[mapserver-commits] r8697 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 10:27:47 EDT 2009
Author: jmckenna
Date: 2009-03-09 10:27:47 -0400 (Mon, 09 Mar 2009)
New Revision: 8697
Added:
trunk/docs/tutorial/section1.txt
trunk/docs/tutorial/index.txt
formatting improvements
Modified: trunk/docs/tutorial/index.txt
--- trunk/docs/tutorial/index.txt 2009-03-09 14:15:03 UTC (rev 8696)
+++ trunk/docs/tutorial/index.txt 2009-03-09 14:27:47 UTC (rev 8697)
@@ -28,6 +28,5 @@
:maxdepth: 1
background
- example1-1
- example1-2
- example1-3
\ No newline at end of file
+ section1
+ section2
Copied: trunk/docs/tutorial/section1.txt (from rev 8689, trunk/docs/tutorial/example1-2.txt)
--- trunk/docs/tutorial/section1.txt (rev 0)
+++ trunk/docs/tutorial/section1.txt 2009-03-09 14:27:47 UTC (rev 8697)
@@ -0,0 +1,31 @@
+.. _section1:
+Section 1: Static Maps and the MapFile
+- Take a shapefile. Any shapefile. We can use MapServer to display that shapefile on a web browser. Look...
+ - :ref:`Example 1.1 - A map with a single layer <example1-1>`
+- We can display the same shapefile repeatedly. We can display the polygon attributes on one LAYER and and the line attributes on another...
+ - :ref:`Example 1.2 - A map with two layers <example1-2>`
+- And we can select which parts of the shapefile to display. We do this using the CLASS object...
+ - :ref:`Example 1.3 - Using classes to make a "useful" map <example1-3>`
+- We can also label our maps...
+ - :ref:`Example 1.4 - Labeling layers and label layers <example1-4>`
+- Or add raster data such as satellite images, aerial photographs, or shaded reliefs...
+ - :ref:`Example 1.5- Adding a raster layer <example1-5>`
+- We can reproject our data from just about any projection to just about any... Yeah, check it out!
+ - :ref:`Example 1.6 - Projection/Reprojection <example1-6`
+- And we can use layers from other map servers on the internet (as long as they are WMS servers)...
+ - :ref:`Example 1.7- Adding a WMS layer <example1-7>`
+- MapServer can output to various formats such as PDF and GeoTIFF.
+ - :ref:`Example 1.8 - A different output format <example1-8>`
+- MapServer not only generates static maps, it can also create interactive maps...
+ - :ref:`Example 1.9- The difference between map and browse mode <example1-9>`
More information about the mapserver-commits
