[mapserver-commits] r8987 - sandbox/graphics
svn at osgeo.org
svn at osgeo.org
Fri May 1 14:19:13 EDT 2009
Author: tbonfort
Date: 2009-05-01 14:19:13 -0400 (Fri, 01 May 2009)
New Revision: 8987
sandbox/graphics/mapcairo.c
stop using cairo text api, but use our own text to glyph decoding
Modified: sandbox/graphics/mapcairo.c
--- sandbox/graphics/mapcairo.c 2009-05-01 10:19:31 UTC (rev 8986)
+++ sandbox/graphics/mapcairo.c 2009-05-01 18:19:13 UTC (rev 8987)
@@ -283,29 +283,44 @@
void renderTruetypeSymbolCairo(imageObj *img, double x, double y, symbolObj *symbol,
symbolStyleObj *s) {
cairo_renderer *r = getCairoRenderer(img);
cairo_font_face_t *ff = getFontFace(r,symbol->full_font_path);
+ int unicode;
+ cairo_glyph_t glyph;
cairo_text_extents_t extents;
+ FT_Face *f;
cairo_matrix_t trans;
double ox,oy;
+ cairo_save(r->cr);
+ cairo_set_font_face(r->cr,ff);
+ cairo_set_font_size(r->cr,s->scale*96/72.0);
- cairo_save(r->cr);
- cairo_set_font_face(r->cr, ff);
- cairo_set_font_size(r->cr, s->scale * 96 / 72.0);
- cairo_text_extents(r->cr, symbol->character, &extents);
+ f = cairo_font_face_get_user_data(
+ cairo_get_font_face(r->cr),
+ &facekey);
+ msUTF8ToUniChar(symbol->character, &unicode);
+ glyph.index = FT_Get_Char_Index(*f, unicode);
+ cairo_glyph_extents(r->cr,&glyph,1,&extents);
+ ox=extents.x_bearing+extents.width/2.;
+ oy=extents.y_bearing+extents.height/2.;
+ glyph.x=0;
+ glyph.y=0;
cairo_matrix_init_rotate(&trans,-s->rotation);
- ox=extents.x_bearing+extents.width/2.;
- oy=extents.y_bearing+extents.height/2.;
cairo_matrix_transform_point(&trans,&ox,&oy);
//cairo_translate(cr,-extents.width/2,-extents.height/2);
- cairo_move_to(r->cr,x-ox,y-oy);
+ cairo_translate(r->cr,x-ox,y-oy);
cairo_rotate(r->cr, -s->rotation);
- cairo_text_path(r->cr, symbol->character);
+ cairo_glyph_path(r->cr,&glyph,1);
if (s->outlinewidth) {
msCairoSetSourceColor(r->cr, &s->outlinecolor);
cairo_set_line_width(r->cr, s->outlinewidth);
@@ -332,191 +347,200 @@
#define CAIROLINESPACE 1.33
-int getTruetypeTextBBoxCairo(imageObj *img,char *font, double size, char *string,
+int getTruetypeTextBBoxCairo(imageObj *img,char *font, double size, char *text,
rectObj *rect, double **advances) {
- cairo_renderer *r = getCairoRenderer(img);
- cairo_font_face_t *ff = getFontFace(r,font);
- int numlines, i;
- char **lines = msStringSplit(string, '\n', &numlines);
- cairo_text_extents_t extents;
+ cairo_renderer *r = getCairoRenderer(img);
+ cairo_font_face_t *ff = getFontFace(r,font);
- cairo_set_font_size(r->cr, size * 96 / 72.0);
+ char *utfptr=text;
+ int i,has_kerning,unicode;
+ unsigned long previdx=0;
+ int numglyphs = msGetNumGlyphs(text);
+ cairo_text_extents_t extents;
+ double px=0,py=0;
+ FT_Face *f;
- for(i=0;i<numlines;i++) {
- cairo_text_extents(r->cr, lines[i], &extents);
+ cairo_set_font_size(r->cr,size*96/72.0);
+ &facekey);
+ has_kerning = FT_HAS_KERNING((*f));
+ if(advances != NULL) {
+ *advances = (double*)malloc(numglyphs*sizeof(double));
