[mapserver-commits] r9104 - sandbox/davidK
svn at osgeo.org
svn at osgeo.org
Sun Jun 14 14:28:42 EDT 2009
Author: davidK
Date: 2009-06-14 14:28:42 -0400 (Sun, 14 Jun 2009)
New Revision: 9104
sandbox/davidK/mapkmlrenderer.cpp
sandbox/davidK/mapkmlrenderer.h
added lines and polygon symbology
added geometry attributes altitudeMode, extrude, tessellate
added mapfile projection test
Modified: sandbox/davidK/mapkmlrenderer.cpp
--- sandbox/davidK/mapkmlrenderer.cpp 2009-06-11 19:46:16 UTC (rev 9103)
+++ sandbox/davidK/mapkmlrenderer.cpp 2009-06-14 18:28:42 UTC (rev 9104)
@@ -5,8 +5,11 @@
#include "mapkmlrenderer.h"
#include "mapio.h"
+#define LAYER_FOLDER_STYLE "LayerFolder"
+#define LAYER_FOLDER_STYLE_URL "#LayerFolder"
KmlRenderer::KmlRenderer(int width, int height, colorObj* color/*=NULL*/)
- : XmlDoc(NULL), LayerNode(NULL)
+ : XmlDoc(NULL), LayerNode(NULL), FirstLayer(true)
// Create document.
XmlDoc = xmlNewDoc(BAD_CAST "1.0");
@@ -20,6 +23,11 @@
DocNode = xmlNewChild(rootNode, NULL, BAD_CAST "Document", NULL);
+ xmlNodePtr styleNode = xmlNewChild(DocNode, NULL, BAD_CAST "Style", NULL);
+ xmlNewProp(styleNode, BAD_CAST "id", BAD_CAST LAYER_FOLDER_STYLE);
+ xmlNodePtr listStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "ListStyle", NULL);
+ xmlNewChild(listStyleNode, NULL, BAD_CAST "listItemType", BAD_CAST "checkHideChildren");
StyleHashTable = msCreateHashTable();
@@ -83,20 +91,86 @@
+void KmlRenderer::setupRenderingParams(hashTableObj *layerMetadata)
+ AltitudeMode = 0;
+ Extrude = 0;
+ Tessellate = 0;
+ char *altitudeModeVal = msLookupHashTable(layerMetadata, "kml_altitudeMode");
+ if (altitudeModeVal)
+ if(strcasecmp(altitudeModeVal, "absolute") == 0)
+ AltitudeMode = absolute;
+ else if(strcasecmp(altitudeModeVal, "relativeToGround") == 0)
+ AltitudeMode = relativeToGround;
+ else if(strcasecmp(altitudeModeVal, "clampToGround") == 0)
+ AltitudeMode = clampToGround;
+ char *extrudeVal = msLookupHashTable(layerMetadata, "kml_extrude");
+ Extrude = atoi(extrudeVal);
+ char *tessellateVal = msLookupHashTable(layerMetadata, "kml_tessellate");
+ if (tessellateVal)
+ Tessellate = atoi(tessellateVal);
+int KmlRenderer::checkProjection(projectionObj *projection)
+#ifdef USE_PROJ
+ if (projection && projection->numargs > 0 && pj_is_latlong(projection->proj))
+ char *projStr = msGetProjectionString(projection);
+ /* is ellipsoid WGS84 or projection code epsg:4326 */
+ if (strcasestr(projStr, "WGS84") || strcasestr(projStr,"epsg:4326"))
+ return MS_SUCCESS;
+ msSetError(MS_PROJERR, "Mapfile projection not defined, KML output driver requires projection WGS84 (epsg:4326)", "KmlRenderer::checkProjection()" );
+ return MS_FAILURE;
+#else
+ msSetError(MS_MISCERR, "Projection support not enabled", "KmlRenderer::checkProjection" );
+#endif
void KmlRenderer::startNewLayer(imageObj *img, layerObj *layer)
LayerNode = xmlNewChild(DocNode, NULL, BAD_CAST "Folder", NULL);
- xmlNodePtr layerNameNode = xmlNewChild(LayerNode, NULL, BAD_CAST "name", NULL);
- xmlNodeAddContent(layerNameNode, BAD_CAST layer->name);
+ xmlNewChild(LayerNode, NULL, BAD_CAST "name", BAD_CAST layer->name);
- xmlNodePtr layerVisibilityNode = xmlNewChild(LayerNode, NULL, BAD_CAST "visibility", NULL);
- xmlNodeAddContent(layerVisibilityNode, BAD_CAST "1");
+ char *layerVisibility = layer->status != MS_OFF ? "1" : "0";
+ xmlNewChild(LayerNode, NULL, BAD_CAST "visibility", BAD_CAST layerVisibility);
+ xmlNewChild(LayerNode, NULL, BAD_CAST "styleUrl", BAD_CAST LAYER_FOLDER_STYLE_URL);
+ setupRenderingParams(&layer->metadata);
+ if (FirstLayer)
+ if (layer->map->name)
+ xmlNewChild(DocNode, NULL, BAD_CAST "name", BAD_CAST layer->map->name);
+ // First rendered layer - check mapfile projection
+ checkProjection(&layer->map->projection);
+ FirstLayer = false;
void KmlRenderer::closeNewLayer(imageObj *img, layerObj *layer)
xmlNodePtr KmlRenderer::createPlacemarkNode(xmlNodePtr parentNode, char *styleUrl)
@@ -113,12 +187,11 @@
xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, lookupLineStyle(style));
- int includeZ = 0;
if (p->numlines == 1)
xmlNodePtr geomNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "LineString", NULL);
- addCoordsNode(geomNode, p->line[0].point, p->line[0].numpoints, includeZ);
