[mapserver-commits] r8807 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Mar 18 10:10:57 EDT 2009
Author: sdlime
Date: 2009-03-18 10:10:57 -0400 (Wed, 18 Mar 2009)
New Revision: 8807
branches/branch-5-2/mapserver/mapsymbol.c
Fixed symbol set loader to require the SYMBOLSET token before processing. (related to #2941)
Modified: branches/branch-5-2/mapserver/mapsymbol.c
--- branches/branch-5-2/mapserver/mapsymbol.c 2009-03-18 11:14:16 UTC (rev 8806)
+++ branches/branch-5-2/mapserver/mapsymbol.c 2009-03-18 14:10:57 UTC (rev 8807)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
* Project: MapServer
* Purpose: symbolObj related functions.
@@ -621,7 +621,7 @@
int msLoadSymbolSet(symbolSetObj *symbolset, mapObj *map)
int retval = MS_FAILURE;
msAcquireLock( TLOCK_PARSER );
retval = loadSymbolSet( symbolset, map );
msReleaseLock( TLOCK_PARSER );
@@ -636,6 +636,9 @@
int status=1;
char szPath[MS_MAXPATHLEN], *pszSymbolPath=NULL;
+ int foundSymbolSetToken=MS_FALSE;
+ int token;
if(!symbolset) {
msSetError(MS_SYMERR, "Symbol structure unallocated.", "loadSymbolSet()");
return(-1);
@@ -662,7 +665,15 @@
** Read the symbol file
for(;;) {
- switch(msyylex()) {
+ token = msyylex();
+ if(!foundSymbolSetToken && token != SYMBOLSET) {
+ msSetError(MS_IDENTERR, "First token must be SYMBOLSET, this doesn't look like a symbol file.", "msLoadSymbolSet()");
+ return(-1);
+ switch(token) {
case(END):
case(EOF):
status = 0;
@@ -678,6 +689,7 @@
symbolset->numsymbols++;
break;
case(SYMBOLSET):
+ foundSymbolSetToken = MS_TRUE;
break;
default:
msSetError(MS_IDENTERR, "Parsing error near (%s):(line %d)", "loadSymbolSet()", msyytext, msyylineno);
More information about the mapserver-commits
