[mapserver-commits] r8811 - branches/branch-5-2/msautotest/gdal
svn at osgeo.org
svn at osgeo.org
Thu Mar 19 14:11:30 EDT 2009
Author: sdlime
Date: 2009-03-19 14:11:29 -0400 (Thu, 19 Mar 2009)
New Revision: 8811
branches/branch-5-2/msautotest/gdal/256_overlay_res.map
branches/branch-5-2/msautotest/gdal/256color_overdose.map
branches/branch-5-2/msautotest/gdal/256color_overdose_cmt.map
branches/branch-5-2/msautotest/gdal/256color_overdose_res.map
branches/branch-5-2/msautotest/gdal/average_rgb.map
branches/branch-5-2/msautotest/gdal/bilinear_float.map
branches/branch-5-2/msautotest/gdal/class16.map
branches/branch-5-2/msautotest/gdal/class16_ndmap.map
branches/branch-5-2/msautotest/gdal/class16_oddscale.map
branches/branch-5-2/msautotest/gdal/class16_range.map
branches/branch-5-2/msautotest/gdal/class8_range.map
branches/branch-5-2/msautotest/gdal/classtest1.map
branches/branch-5-2/msautotest/gdal/classtest2.map
branches/branch-5-2/msautotest/gdal/force_pc256.map
branches/branch-5-2/msautotest/gdal/gd_jpeg_256.map
branches/branch-5-2/msautotest/gdal/gd_png_256_res.map
branches/branch-5-2/msautotest/gdal/gd_png_tr_256.map
branches/branch-5-2/msautotest/gdal/gd_png_tr_256_res.map
branches/branch-5-2/msautotest/gdal/gdal_png_256_res.map
branches/branch-5-2/msautotest/gdal/gdal_png_tr_256.map
branches/branch-5-2/msautotest/gdal/gdal_png_tr_256_res.map
branches/branch-5-2/msautotest/gdal/grayalpha.map
branches/branch-5-2/msautotest/gdal/grayalpha_8bit.map
branches/branch-5-2/msautotest/gdal/lut_1_crv.map
branches/branch-5-2/msautotest/gdal/lut_inline.map
branches/branch-5-2/msautotest/gdal/lut_rgb_crv.map
branches/branch-5-2/msautotest/gdal/nodata_8bit.map
branches/branch-5-2/msautotest/gdal/nodata_scaled.map
branches/branch-5-2/msautotest/gdal/nonsquare.map
branches/branch-5-2/msautotest/gdal/nonsquare_multiraw.map
branches/branch-5-2/msautotest/gdal/offsite_8bitgrey.map
branches/branch-5-2/msautotest/gdal/offsite_pct_rgb.map
branches/branch-5-2/msautotest/gdal/offsite_pct_rgb_torgb.map
branches/branch-5-2/msautotest/gdal/ows_extent.map
branches/branch-5-2/msautotest/gdal/processing_bands.map
branches/branch-5-2/msautotest/gdal/processing_scale_auto.map
branches/branch-5-2/msautotest/gdal/rawmode_multiband.map
branches/branch-5-2/msautotest/gdal/reproj.map
branches/branch-5-2/msautotest/gdal/rgb_overlay.map
branches/branch-5-2/msautotest/gdal/rgb_overlay_res.map
branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit.map
branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit_dithered.map
branches/branch-5-2/msautotest/gdal/rgba_overlay_res.map
branches/branch-5-2/msautotest/gdal/rot_out.map
branches/branch-5-2/msautotest/gdal/tileindex.map
branches/branch-5-2/msautotest/gdal/trlay1.map
branches/branch-5-2/msautotest/gdal/trlay2.map
branches/branch-5-2/msautotest/gdal/trlay3.map
branches/branch-5-2/msautotest/gdal/unclassified.map
branches/branch-5-2/msautotest/gdal/wld_rotate.map
branches/branch-5-2/msautotest/gdal/wld_upsidedown.map
Added leading MAP token to the GDAL autotest mapfiles.
Modified: branches/branch-5-2/msautotest/gdal/256_overlay_res.map
--- branches/branch-5-2/msautotest/gdal/256_overlay_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/256_overlay_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests overlaying an image with a transparent color on an opaque layer.
Modified: branches/branch-5-2/msautotest/gdal/256color_overdose.map
--- branches/branch-5-2/msautotest/gdal/256color_overdose.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/256color_overdose.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests layering a layer with transparency on a layer with 256 colors already.
Modified: branches/branch-5-2/msautotest/gdal/256color_overdose_cmt.map
--- branches/branch-5-2/msautotest/gdal/256color_overdose_cmt.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/256color_overdose_cmt.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/256color_overdose_res.map
--- branches/branch-5-2/msautotest/gdal/256color_overdose_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/256color_overdose_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/average_rgb.map
--- branches/branch-5-2/msautotest/gdal/average_rgb.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/average_rgb.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test averaged resampling. Results currently depend on the 2x oversampling
# for mapresample.c.
Modified: branches/branch-5-2/msautotest/gdal/bilinear_float.map
--- branches/branch-5-2/msautotest/gdal/bilinear_float.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/bilinear_float.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test bilinear resampling on floating point "raw" data format.
