[mapserver-commits] r9087 - sandbox/pramsey/mapserver-5-4-plus
svn at osgeo.org
svn at osgeo.org
Fri Jun 5 20:09:05 EDT 2009
Author: pramsey
Date: 2009-06-05 20:09:05 -0400 (Fri, 05 Jun 2009)
New Revision: 9087
sandbox/pramsey/mapserver-5-4-plus/HISTORY.TXT
sandbox/pramsey/mapserver-5-4-plus/mapchart.c
sandbox/pramsey/mapserver-5-4-plus/mapdraw.c
sandbox/pramsey/mapserver-5-4-plus/mapquery.c
sandbox/pramsey/mapserver-5-4-plus/mapraster.c
sandbox/pramsey/mapserver-5-4-plus/maprasterquery.c
sandbox/pramsey/mapserver-5-4-plus/mapresample.c
sandbox/pramsey/mapserver-5-4-plus/mapwmslayer.c
Test msProjectRect status on return (#2844)
Modified: sandbox/pramsey/mapserver-5-4-plus/HISTORY.TXT
--- sandbox/pramsey/mapserver-5-4-plus/HISTORY.TXT 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/HISTORY.TXT 2009-06-06 00:09:05 UTC (rev 9087)
@@ -14,6 +14,8 @@
Current Version:
+- Test msProjectRect status on return (#2844)
- Do pre-emptive test for map.extent/layer.extent interaction (#3043)
Version 5.4.1 (2009-06-02):
Modified: sandbox/pramsey/mapserver-5-4-plus/mapchart.c
--- sandbox/pramsey/mapserver-5-4-plus/mapchart.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapchart.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -566,7 +566,8 @@
#ifdef USE_PROJ
if((map->projection.numargs > 0) && (layer->projection.numargs > 0))
- msProjectRect(&map->projection, &layer->projection, &searchrect); /* project the searchrect to source coords */
+ /* if we can't project into the source srs, the source srs is not in our extent, so no-op this layer */
+ if ( msProjectRect(&map->projection, &layer->projection, &searchrect) == MS_FAILURE ) return MS_SUCCESS;
#endif
status = msLayerWhichShapes(layer, searchrect);
Modified: sandbox/pramsey/mapserver-5-4-plus/mapdraw.c
--- sandbox/pramsey/mapserver-5-4-plus/mapdraw.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapdraw.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -866,7 +866,13 @@
#ifdef USE_PROJ
+ /* project into the source srs */
+ /* if we can't do it, we have no overlap, so exit */
+ msLayerClose(layer);
+ return MS_SUCCESS;
#endif
Modified: sandbox/pramsey/mapserver-5-4-plus/mapquery.c
--- sandbox/pramsey/mapserver-5-4-plus/mapquery.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapquery.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -352,7 +352,12 @@
searchrect = map->extent;
#ifdef USE_PROJ
if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
- msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
+ status = msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
+ if ( status == MS_FAILURE ) { /* can't project => no overlap */
+ msLayerClose(lp);
+ msSetError(MS_NOTFOUND, "No matching record(s) found, layer and area of interest do not overlap.", "msQueryByAttributes()");
+ return(MS_FAILURE);
else
lp->project = MS_FALSE;
#endif
@@ -508,8 +513,13 @@
/* identify target shapes */
searchrect = rect;
#ifdef USE_PROJ
- if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
+ if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection))) {
+ msLayerClose(lp);
+ continue;
else
#endif
@@ -735,10 +745,15 @@
searchrect = selectshape.bounds;
#ifdef USE_PROJ
+ msLayerClose(lp);
+ break; /* next layer */
else
- lp->project = MS_FALSE;
+ lp->project = MS_FALSE;
#endif
searchrect.minx -= tolerance; /* expand the search box to account for layer tolerances (e.g. buffered searches) */
@@ -1002,8 +1017,13 @@
searchrect = rect;
#ifdef USE_PROJ
+ msLayerClose(lp);
+ continue;
else
#endif
@@ -1182,8 +1202,13 @@
searchrect = selectshape->bounds;
#ifdef USE_PROJ
+ msLayerClose(lp);
+ continue;
else
#endif
@@ -1380,7 +1405,11 @@
#ifdef USE_PROJ
+ msLayerClose(lp);
+ continue;
else
#endif
Modified: sandbox/pramsey/mapserver-5-4-plus/mapraster.c
