[mapserver-commits] r8756 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Tue Mar 10 09:36:44 EDT 2009
Author: pnaciona
Date: 2009-03-10 09:36:44 -0400 (Tue, 10 Mar 2009)
New Revision: 8756
Added:
trunk/docs/tutorial/example1-4-map.txt
add mapfile example for tutorial example 1.4
Added: trunk/docs/tutorial/example1-4-map.txt
--- trunk/docs/tutorial/example1-4-map.txt (rev 0)
+++ trunk/docs/tutorial/example1-4-map.txt 2009-03-10 13:36:44 UTC (rev 8756)
@@ -0,0 +1,122 @@
+.. _example-1-4-map:
+Example1-4.map
+.. code-block:: mapfile
+ # The annotated map file (sort of)
+ # Created by Pericles S. Nacionales for the MapServer tutorial
+ # 20050408
+ # MapServer map file uses the pound sign (#) to denote the start of a line
+ # comment--each line that needs to be commented has to be prepended with a "#".
+ # Map files begin with MAP keyword to signify the start of the map object.
+ # Well, the entire map file is THE map object. Enclosed between MAP and END
+ # at the very bottom of this map file, are keyword/value pairs and other
+ # objects.
+ MAP
+ IMAGETYPE PNG
+ EXTENT -97.238976 41.619778 -82.122902 49.385620
+ SIZE 400 300
+ SHAPEPATH "../data"
+ IMAGECOLOR 255 255 255
+ FONTSET "../fonts/fonts.list"
+ # Layer objects are defined beneath the map object. You need at least one
+ # layer defined in your map file before you can display a map... You can
+ # define as many layers as you'd like although a limit is typically hard-coded
+ # in map.h in the MapServer source. The default limit is set at 100. You'd
+ # have to have a very specialized application to need more than 100 layers in
+ # your application.
+ # Start of LAYER DEFINITIONS ---------------------------------------------
+ LAYER # States polygon layer begins here
+ NAME states_poly
+ DATA states_ugl
+ STATUS OFF
+ TYPE POLYGON
+ # CLASSITEM defines the non-spatial attribute that you will be using to
+ # separate a layer into classes. This attribute will be in the DBF file
+ # of your shapefile (it will be different for each data format). In this
+ # example the shapefile states_ugl has an associated database
+ # (states_ugl.dbf) that contains an attribute called "CLASS". You will be
+ # using two values in the CLASS attribute to separate the classes (also
+ # called themes) used in this layer--land and water. CLASSITEM is used in
+ # association with the EXPRESSION parameter in the CLASS object. See below.
+ CLASSITEM "CLASS"
+ # Just like CLASSITEM, LABELITEM defines the database attribute that you
+ # will be using to draw labels. In this case, the values of the attribute
+ # "STATE" will be used to label the states polygons.
+ LABELITEM "STATE"
+ # The class object is defined within the layer object. You can define as
+ # many classes as you need (well, there are limits as with layers, but it's
+ # senseless to define more than ten on a "normal" layer. There are
+ # situations, however, where you might have to do it.)
+ CLASS
+ NAME 'States'
+ EXPRESSION 'land'
+ # There are styles in a class, just like there are classes in a layer,
+ # just like there are layers in a map. You can define multiple styles in
+ # a class just as you can define multiple classes in a layer and multiple
+ # layers in a map.
+ STYLE
+ COLOR 232 232 232
+ END
+ # There can be labels in a class, just like there are classes in a layer,
+ # just like there are layers in a map. You can define multiple labels in
+ # MapServer has a very flexible labeling system. With that flexibility
+ # comes complexity, specially when using truetype fonts. Please read
+ # through the LABEL section of the MapServer map file documentation at
+ # http://ms.gis.umn.edu/docs/reference/mapfile for more information.
+ LABEL
+ COLOR 132 31 31
+ SHADOWCOLOR 218 218 218
+ SHADOWSIZE 2 2
+ TYPE TRUETYPE
+ FONT arial-bold
+ SIZE 12
+ ANTIALIAS TRUE
+ POSITION CL
+ PARTIALS FALSE
+ MINDISTANCE 300
+ BUFFER 4
+ END # end of label
+ END
+ CLASS
+ NAME 'Water'
+ EXPRESSION 'water'
+ STYLE
+ COLOR 198 198 255
+ END
+ END
+ END # States polygon layer ends here
+ LAYER # States line layer begins here
+ NAME states_line
+ DATA states_ugl
+ STATUS OFF
+ TYPE LINE
+ CLASSITEM "CLASS"
+ CLASS
+ NAME 'State Boundary'
+ EXPRESSION 'land'
+ STYLE
+ COLOR 64 64 64
+ END
+ END
+ END # States line layer ends here
+ # End of LAYER DEFINITIONS -------------------------------
+ END # All map files must come to an end just as all other things must come to...
More information about the mapserver-commits
