[mapserver-commits] r8654 - trunk/docs/mapfile
svn at osgeo.org
svn at osgeo.org
Sat Mar 7 14:32:34 EST 2009
Author: jmckenna
Date: 2009-03-07 14:32:34 -0500 (Sat, 07 Mar 2009)
New Revision: 8654
trunk/docs/mapfile/layer.txt
add missing EXTENT parameter (ticket:2914)
Modified: trunk/docs/mapfile/layer.txt
--- trunk/docs/mapfile/layer.txt 2009-03-07 19:25:21 UTC (rev 8653)
+++ trunk/docs/mapfile/layer.txt 2009-03-07 19:32:34 UTC (rev 8654)
@@ -144,11 +144,17 @@
Switch to allow MapServer to return data in GML format. Useful when
used with WMS GetFeatureInfo operations. "false" by default.
+EXTENT [minx] [miny] [maxx] [maxy]
+ The spatial extent of the data. In most cases you will not need
+ to specify this, but it can be used to avoid the speed cost of having
+ MapServer compute the extents of the data. An application can also
+ possibly use this value to override the extents of the map.
:ref:`FEATURE`
Signals the start of a :ref:`FEATURE` object.
.. _FILTER:
FILTER [string]
This parameter allows for data specific attribute filtering that is done
at the same time spatial filtering is done, but before any CLASS
More information about the mapserver-commits
