[mapserver-commits] r8734 - trunk/docs/tutorial
Mon Mar 9 16:44:25 EDT 2009
Author: pnaciona
Date: 2009-03-09 16:44:25 -0400 (Mon, 09 Mar 2009)
New Revision: 8734
   trunk/docs/tutorial/example1-8.txt
update tutorial example 1.8 to point to demo.mapserver.org
Modified: trunk/docs/tutorial/example1-8.txt
--- trunk/docs/tutorial/example1-8.txt	2009-03-09 20:43:06 UTC (rev 8733)
+++ trunk/docs/tutorial/example1-8.txt	2009-03-09 20:44:25 UTC (rev 8734)
@@ -6,7 +6,7 @@
 Changing the Map's Output Format
-.. image::  http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-8.map&layers=states+states_label+modis&map.imagetype=AGG&mode=map
+.. image::  http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-8.map&layers=states+states_label+modis&map.imagetype=AGG&mode=map
 Depending on the format you choose, the image may not display on your browser.
 If the link fails to display on your browser, right click on the graphic above