Modified: branches/branch-5-2/msautotest/gdal/class16.map
--- branches/branch-5-2/msautotest/gdal/class16.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/class16.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Simple test of classification methods on a floating point input.
Modified: branches/branch-5-2/msautotest/gdal/class16_ndmap.map
--- branches/branch-5-2/msautotest/gdal/class16_ndmap.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/class16_ndmap.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test of classification methods on a floating point input with provided
# NODATA, scaling and bucket values.
Modified: branches/branch-5-2/msautotest/gdal/class16_oddscale.map
--- branches/branch-5-2/msautotest/gdal/class16_oddscale.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/class16_oddscale.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# scaling that causes merging of some original values throwing off results.
Modified: branches/branch-5-2/msautotest/gdal/class16_range.map
--- branches/branch-5-2/msautotest/gdal/class16_range.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/class16_range.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/class8_range.map
--- branches/branch-5-2/msautotest/gdal/class8_range.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/class8_range.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/classtest1.map
--- branches/branch-5-2/msautotest/gdal/classtest1.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/classtest1.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test classification methods on a pseudocolored input image.
Modified: branches/branch-5-2/msautotest/gdal/classtest2.map
--- branches/branch-5-2/msautotest/gdal/classtest2.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/classtest2.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/force_pc256.map
--- branches/branch-5-2/msautotest/gdal/force_pc256.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/force_pc256.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests the quantization option allowing conversion of
Modified: branches/branch-5-2/msautotest/gdal/gd_jpeg_256.map
--- branches/branch-5-2/msautotest/gdal/gd_jpeg_256.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gd_jpeg_256.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for rendering 8bit images to JPEG, where the JPEG is in PC256
# mode..
Modified: branches/branch-5-2/msautotest/gdal/gd_png_256_res.map
--- branches/branch-5-2/msautotest/gdal/gd_png_256_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gd_png_256_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests non-transparent 8bit output via GD with resampling.
Modified: branches/branch-5-2/msautotest/gdal/gd_png_tr_256.map
--- branches/branch-5-2/msautotest/gdal/gd_png_tr_256.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gd_png_tr_256.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests transparent 8bit output via GD without resampling.
Modified: branches/branch-5-2/msautotest/gdal/gd_png_tr_256_res.map
--- branches/branch-5-2/msautotest/gdal/gd_png_tr_256_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gd_png_tr_256_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests transparent 8bit output via GD with resampling.
Modified: branches/branch-5-2/msautotest/gdal/gdal_png_256_res.map
--- branches/branch-5-2/msautotest/gdal/gdal_png_256_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gdal_png_256_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests non-transparent 8bit output via GDAL with resampling.
Modified: branches/branch-5-2/msautotest/gdal/gdal_png_tr_256.map
--- branches/branch-5-2/msautotest/gdal/gdal_png_tr_256.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gdal_png_tr_256.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests transparent 8bit output via GDAL without resampling.
Modified: branches/branch-5-2/msautotest/gdal/gdal_png_tr_256_res.map
--- branches/branch-5-2/msautotest/gdal/gdal_png_tr_256_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/gdal_png_tr_256_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests transparent 8bit output via GDAL with resampling.
Modified: branches/branch-5-2/msautotest/gdal/grayalpha.map
--- branches/branch-5-2/msautotest/gdal/grayalpha.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/grayalpha.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests overlaying a greyscale image with an alpha band on a greyscale image
Modified: branches/branch-5-2/msautotest/gdal/grayalpha_8bit.map
--- branches/branch-5-2/msautotest/gdal/grayalpha_8bit.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/grayalpha_8bit.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/lut_1_crv.map
--- branches/branch-5-2/msautotest/gdal/lut_1_crv.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/lut_1_crv.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test GIMP curve file support: single curve.
Modified: branches/branch-5-2/msautotest/gdal/lut_inline.map
--- branches/branch-5-2/msautotest/gdal/lut_inline.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/lut_inline.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test LUT (RFC GIMP curve file support: 3 curve.
Modified: branches/branch-5-2/msautotest/gdal/lut_rgb_crv.map
--- branches/branch-5-2/msautotest/gdal/lut_rgb_crv.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/lut_rgb_crv.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test GIMP curve file support: 3 curve.
Modified: branches/branch-5-2/msautotest/gdal/nodata_8bit.map
--- branches/branch-5-2/msautotest/gdal/nodata_8bit.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/nodata_8bit.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for NODATA used with a single value from an 8bit image. This
Modified: branches/branch-5-2/msautotest/gdal/nodata_scaled.map
--- branches/branch-5-2/msautotest/gdal/nodata_scaled.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/nodata_scaled.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test unclassified scaled raster with NODATA.
