[mapserver-commits] r9180 - in branches/branch-5-4/mapserver: . mapscript/php3
Fri Jul 17 10:23:42 EDT 2009
Author: aboudreault
Date: 2009-07-17 10:23:42 -0400 (Fri, 17 Jul 2009)
New Revision: 9180
   branches/branch-5-4/mapserver/HISTORY.TXT
   branches/branch-5-4/mapserver/configure
   branches/branch-5-4/mapserver/configure.in
   branches/branch-5-4/mapserver/mapregex.c
   branches/branch-5-4/mapserver/mapregex.h
   branches/branch-5-4/mapserver/mapscript/php3/Makefile.in
   branches/branch-5-4/mapserver/mapscript/php3/php_mapscript_util.h
   branches/branch-5-4/mapserver/mapscript/php3/php_regex.c
backporting support for PHP 5.3 in branch-5-4
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/HISTORY.TXT	2009-07-17 14:23:42 UTC (rev 9180)
@@ -14,6 +14,8 @@
 Current Version:
+- Fixed PHP/Mapscript to support PHP 5.3 (#3065, #3066)
 - New fix for incomplete CVE-2009-0840 security fix made in 5.4.0 (#2943)
 - Add centroid geomtransform (#2825)
Modified: branches/branch-5-4/mapserver/configure
--- branches/branch-5-4/mapserver/configure	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/configure	2009-07-17 14:23:42 UTC (rev 9180)
@@ -12931,17 +12931,27 @@
             test -f "$PHP_SRC_DIR/regex/regex_extra.h" && PHP_NO_SOURCE="1"
         if test -n "$PHP_NO_SOURCE" ; then
                     USE_PHP_REGEX="-DUSE_PHP_REGEX"
+          PHP_REGEX_INC="$PHP_SRC_DIR/"
           PHP_REGEX_OBJ=php_regex.o
           { echo "$as_me:$LINENO: result:         found regex_extra.h - building PHP MapScript with PHP's bundled regex " >&5
 echo "${ECHO_T}        found regex_extra.h - building PHP MapScript with PHP's bundled regex " >&6; }
         else
-          { { echo "$as_me:$LINENO: error:
-!!! PHP uses its bundled regex library but regex/regex_extra.h cannot be !!!
-!!! found.                                                               !!!" >&5
+                    test -f "$PHP_SRC_DIR/ext/ereg/regex/regex.h" && PHP_NO_SOURCE="1"
+          if test -n "$PHP_NO_SOURCE" ; then
+                    USE_PHP_REGEX="-DUSE_PHP_REGEX"
+          PHP_REGEX_INC="$PHP_SRC_DIR/ext/ereg/"
+          PHP_REGEX_OBJ=php_regex.o
+          { echo "$as_me:$LINENO: result:         found regex.h - building PHP MapScript with PHP's bundled regex " >&5
+echo "${ECHO_T}        found regex.h - building PHP MapScript with PHP's bundled regex " >&6; }
+          else
+            { { echo "$as_me:$LINENO: error:
+!!! PHP uses its bundled regex library but regex/regex_extra.h (PHP <=5.2) or !!!
+!!! ext/ereg/regex/regex.h (PHP >=5.3) cannot be found.                                  !!!" >&5
 echo "$as_me: error:
-!!! found.                                                               !!!" >&2;}
+!!! ext/ereg/regex/regex.h (PHP >=5.3) cannot be found.                                  !!!" >&2;}
    { (exit 1); exit 1; }; }
+          fi
 	fi
   else
Modified: branches/branch-5-4/mapserver/configure.in
--- branches/branch-5-4/mapserver/configure.in	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/configure.in	2009-07-17 14:23:42 UTC (rev 9180)
@@ -2347,12 +2347,23 @@
           dnl Found regex_extra.h
           AC_MSG_RESULT([        found regex_extra.h - building PHP MapScript with PHP's bundled regex ])
         else
-          AC_MSG_ERROR([
-!!! found.                                                               !!!])
+          dnl PHP 5.3 changed the layout of regex-related files.
+          dnl Found regex.h
+          AC_MSG_RESULT([        found regex.h - building PHP MapScript with PHP's bundled regex ])
+          else
+            AC_MSG_ERROR([
+!!! ext/ereg/regex/regex.h (PHP >=5.3) cannot be found.                                  !!!])
