kml
- int UseInternalRasterizer;
+ rectObj MapExtent;
+ double MapCellsize;
+ // if true - features are rasterized
+ int VectorMode;
+ // if true - features are written directly in kml
+ int RasterMode;
enum altitudeModeEnum { undefined, clampToGround, relativeToGround, absolute };
protected:
+ imageObj* createInternalImage();
xmlNodePtr createPlacemarkNode(xmlNodePtr parentNode, char *styleUrl);
+ void createGroundOverlayNode(char *imageHref);
char* lookupPointStyle(colorObj *color);
char* lookupLineStyle(strokeStyleObj *strokeStyle);
@@ -50,6 +61,14 @@
int createIconImage(char *fileName, symbolObj *symbol, symbolStyleObj *style);
+ void createSymbolPlacemark(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
+ void renderLineVector(imageObj *img, shapeObj *p, strokeStyleObj *style);
+ void renderPolygonVector(imageObj *img, shapeObj *p, colorObj *color);
+ void renderGlyphsVector(imageObj *img, double x, double y, labelStyleObj *style, char *text);
public:
KmlRenderer(int width, int height, colorObj* color = NULL);
@@ -67,10 +86,13 @@
void renderGlyphs(imageObj *img, double x, double y, labelStyleObj *style, char *text);
+ // Symbols
void renderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
+ void renderVectorSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
+ void renderEllipseSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
+ void renderTruetypeSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
- int getTruetypeTextBBox(imageObj *img,char *font, double size, char *string,
- rectObj *rect, double **advances);
+ int getTruetypeTextBBox(imageObj *img,char *font, double size, char *string, rectObj *rect, double **advances);
#endif /* USE_KML && USE_LIBXML2*/
More information about the mapserver-commits
