[mapserver-commits] r8790 - trunk/msautotest/wxs
svn at osgeo.org
svn at osgeo.org
Fri Mar 13 17:32:38 EDT 2009
Author: tomkralidis
Date: 2009-03-13 17:32:38 -0400 (Fri, 13 Mar 2009)
New Revision: 8790
trunk/msautotest/wxs/sos.map
test commit
Modified: trunk/msautotest/wxs/sos.map
--- trunk/msautotest/wxs/sos.map 2009-03-12 19:42:01 UTC (rev 8789)
+++ trunk/msautotest/wxs/sos.map 2009-03-13 21:32:38 UTC (rev 8790)
@@ -33,7 +33,7 @@
# DescribeSensor
-# Exceptions
+# Exceptions
# RUN_PARMS: sos_se3.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.1.0&request=DescribeSensor" > [RESULT]
# RUN_PARMS: sos_se4.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor" > [RESULT]
@@ -41,7 +41,7 @@
# RUN_PARMS: sos_se6.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=2147&outputFormat=XML" > [RESULT]
# RUN_PARMS: sos_se7.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=20147&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
-# Valid
+# Valid
# RUN_PARMS: sos_describe.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=urn:ogc:def:procedure:35&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
More information about the mapserver-commits
