[mapserver-commits] r8706 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 12:12:10 EDT 2009
Author: jmckenna
Date: 2009-03-09 12:12:10 -0400 (Mon, 09 Mar 2009)
New Revision: 8706
Added:
trunk/docs/tutorial/example1-5-map.txt
add raster mapfile for tutorial
Added: trunk/docs/tutorial/example1-5-map.txt
--- trunk/docs/tutorial/example1-5-map.txt (rev 0)
+++ trunk/docs/tutorial/example1-5-map.txt 2009-03-09 16:12:10 UTC (rev 8706)
@@ -0,0 +1,163 @@
+.. _example1-5-map:
+Example1-5.map
+.. code-block:: mapfile
+ # The annotated map file (sort of)
+ # Created by Pericles S. Nacionales for the MapServer tutorial
+ # 20050408
+ # MapServer map file uses the pound sign (#) to denote the start of a line
+ # comment--each line that needs to be commented has to be prepended with a "#".
+ # Map files begin with MAP keyword to signify the start of the map object.
+ # Well, the entire map file is THE map object. Enclosed between MAP and END
+ # at the very bottom of this map file, are keyword/value pairs and other
+ # objects.
+ MAP
+ IMAGETYPE PNG24
+ EXTENT -97.238976 41.619778 -82.122902 49.385620
+ SIZE 400 300
+ SHAPEPATH "../data"
+ IMAGECOLOR 255 255 255
+ FONTSET "../fonts/fonts.list"
+ SYMBOLSET "../symbols/symbols35.sym"
+ # Layer objects are defined beneath the map object. You need at least one
+ # layer defined in your map file before you can display a map... You can
+ # define as many layers as you'd like although a limit is typically hard-coded
+ # in map.h in the MapServer source. The default limit is set at 100. You'd
+ # have to have a very specialized application to need more than 100 layers in
+ # your application.
+ # Start of LAYER DEFINITIONS ---------------------------------------------
+ LAYER # States polygon layer begins here
+ NAME states
+ DATA states_ugl
+ STATUS OFF
+ TYPE POLYGON
+ # CLASSITEM defines the non-spatial attribute that you will be using to
+ # separate a layer into classes. This attribute will be in the DBF file
+ # of your shapefile (it will be different for each data format). In this
+ # example the shapefile states_ugl has an associated database
+ # (states_ugl.dbf) that contains an attribute called "CLASS". You will be
+ # using two values in the CLASS attribute to separate the classes (also
+ # called themes) used in this layer--land and water. CLASSITEM is used in
+ # association with the EXPRESSION parameter in the CLASS object. See below.
+ CLASSITEM "CLASS"
+ # The class object is defined within the layer object. You can define as
+ # many classes as you need (well, there are limits as with layers, but it's
+ # senseless to define more than ten on a "normal" layer. There are
+ # situations, however, where you might have to do it.)
+ CLASS
+ NAME 'States'
+ EXPRESSION 'land'
+ # There are styles in a class, just like there are classes in a layer,
+ # just like there are layers in a map. You can define multiple styles in
+ # a class just as you can define multiple classes in a layer and multiple
+ # layers in a map.
+ STYLE
+ COLOR 232 232 232
+ END
+ END
+ END # States polygon layer ends here
+ # In addition to vector data (shapefiles are vector data), MapServer supports
+ # a host of raster formats. In GIS world, one of the most common raster
+ # formats is GeoTIFF, a TIFF image with geospatial headers. MapServer also
+ # supports JPEG, PNG, GIF, and other common formats. Other raster formats
+ # supported by MapServer include ESRI Arc/Info grid, HDF and HDF-EOS, NetCDF,
+ # Generic raster binaries, OGC Web Map Service (WMS) layers, etc. Pretty much
+ # any raster format you can think of is probably supported, thanks to the
+ # impressive Geospatial Data Abstraction Library (GDAL, pronounced "GOODALL"
+ # or GOODLE?). More information on GDAL is available at http://www.gdal.org.
+ # MapServer 4.x can read and display bitmapped (like GIFs), RGB/A (true
+ # color), and multispectral (images with more than 3 bands, like raw LandSat
+ # images) rasters.
+ LAYER # MODIS raster layer begins here
+ NAME modis
+ DATA "raster/mod09a12003161_ugl_ll_8bit.tif"
+ STATUS OFF
+ TYPE RASTER
+ PROCESSING "BANDS=1,2,3"
+ OFFSITE 71 74 65
+ END # MODIS raster layer ends here
+ LAYER # States line layer begins here
+ NAME states_line
+ DATA states_ugl
+ STATUS OFF
+ TYPE LINE
+ CLASSITEM "CLASS"
+ CLASS
+ NAME 'State Boundary'
+ EXPRESSION 'land'
+ STYLE
+ SYMBOL 'line5'
+ COLOR 64 64 64
+ SIZE 1
+ END
+ END
+ END # States line layer ends here
+ # Labels can be defined in its own layer. This is useful if, say, you want
+ # to label a polygon layer that's covered by another layer. By keeping the
+ # label separate from the polygon and placing it near the bottom of the map
+ # file (so its drawn on, or near the, top), you can still see the label even
+ # though you might not be able to see the polygon. It is also a good
+ # alternate to point symbols.
+ # A label layer is actually defined with ANNOTATION type (This is derived from
+ # points, Node IDs for lines, or polygon IDs).
+ LAYER # States label layer begins here
+ NAME states_label
+ DATA states_ugl
+ STATUS OFF
+ TYPE ANNOTATION
+ CLASSITEM "CLASS"
+ # Just like CLASSITEM, LABELITEM defines the database attribute that you
+ # will be using to draw labels. In this case, the values of the attribute
+ # "STATE" will be used to label the states polygons.
+ LABELITEM "STATE"
+ CLASS
+ EXPRESSION 'land'
+ STYLE
+ COLOR -1 -1 -1
+ END
+ # There can be labels in a class, just like there are classes in a layer,
+ # just like there are layers in a map. You can define multiple labels in
+ # MapServer has a very flexible labeling system. With that flexibility
+ # comes complexity, specially when using truetype fonts. Please read
+ # through the LABEL section of the MapServer map file documentation at
+ # http://ms.gis.umn.edu/docs/reference/mapfile for more information.
+ LABEL
+ COLOR 132 31 31
+ SHADOWCOLOR 218 218 218
+ SHADOWSIZE 2 2
+ TYPE TRUETYPE
+ FONT arial-bold
+ SIZE 12
+ ANTIALIAS TRUE
+ POSITION CL
+ PARTIALS FALSE
+ MINDISTANCE 300
+ BUFFER 4
+ END # end of label
+ END # end of class
+ END # States label layer ends here
+ # End of LAYER DEFINITIONS -------------------------------
+ END # All map files must come to an end just as all other things must come to...
\ No newline at end of file
More information about the mapserver-commits
