[mapserver-commits] r8694 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 10:00:23 EDT 2009
Author: pnaciona
Date: 2009-03-09 10:00:23 -0400 (Mon, 09 Mar 2009)
New Revision: 8694
trunk/docs/tutorial/example1-3.txt
update tutorial example 1.3
Modified: trunk/docs/tutorial/example1-3.txt
--- trunk/docs/tutorial/example1-3.txt 2009-03-09 13:59:48 UTC (rev 8693)
+++ trunk/docs/tutorial/example1-3.txt 2009-03-09 14:00:23 UTC (rev 8694)
@@ -11,7 +11,7 @@
.. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-3.map&layer=states_poly&layer=states_line&mode=map
-This is what the mapfile looks like: `Example1-3.map<http://biometry.gis.umn.edu/tutorial/example1-3.map>`_.
+This is what the mapfile looks like: `<http://biometry.gis.umn.edu/tutorial/example1-3.map>`_.
The mapfile structure, by objects, looks like this:
@@ -47,4 +47,5 @@
simplest form of EXPRESSION. EXPRESSIONs can be even more complex than
this, allowing one to evaluate regular or logical expressions. Please
look at the mapfile reference page to see what you can do
- with EXPRESSION.
\ No newline at end of file
+ with EXPRESSION.
More information about the mapserver-commits