--- sandbox/pramsey/mapserver-5-4-plus/mapraster.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapraster.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -1408,7 +1408,13 @@
#ifdef USE_PROJ
/* if necessary, project the searchrect to source coords */
- if((map->projection.numargs > 0) && (layer->projection.numargs > 0)) msProjectRect(&map->projection, &layer->projection, &searchrect);
+ if((map->projection.numargs > 0) && (layer->projection.numargs > 0)) {
+ status = msProjectRect(&map->projection, &layer->projection, &searchrect);
+ final_status = MS_SUCCESS;
+ goto cleanup;
#endif
status = msLayerWhichShapes(tlp, searchrect);
if (status != MS_SUCCESS) {
Modified: sandbox/pramsey/mapserver-5-4-plus/maprasterquery.c
--- sandbox/pramsey/mapserver-5-4-plus/maprasterquery.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/maprasterquery.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -416,7 +416,7 @@
CPLErr eErr;
rasterLayerInfo *rlinfo;
rectObj searchrect;
- int needReproject = MS_FALSE;
+ int status, needReproject = MS_FALSE;
rlinfo = (rasterLayerInfo *) layer->layerinfo;
@@ -429,7 +429,12 @@
if(layer->project
&& msProjectionsDiffer(&(layer->projection), &(map->projection)))
- msProjectRect(&(map->projection), &(layer->projection), &searchrect);
+ status = msProjectRect(&(map->projection), &(layer->projection), &searchrect);
+ msSetError( MS_IMGERR, "Unable to project into source SRS.",
+ "msRasterQueryByRectLow()" );
+ return MS_FAILURE;
needReproject = MS_TRUE;
else
@@ -732,15 +737,21 @@
searchrect = queryRect;
+ status = MS_SUCCESS;
#ifdef USE_PROJ
+ status = msProjectRect(&map->projection, &layer->projection, &searchrect); /* project the searchrect to source coords */
#endif
- status = msShapefileWhichShapes(&tilefile, searchrect, layer->debug);
- if(status != MS_SUCCESS)
+ if ( status == MS_SUCCESS ) { /* rectangle projected properly */
+ status = msShapefileWhichShapes(&tilefile, searchrect, layer->debug);
+ if(status != MS_SUCCESS)
numtiles = 0; /* could be MS_DONE or MS_FAILURE */
- else
+ else
numtiles = tilefile.numshapes;
+ else { /* rectangle didn't project => no overlap */
+ numtiles = 0;
Modified: sandbox/pramsey/mapserver-5-4-plus/mapresample.c
--- sandbox/pramsey/mapserver-5-4-plus/mapresample.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapresample.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -1317,7 +1317,7 @@
#if !defined(PJD_GRIDSHIFT) && !defined(PJ_VERSION)
msSetError(MS_PROJERR,
"Projection support is not available, so msResampleGDALToMap() fails.",
- "msProjectRect()");
+ "msResampleGDALToMap()");
return(MS_FAILURE);
#else
int nSrcXSize, nSrcYSize, nDstXSize, nDstYSize;
Modified: sandbox/pramsey/mapserver-5-4-plus/mapwmslayer.c
--- sandbox/pramsey/mapserver-5-4-plus/mapwmslayer.c 2009-06-05 23:16:38 UTC (rev 9086)
+++ sandbox/pramsey/mapserver-5-4-plus/mapwmslayer.c 2009-06-06 00:09:05 UTC (rev 9087)
@@ -817,7 +817,7 @@
char *pszURL = NULL, *pszHTTPCookieData = NULL;
const char *pszTmp;
rectObj bbox;
- int nTimeout, bOkToMerge, bForceSeparateRequest;
+ int nTimeout, bOkToMerge, bForceSeparateRequest, status;
wmsParamsObj sThisWMSParams;
char *pszProxyHost=NULL;
@@ -874,7 +874,13 @@
/* Reproject latlonboundingbox to the selected SRS for the layer and */
/* check if it overlaps the bbox that we calculated for the request */
- msProjectRect(&(map->latlon), &(lp->projection), &ext);
+ if ( msProjectRect(&(map->latlon), &(lp->projection), &ext) == MS_FAILURE )
+ /* no rectangle projection => no overlap => nothing to do */
+ msFreeWmsParamsObj(&sThisWMSParams);
+ return MS_SUCCESS; /* No overlap. */
if (!msRectOverlap(&bbox, &ext))
/* No overlap... nothing to do */
More information about the mapserver-commits
