[mapserver-commits] r8761 - trunk/docs/tutorial
Tue Mar 10 09:40:54 EDT 2009
Author: pnaciona
Date: 2009-03-10 09:40:53 -0400 (Tue, 10 Mar 2009)
New Revision: 8761
   trunk/docs/tutorial/example1-4.txt
update tutorial example 1.4 links
Modified: trunk/docs/tutorial/example1-4.txt
--- trunk/docs/tutorial/example1-4.txt	2009-03-10 13:39:48 UTC (rev 8760)
+++ trunk/docs/tutorial/example1-4.txt	2009-03-10 13:40:53 UTC (rev 8761)
@@ -16,7 +16,7 @@
 many parameters involved in creating good labels, you will be rewarded with
 informative and aesthetically pleasing maps.
-This is what the map file looks like: `Example1-4.map <http://biometry.gis.umn.edu/tutorial/example1-4.map>`_.
+This is what the map file looks like: :ref:`Example1-4.map <example1-4-map>`.
 MapFile Structure
@@ -110,3 +110,5 @@
           parameter value of "-1 -1 -1". The negative number tells MapServer to
           give this CLASS a transparent color (the label IDs don't show up).
           Once again, play with the values to understand how it affects the map.
+:ref:`Back to Example 1.3 <example1-3.txt>` | :ref:`Proceed to Example 1.5 <example1-5.txt>`
