[mapserver-commits] r8676 - in trunk/msautotest/wxs: . expected
Sun Mar 8 16:26:48 EDT 2009
Author: warmerdam
Date: 2009-03-08 16:26:48 -0400 (Sun, 08 Mar 2009)
New Revision: 8676
Added:
   trunk/msautotest/wxs/expected/wms_rast_cap.xml
   trunk/msautotest/wxs/wms_raster.map
test extent setting from raster data (#79)
Added: trunk/msautotest/wxs/expected/wms_rast_cap.xml
--- trunk/msautotest/wxs/expected/wms_rast_cap.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_rast_cap.xml	2009-03-08 20:26:48 UTC (rev 8676)
@@ -0,0 +1,145 @@
+Content-type: application/vnd.ogc.wms_xml
+<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
+ <!ELEMENT VendorSpecificCapabilities EMPTY>
+ ]>  <!-- end of DOCTYPE declaration -->
+<WMT_MS_Capabilities version="1.1.1" updateSequence="123">
+<Service>
+  <Name>OGC:WMS</Name>
+  <Title>Test simple wms</Title>
+        <KeywordList>
+          <Keyword>ogc</Keyword>
+          <Keyword>wms</Keyword>
+          <Keyword>mapserver</Keyword>
+        </KeywordList>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.mapserver.org/"/>
+  <ContactInformation>
+    <ContactPersonPrimary>
+      <ContactPerson>Tom Kralidis</ContactPerson>
+      <ContactOrganization>MapServer</ContactOrganization>
+    </ContactPersonPrimary>
+      <ContactPosition>self</ContactPosition>
+    <ContactAddress>
+        <AddressType>postal</AddressType>
+        <Address>123 SomeRoad Road</Address>
+        <City>Toronto</City>
+        <StateOrProvince>Ontario</StateOrProvince>
+        <PostCode>xxx-xxx</PostCode>
+        <Country>Canada</Country>
+    </ContactAddress>
+      <ContactVoiceTelephone>+xx-xxx-xxx-xxxx</ContactVoiceTelephone>
+      <ContactFacsimileTelephone>+xx-xxx-xxx-xxxx</ContactFacsimileTelephone>
+  <ContactElectronicMailAddress>tomkralidis at xxxxxxx.xxx</ContactElectronicMailAddress>
+  </ContactInformation>
+  <Fees>None</Fees>
+  <AccessConstraints>None</AccessConstraints>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <Format>application/vnd.ogc.wms_xml</Format>
+      <DCPType>
+        <HTTP>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Post>
+        </HTTP>
+      </DCPType>
+    </GetCapabilities>
+    <GetMap>
+      <Format>image/png</Format>
+      <Format>image/gif</Format>
+      <Format>image/png; mode=24bit</Format>
+      <Format>image/jpeg</Format>
+      <Format>image/vnd.wap.wbmp</Format>
+      <Format>image/tiff</Format>
+      <Format>image/svg+xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>text/plain</Format>
+      <Format>application/vnd.ogc.gml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <DescribeLayer>
+      <Format>text/xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </DescribeLayer>
+    <GetLegendGraphic>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetLegendGraphic>
+    <GetStyles>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetStyles>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_xml</Format>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
+  </Exception>
+  <VendorSpecificCapabilities />
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+  <Layer>
+    <Name>WMS_TEST</Name>
+    <SRS>EPSG:42304</SRS>
+    <SRS>EPSG:42101</SRS>
+    <SRS>EPSG:4269</SRS>
+    <SRS>EPSG:4326</SRS>
+    <LatLonBoundingBox minx="-67.5725" miny="42" maxx="-58.9275" maxy="48.5" />
+    <BoundingBox SRS="EPSG:4326"
+                minx="-67.5725" miny="42" maxx="-58.9275" maxy="48.5" />
+    <Layer queryable="0" opaque="0" cascaded="0">
+        <Name>road</Name>
+        <Title>road</Title>
+        <SRS>EPSG:43204</SRS>
+        <LatLonBoundingBox minx="-117.546" miny="44.6656" maxx="-117.387" maxy="44.7671" />