+ addAddRenderingSpecifications(geomNode);
+ addCoordsNode(geomNode, p->line[0].point, p->line[0].numpoints);
else
@@ -126,7 +199,8 @@
for (int i=0; i<p->numlines; i++)
xmlNodePtr lineStringNode = xmlNewChild(multiGeomNode, NULL, BAD_CAST "LineString", NULL);
- addCoordsNode(lineStringNode, p->line[i].point, p->line[i].numpoints, includeZ);
+ addAddRenderingSpecifications(lineStringNode);
+ addCoordsNode(lineStringNode, p->line[i].point, p->line[i].numpoints);
@@ -136,8 +210,6 @@
xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, lookupPolyStyle(color));
xmlNodePtr polygonNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Polygon", NULL);
- int includeZ = 0;
xmlNodePtr bdryNode = NULL;
@@ -148,11 +220,12 @@
bdryNode = xmlNewChild(polygonNode, NULL, BAD_CAST "innerBoundaryIs", NULL);
xmlNodePtr ringNode = xmlNewChild(bdryNode, NULL, BAD_CAST "LinearRing", NULL);
- addCoordsNode(ringNode, p->line[i].point, p->line[i].numpoints, includeZ);
+ addAddRenderingSpecifications(ringNode);
+ addCoordsNode(ringNode, p->line[i].point, p->line[i].numpoints);
-void KmlRenderer::addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts, int includeZ)
+void KmlRenderer::addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts)
char lineBuf[128];
@@ -161,12 +234,12 @@
for (int i=0; i<numPts; i++)
- if (includeZ)
+ if (AltitudeMode == relativeToGround || AltitudeMode == absolute)
#ifdef USE_POINT_Z_M
sprintf(lineBuf, "\t%.8f,%.8f,%.8f\n", pts[i].x, pts[i].y, pts[i].z);
#else
- msSetError(MS_QUERYERR, "Z coordinates support not available (mapserver not compiled with USE_POINT_Z_M option)", "KmlRenderer::addCoordsNode");
+ msSetError(MS_MISCERR, "Z coordinates support not available (mapserver not compiled with USE_POINT_Z_M option)", "KmlRenderer::addCoordsNode()");
#endif
else
@@ -272,22 +345,45 @@
xmlNewChild(placemarkNode, NULL, BAD_CAST "name", BAD_CAST text);
xmlNodePtr pointNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Point", NULL);
- int includeZ = false;
+ addAddRenderingSpecifications(pointNode);
pointObj pt;
pt.x = x; pt.y = y;
- addCoordsNode(pointNode, &pt, 1, includeZ);
+ addCoordsNode(pointNode, &pt, 1);
int KmlRenderer::getTruetypeTextBBox(imageObj *img,char *font, double size, char *string,
rectObj *rect, double **advances)
- rect->minx=0.0;
- rect->maxx=0.0;
- rect->miny=0.0;
+ rect->minx=0.0;
+ rect->maxx=0.0;
+ rect->miny=0.0;
rect->maxy=0.0;
return true;
+void KmlRenderer::addAddRenderingSpecifications(xmlNodePtr node)
+ <extrude>0</extrude> <!-- boolean -->
+ <tessellate>0</tessellate> <!-- boolean -->
+ <altitudeMode>clampToGround</altitudeMode>
+ if (Extrude)
+ xmlNewChild(node, NULL, BAD_CAST "extrude", BAD_CAST "1");
+ if (Tessellate)
+ xmlNewChild(node, NULL, BAD_CAST "tessellate", BAD_CAST "1");
+ if (AltitudeMode == absolute)
+ xmlNewChild(node, NULL, BAD_CAST "altitudeMode", BAD_CAST "absolute");
+ else if (AltitudeMode == relativeToGround)
+ xmlNewChild(node, NULL, BAD_CAST "altitudeMode", BAD_CAST "relativeToGround");
+ else if (AltitudeMode == clampToGround)
+ xmlNewChild(node, NULL, BAD_CAST "altitudeMode", BAD_CAST "clampToGround");
#endif
\ No newline at end of file
Modified: sandbox/davidK/mapkmlrenderer.h
--- sandbox/davidK/mapkmlrenderer.h 2009-06-11 19:46:16 UTC (rev 9103)
+++ sandbox/davidK/mapkmlrenderer.h 2009-06-14 18:28:42 UTC (rev 9104)
@@ -17,6 +17,14 @@
hashTableObj *StyleHashTable;
+ int AltitudeMode;
+ int Tessellate;
+ int Extrude;
+ int FirstLayer;
+ enum altitudeModeEnum { undefined, clampToGround, relativeToGround, absolute };
protected:
xmlNodePtr createPlacemarkNode(xmlNodePtr parentNode, char *styleUrl);
@@ -25,8 +33,13 @@
char* lookupLineStyle(strokeStyleObj *strokeStyle);
char* lookupPolyStyle(colorObj *color);
- void addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts, int includeZ);
+ void addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts);
+ void setupRenderingParams(hashTableObj *layerMetadata);
+ void addAddRenderingSpecifications(xmlNodePtr node);
+ int checkProjection(projectionObj *projection);
public:
KmlRenderer(int width, int height, colorObj* color = NULL);
More information about the mapserver-commits