+          fi
 	fi
   else
Modified: branches/branch-5-4/mapserver/mapregex.c
--- branches/branch-5-4/mapserver/mapregex.c	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/mapregex.c	2009-07-17 14:23:42 UTC (rev 9180)
@@ -52,7 +52,7 @@
 #include "mapregex.h"
 #include <regex.h>
-API_EXPORT(int) ms_regcomp(ms_regex_t *regex, const char *expr, int cflags)
+MS_API_EXPORT(int) ms_regcomp(ms_regex_t *regex, const char *expr, int cflags)
   /* Must free in regfree() */
   regex_t* sys_regex = (regex_t*) malloc(sizeof(regex_t));
@@ -60,12 +60,12 @@
   return regcomp(sys_regex, expr, cflags);
-API_EXPORT(size_t) ms_regerror(int errcode, const ms_regex_t *regex, char *errbuf, size_t errbuf_size)
+MS_API_EXPORT(size_t) ms_regerror(int errcode, const ms_regex_t *regex, char *errbuf, size_t errbuf_size)
   return regerror(errcode, (regex_t*)(regex->sys_regex), errbuf, errbuf_size);
-API_EXPORT(int) ms_regexec(const ms_regex_t *regex, const char *string, size_t nmatch, ms_regmatch_t pmatch[], int eflags)
+MS_API_EXPORT(int) ms_regexec(const ms_regex_t *regex, const char *string, size_t nmatch, ms_regmatch_t pmatch[], int eflags)
   /*This next line only works because we know that regmatch_t
     and ms_regmatch_t are exactly alike (POSIX STANDARD)*/
@@ -74,7 +74,7 @@
 	       (regmatch_t*) pmatch, eflags);
-API_EXPORT(void) ms_regfree(ms_regex_t *regex)
+MS_API_EXPORT(void) ms_regfree(ms_regex_t *regex)
   regfree((regex_t*)(regex->sys_regex));
   free(regex->sys_regex);
Modified: branches/branch-5-4/mapserver/mapregex.h
--- branches/branch-5-4/mapserver/mapregex.h	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/mapregex.h	2009-07-17 14:23:42 UTC (rev 9180)
@@ -37,9 +37,11 @@
   /* We want these to match the POSIX standard, so we need these*/
   /* === regex2.h === */
 #ifdef WIN32
-#define API_EXPORT(type)    __declspec(dllexport) type __stdcall
+#define MS_API_EXPORT(type)  __declspec(dllexport) type __stdcall
+#elif defined(__GNUC__) && __GNUC__ >= 4
+#define MS_API_EXPORT(type)  __attribute__ ((visibility("default"))) type
 #else
-#define API_EXPORT(type)    type
+#define MS_API_EXPORT(type)  type
 #endif
   typedef struct {
@@ -53,10 +55,10 @@
     ms_regoff_t rm_eo;  /* Byte offset from string's start to substring's end.  */
   } ms_regmatch_t;
-  API_EXPORT(int) ms_regcomp(ms_regex_t *, const char *, int);
-  API_EXPORT(size_t) ms_regerror(int, const ms_regex_t *, char *, size_t);
-  API_EXPORT(int) ms_regexec(const ms_regex_t *, const char *, size_t, ms_regmatch_t [], int);
-  API_EXPORT(void) ms_regfree(ms_regex_t *);
+  MS_API_EXPORT(int) ms_regcomp(ms_regex_t *, const char *, int);
+  MS_API_EXPORT(size_t) ms_regerror(int, const ms_regex_t *, char *, size_t);
+  MS_API_EXPORT(int) ms_regexec(const ms_regex_t *, const char *, size_t, ms_regmatch_t [], int);
+  MS_API_EXPORT(void) ms_regfree(ms_regex_t *);
 #ifndef BUILDING_REGEX_PROXY
Modified: branches/branch-5-4/mapserver/mapscript/php3/Makefile.in
--- branches/branch-5-4/mapserver/mapscript/php3/Makefile.in	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/mapscript/php3/Makefile.in	2009-07-17 14:23:42 UTC (rev 9180)
@@ -54,7 +54,7 @@
 # uses the same version of the REGEX library that PHP was compiled with:
 PHP_REGEX_OBJ=@PHP_REGEX_OBJ@
-PHP_REGEX_INC=@PHP_REGEX_INC@
+PHP_REGEX_INC=-I at PHP_REGEX_INC@
Modified: branches/branch-5-4/mapserver/mapscript/php3/php_mapscript_util.h
--- branches/branch-5-4/mapserver/mapscript/php3/php_mapscript_util.h	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/mapscript/php3/php_mapscript_util.h	2009-07-17 14:23:42 UTC (rev 9180)
@@ -44,6 +44,11 @@
 #define TSRMLS_CC
 #endif
+/* PHP >=5.3 replaced ZVAL_DELREF by Z_DELREF_P */
+#if ZEND_MODULE_API_NO >= 20090626
+#define ZVAL_DELREF Z_DELREF_P
+#define ZVAL_ADDREF Z_ADDREF_P
+#endif
  *                  macros for setting object properties
Modified: branches/branch-5-4/mapserver/mapscript/php3/php_regex.c
--- branches/branch-5-4/mapserver/mapscript/php3/php_regex.c	2009-07-17 13:45:52 UTC (rev 9179)
+++ branches/branch-5-4/mapserver/mapscript/php3/php_regex.c	2009-07-17 14:23:42 UTC (rev 9180)
@@ -54,12 +54,19 @@
+/* regex_extra.h doesn't exist in PHP >=5.3 */
+#include "php.h"
+#if ZEND_MODULE_API_NO < 20090626
 #include "regex/regex_extra.h"
 #include "regex/regex.h"
+#else
+#include "php_regex.h"
+#endif
@@ -67,21 +74,21 @@
   return regexec((const regex_t*)(regex->sys_regex),
-	       string, nmatch,
-	       (regmatch_t*) pmatch, eflags);
+                 string, nmatch,
+                 (regmatch_t*) pmatch, eflags);