Modified: branches/branch-5-2/msautotest/gdal/nonsquare.map
--- branches/branch-5-2/msautotest/gdal/nonsquare.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/nonsquare.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test support for generating non-square output pixels.
Modified: branches/branch-5-2/msautotest/gdal/nonsquare_multiraw.map
--- branches/branch-5-2/msautotest/gdal/nonsquare_multiraw.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/nonsquare_multiraw.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test support for resampling raw mode images with more than one band.
Modified: branches/branch-5-2/msautotest/gdal/offsite_8bitgrey.map
--- branches/branch-5-2/msautotest/gdal/offsite_8bitgrey.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/offsite_8bitgrey.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test support for OFFSITE on simple greyscale (1 band, no colormap) inputs.
Modified: branches/branch-5-2/msautotest/gdal/offsite_pct_rgb.map
--- branches/branch-5-2/msautotest/gdal/offsite_pct_rgb.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/offsite_pct_rgb.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for OFFSITE used with RGB value of a colortable entry
Modified: branches/branch-5-2/msautotest/gdal/offsite_pct_rgb_torgb.map
--- branches/branch-5-2/msautotest/gdal/offsite_pct_rgb_torgb.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/offsite_pct_rgb_torgb.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/ows_extent.map
--- branches/branch-5-2/msautotest/gdal/ows_extent.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/ows_extent.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for getting image extents from OWS extents metadata.
Modified: branches/branch-5-2/msautotest/gdal/processing_bands.map
--- branches/branch-5-2/msautotest/gdal/processing_bands.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/processing_bands.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test use of the BANDS option via the PROCESSING directive.
Modified: branches/branch-5-2/msautotest/gdal/processing_scale_auto.map
--- branches/branch-5-2/msautotest/gdal/processing_scale_auto.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/processing_scale_auto.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/rawmode_multiband.map
--- branches/branch-5-2/msautotest/gdal/rawmode_multiband.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rawmode_multiband.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/reproj.map
--- branches/branch-5-2/msautotest/gdal/reproj.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/reproj.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test supports for image reprojection.
Modified: branches/branch-5-2/msautotest/gdal/rgb_overlay.map
--- branches/branch-5-2/msautotest/gdal/rgb_overlay.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rgb_overlay.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests overlaying an RGB image with a transparent value on a greyscale image
Modified: branches/branch-5-2/msautotest/gdal/rgb_overlay_res.map
--- branches/branch-5-2/msautotest/gdal/rgb_overlay_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rgb_overlay_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit.map
--- branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit_dithered.map
--- branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit_dithered.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rgb_overlay_res_to8bit_dithered.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/rgba_overlay_res.map
--- branches/branch-5-2/msautotest/gdal/rgba_overlay_res.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rgba_overlay_res.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests overlaying an RGBA image with on a greyscale image
Modified: branches/branch-5-2/msautotest/gdal/rot_out.map
--- branches/branch-5-2/msautotest/gdal/rot_out.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/rot_out.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test support for generating a rotated output map.
Modified: branches/branch-5-2/msautotest/gdal/tileindex.map
--- branches/branch-5-2/msautotest/gdal/tileindex.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/tileindex.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
NAME TEST
STATUS ON
Modified: branches/branch-5-2/msautotest/gdal/trlay1.map
--- branches/branch-5-2/msautotest/gdal/trlay1.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/trlay1.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test TRANSPARENCY flag on layer for overlaying 24bit image(s).
Modified: branches/branch-5-2/msautotest/gdal/trlay2.map
--- branches/branch-5-2/msautotest/gdal/trlay2.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/trlay2.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
Modified: branches/branch-5-2/msautotest/gdal/trlay3.map
--- branches/branch-5-2/msautotest/gdal/trlay3.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/trlay3.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test TRANSPARENCY flag with 8bit output result.
Modified: branches/branch-5-2/msautotest/gdal/unclassified.map
--- branches/branch-5-2/msautotest/gdal/unclassified.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/unclassified.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Test use of 24bit images with a dummy class used to populate the legend.
Modified: branches/branch-5-2/msautotest/gdal/wld_rotate.map
--- branches/branch-5-2/msautotest/gdal/wld_rotate.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/wld_rotate.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for images with non-northup world files.
Modified: branches/branch-5-2/msautotest/gdal/wld_upsidedown.map
--- branches/branch-5-2/msautotest/gdal/wld_upsidedown.map 2009-03-19 16:43:58 UTC (rev 8810)
+++ branches/branch-5-2/msautotest/gdal/wld_upsidedown.map 2009-03-19 18:11:29 UTC (rev 8811)
@@ -1,3 +1,4 @@
+MAP
# Tests support for upside-down images (like bug 1904).
More information about the mapserver-commits
