[mapserver-commits] r9173 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jul 13 16:34:07 EDT 2009
Author: dmorissette
Date: 2009-07-13 16:34:07 -0400 (Mon, 13 Jul 2009)
New Revision: 9173
branches/branch-5-2/mapserver/HISTORY.TXT
branches/branch-5-2/mapserver/cgiutil.c
branches/branch-5-2/mapserver/mapserver.h
New fix for incomplete CVE-2009-0840 security fix made in 5.2.2 (#2943)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT 2009-07-13 20:26:41 UTC (rev 9172)
+++ branches/branch-5-2/mapserver/HISTORY.TXT 2009-07-13 20:34:07 UTC (rev 9173)
@@ -12,6 +12,8 @@
Current Version:
+- New fix for incomplete CVE-2009-0840 security fix made in 5.2.2 (#2943)
- Fixed seg fault if font not found with label ANGLE FOLLOW (#2973)
Version 5.2.2 (2009-03-26):
Modified: branches/branch-5-2/mapserver/cgiutil.c
--- branches/branch-5-2/mapserver/cgiutil.c 2009-07-13 20:26:41 UTC (rev 9172)
+++ branches/branch-5-2/mapserver/cgiutil.c 2009-07-13 20:34:07 UTC (rev 9173)
@@ -44,7 +44,7 @@
static char *readPostBody( cgiRequestObj *request )
char *data;
- unsigned int data_max, data_len;
+ size_t data_max, data_len;
int chunk_size;
msIO_needBinaryStdin();
@@ -53,10 +53,11 @@
/* If the length is provided, read in one gulp. */
if( getenv("CONTENT_LENGTH") != NULL ) {
- data_max = (unsigned int) atoi(getenv("CONTENT_LENGTH"));
- if(data_max <= 0) {
+ data_max = (size_t) atoi(getenv("CONTENT_LENGTH"));
+ /* Test for suspicious CONTENT_LENGTH (negative value or SIZE_MAX) */
+ if( data_max >= SIZE_MAX ) {
msIO_printf("Content-type: text/html%c%c",10,10);
- msIO_printf("Content-Length too small.\n");
+ msIO_printf("Suspicious Content-Length.\n");
exit( 1 );
data = (char *) malloc(data_max+1);
@@ -79,7 +80,9 @@
/* Otherwise read in chunks to the end. */
- data_max = 10000;
+#define DATA_ALLOC_SIZE 10000
+ data_max = DATA_ALLOC_SIZE;
data_len = 0;
@@ -87,7 +90,14 @@
data_len += chunk_size;
if( data_len == data_max ) {
- data_max = data_max + 10000;
+ /* Realloc buffer, making sure we check for possible size_t overflow */
+ if ( data_max > SIZE_MAX - (DATA_ALLOC_SIZE+1) ) {
+ msIO_printf("Content-type: text/html%c%c",10,10);
+ msIO_printf("Possible size_t overflow, cannot reallocate input buffer, POST body too large?\n" );
+ exit(1);
+ data_max = data_max + DATA_ALLOC_SIZE;
data = (char *) realloc(data, data_max+1);
if( data == NULL ) {
Modified: branches/branch-5-2/mapserver/mapserver.h
--- branches/branch-5-2/mapserver/mapserver.h 2009-07-13 20:26:41 UTC (rev 9172)
+++ branches/branch-5-2/mapserver/mapserver.h 2009-07-13 20:34:07 UTC (rev 9173)
@@ -65,6 +65,10 @@
/* definition of ms_int32/ms_uint32 */
#include <limits.h>
+#ifndef _WIN32
+#include <stdint.h>
+#endif
#if ULONG_MAX == 0xffffffff
typedef long ms_int32;
typedef unsigned long ms_uint32;
@@ -72,7 +76,6 @@
typedef int ms_int32;
typedef unsigned int ms_uint32;
#else
-#include <stdint.h>
typedef int32_t ms_int32;
typedef uint32_t ms_uint32;
#endif
More information about the mapserver-commits
