[mapserver-commits] r8738 - trunk/docs/ogc
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 16:57:39 EDT 2009
Author: tomkralidis
Date: 2009-03-09 16:57:39 -0400 (Mon, 09 Mar 2009)
New Revision: 8738
trunk/docs/ogc/wms_server.txt
add ows_sld_enabled metadata (#1395)
Modified: trunk/docs/ogc/wms_server.txt
--- trunk/docs/ogc/wms_server.txt 2009-03-09 20:50:08 UTC (rev 8737)
+++ trunk/docs/ogc/wms_server.txt 2009-03-09 20:57:39 UTC (rev 8738)
@@ -605,7 +605,13 @@
metadata document. The parameter value can be an integer, a timestamp in
[ISO 8601:2000] format, or any other number or string.
+**ows_sld_enabled**
+- *Description:* (Optional) A value (true or false) which, when set to
+ "false", will ignore SLD and SLD_BODY parameters in order to disable
+ remote styling of WMS layers. Also, SLD is not advertised in WMS
+ Capabilities as a result
**ows_schemas_location**
- *Description:* (Optional) (Note the name ows_schemas_location and not wms\_... this
More information about the mapserver-commits