+        <BoundingBox SRS="EPSG:32611"
+                    minx="456800" miny="4.94595e+06" maxx="469300" maxy="4.95715e+06" />
+    </Layer>
+        <Name>grey</Name>
+<!-- WARNING: Mandatory metadata '..._title' was missing in this context. -->
+        <Title>grey</Title>
+        <SRS>EPSG:32611</SRS>
+        <!-- WARNING: Optional LatLonBoundingBox could not be established for this layer.  Consider setting the EXTENT in the LAYER object, or wms_extent metadata. Also check that your data exists in the DATA statement -->
+    </Layer>
+  </Layer>
+</Capability>
+</WMT_MS_Capabilities>
Added: trunk/msautotest/wxs/wms_raster.map
--- trunk/msautotest/wxs/wms_raster.map	                        (rev 0)
+++ trunk/msautotest/wxs/wms_raster.map	2009-03-08 20:26:48 UTC (rev 8676)
@@ -0,0 +1,127 @@
+# Test WMS
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
+# The following test exists primarily to test the ability of displaying
+# layer extents in capabilities derived from the underlying raster file
+# without the user having to include in the file using EXTENT keyword.  #79
+# Capabilities
+# RUN_PARMS: wms_rast_cap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities" > [RESULT_DEVERSION]
+NAME WMS_TEST
+STATUS ON
+SIZE 400 300
+#EXTENT   2018000 -73300 3410396 647400
+#UNITS METERS
+EXTENT -67.5725 42 -58.9275 48.5
+UNITS DD
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+  NAME GDPNG
+  DRIVER "GD/PNG"
+  MIMETYPE "image/png"
+  IMAGEMODE RGB
+  EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+  METADATA
+    "ows_updatesequence"   "123"
+    "wms_title"		   "Test simple wms"
+    "wms_onlineresource"   "http://localhost/path/to/wms_simple?"
+    "wms_srs"		   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+    "ows_schemas_location" "http://schemas.opengis.net"
+    "ows_keywordlist" "ogc,wms,mapserver"
+    "ows_service_onlineresource" "http://www.mapserver.org/"
+    "ows_fees" "None"
+    "ows_accessconstraints" "None"
+    "ows_addresstype" "postal"
+    "ows_address"     "123 SomeRoad Road"
+    "ows_city" "Toronto"
+    "ows_stateorprovince" "Ontario"
+    "ows_postcode" "xxx-xxx"
+    "ows_country" "Canada"
+    "ows_contactelectronicmailaddress" "tomkralidis at xxxxxxx.xxx"
+    "ows_contactvoicetelephone" "+xx-xxx-xxx-xxxx"
+    "ows_contactfacsimiletelephone" "+xx-xxx-xxx-xxxx"
+    "ows_contactperson" "Tom Kralidis"
+    "ows_contactorganization" "MapServer"
+    "ows_contactposition" "self"
+  END
+END
+PROJECTION
+  "init=epsg:4326"
+  #"init=./data/epsg2:42304"
+END
+# Start of layer definitions
+LAYER
+  NAME road
+  DATA toronto.tif
+  METADATA
+    "wms_title"       "road"
+    "wms_description" "Roads of I.P.E."
+    "wms_srs" "EPSG:43204"
+    "gml_include_items" "all"
+  END
+  TYPE RASTER
+  STATUS ON
+  PROJECTION
+    "init=epsg:32611"
+  END
+  DUMP TRUE
+END # Layer
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS ON
+  DUMP TRUE
+  TILEINDEX "wcs_index.shp"
+  TILEITEM "location"
+  PROJECTION
+    "init=epsg:32611"
+  END
+  METADATA
+   "wcs_label" "Test label"
+   "ows_srs"	"EPSG:32611 EPSG:4326"
+   "wcs_resolution" "10 10"
+   "wcs_bandcount" "1"
+   "wcs_formats" "GEOTIFF_16 GDPNG AAIGRID"
+   "wcs_nativeformat" "GeoTIFF"
+   "wcs_description" "Test description"
+   "wcs_metadatalink_href" "http://www.gdal.org/metadata_test_link.html"
+   "wcs_keywordlist" "test,mapserver"
+   "wcs_abstract" "Category: Image
+Product: IKONOS-2 PAN/MSI
+Acquisition: 1999-10-11 18:47"
+   "wcs_rangeset_axes" "bands"
+   "wcs_rangeset_name" "Landsat 5 TM Bands"
+   "wcs_rangeset_label" "Bands"
+   "wcs_rangeset_description" "Bands for Landsat 5 TM"
+  END
+END
+END # Map File
