[mapserver-commits] r8730 - trunk/docs/tutorial
Mon Mar 9 16:39:02 EDT 2009
Author: pnaciona
Date: 2009-03-09 16:39:02 -0400 (Mon, 09 Mar 2009)
New Revision: 8730
   trunk/docs/tutorial/example1-4.txt
update tutorial example 1.4 to point to demo.mapserver.org
Modified: trunk/docs/tutorial/example1-4.txt
--- trunk/docs/tutorial/example1-4.txt	2009-03-09 20:38:15 UTC (rev 8729)
+++ trunk/docs/tutorial/example1-4.txt	2009-03-09 20:39:02 UTC (rev 8730)
@@ -8,7 +8,7 @@
 We can also add labels to our map...
-.. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-4.map&layer=states_poly&layer=states_line&mode=map
+.. image:: http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-4.map&layer=states_poly&layer=states_line&mode=map
 MapServer has a very flexible labeling engine.  It supports native bitmap as
 well as truetype fonts.  Font scaling is supported with truetype. The labeling
@@ -102,5 +102,5 @@
           map file to see how you'd implement this kind of labeling.  You will
           notice that the CLASS object within the "label" layer has a COLOR
           parameter value of "-1 -1 -1". The negative number tells MapServer to
-          give this CLASS a transparent color (the label IDs don't show up).
+          give this CLASS a transparent color (the label IDs don't show up).
           Once again, play with the values to understand how it affects the map.
