[mapserver-commits] r8728 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 16:37:09 EDT 2009
Author: pnaciona
Date: 2009-03-09 16:37:09 -0400 (Mon, 09 Mar 2009)
New Revision: 8728
trunk/docs/tutorial/example1-2.txt
update tutorial example 1.2 to point to demo.mapserver.org
Modified: trunk/docs/tutorial/example1-2.txt
--- trunk/docs/tutorial/example1-2.txt 2009-03-09 20:36:24 UTC (rev 8727)
+++ trunk/docs/tutorial/example1-2.txt 2009-03-09 20:37:09 UTC (rev 8728)
@@ -6,7 +6,7 @@
Static Map with Two Layers
-.. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-2.map&layer=states_poly&layer=states_line&mode=map
+.. image:: http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-2.map&layer=states_poly&layer=states_line&mode=map
As in the first example, this image was generated by linking the source of the
<img> tag to this URL:
More information about the mapserver-commits
