[mapserver-commits] r9192 - trunk/docs/en/input/vector
Tue Jul 21 09:50:49 EDT 2009
Author: aboudreault
Date: 2009-07-21 09:50:49 -0400 (Tue, 21 Jul 2009)
New Revision: 9192
   trunk/docs/en/input/vector/ogr.txt
Updated the OGR Line thickness doc
Modified: trunk/docs/en/input/vector/ogr.txt
--- trunk/docs/en/input/vector/ogr.txt	2009-07-21 13:44:41 UTC (rev 9191)
+++ trunk/docs/en/input/vector/ogr.txt	2009-07-21 13:50:49 UTC (rev 9192)
@@ -689,14 +689,8 @@
   The line colour is mapped to CLASS.COLOR
 Line thickness
-  The default will be 1 pixel line (as it always is with MapServer). In MapServer,
-  in order to get lines thicker than 1 pixel, one has to define a circle symbol that
-  will be used to render the line (by applying a size to the circle symbol).
-  So if your data source contains lines thicker than 1 pixel then you need to provide
-  a circle symbol in your symbolset and you must name it "default-circle". If this
-  symbol is present then the lines will be drawn using their real thickness, otherwise
-  all lines will be 1 pixel wide.
+  The line thickness is mapped to CLASS.STYLE.WIDTH. The default will be 1 pixel line (as
+  it always is with MapServer).
 Polygon fill color
   Polygon fill color is mapped directly to CLASS.COLOR