+ for(i=0;i<numglyphs;i++) {
+ utfptr+=msUTF8ToUniChar(utfptr, &unicode);
+ glyph.x=px;
+ glyph.y=py;
+ if(unicode=='\n') {
+ py += ceil(size*CAIROLINESPACE);
+ px = 0;
+ previdx=0;
+ continue;
+ if( has_kerning && previdx ) {
+ FT_Vector delta;
+ FT_Get_Kerning( *f, previdx, glyph.index, FT_KERNING_DEFAULT, &delta );
+ px += delta.x / 64.;
if(i==0) {
- rect->minx = extents.x_bearing;
- rect->miny = extents.y_bearing;
- rect->maxx = extents.x_bearing+extents.width;
- rect->maxy = extents.y_bearing+extents.height;
+ rect->minx = px+extents.x_bearing;
+ rect->miny = py+extents.y_bearing;
+ rect->maxx = px+extents.x_bearing+extents.width;
+ rect->maxy = px+extents.y_bearing+extents.height;
} else {
- rect->minx = MS_MIN(rect->minx,extents.x_bearing);
- rect->miny = MS_MIN(rect->miny,extents.y_bearing);
- rect->maxy += CAIROLINESPACE*size;
- rect->maxx = MS_MAX(rect->maxx,extents.x_bearing+extents.width);
+ rect->minx = MS_MIN(rect->minx,px+extents.x_bearing);
+ rect->miny = MS_MIN(rect->miny,px+extents.y_bearing);
+ rect->maxy = MS_MAX(rect->maxy,py+extents.y_bearing+extents.height);
+ rect->maxx = MS_MAX(rect->maxx,px+extents.x_bearing+extents.width);
- if(advances != NULL) {
- char s[11];
- const char *string_ptr = string;
- int numglyphs = msGetNumGlyphs(string);
- *advances = (double*)malloc(numglyphs*sizeof(double));
- for(i=0; i < numglyphs; i++) {
- msGetNextGlyph(&string_ptr,s);
- cairo_text_extents(r->cr, s, &extents);
+ if(advances!=NULL)
(*advances)[i]=extents.x_advance;
+ px += extents.x_advance;
+ previdx=glyph.index;
- msFreeCharArray(lines,numlines);
return MS_SUCCESS;
-void renderGlyphs(cairo_t *cr, double x, double y, unsigned long *glyphs, unsigned int numglyphs) {
- int i;
+void renderGlyphsCairo(imageObj *img,double x, double y, labelStyleObj *style, char *text) {
+ cairo_font_face_t *ff = getFontFace(r,style->font);
- double px=x,py=y;
- FT_Face *f = cairo_font_face_get_user_data(
- cairo_get_font_face(cr),
- &facekey);
- int has_kerning = FT_HAS_KERNING((*f));
- unsigned long previdx=0;
+ double px=0,py=0;
+ FT_Face *f;
+ cairo_set_font_size(r->cr,style->size*96/72.0);
+ cairo_translate(r->cr,x,y);
+ cairo_rotate(r->cr, -style->rotation);
+ &facekey);
glyph.x=px;
glyph.y=py;
- if(glyphs[i]=='\n') {
- py += 10;
- px = x;
+ py += ceil(style->size*CAIROLINESPACE);
+ px = 0;
previdx=0;
continue;
- glyph.index = FT_Get_Char_Index(*f, glyphs[i]);
FT_Vector delta;
- FT_Get_Kerning( *f, previdx, glyph.index, FT_KERNING_UNFITTED, &delta );
- //printf("adding %f kerning\n",delta.x/64.);
- cairo_glyph_extents(cr,&glyph,1,&extents);
- cairo_glyph_path(cr,&glyph,1);
-void renderGlyphsCairo(imageObj *img,double x, double y, labelStyleObj *style, char *text) {
+ /* NOT SUPPORTED
+ if (style->shadowsizex !=0 || style->shadowsizey != 0) {
+ msCairoSetSourceColor(r->cr, &style->shadowcolor);
+ cairo_rel_move_to(r->cr, style->shadowsizex, style->shadowsizey);
+ cairo_fill(r->cr);
+ cairo_restore(r->cr);
- cairo_font_face_t *ff = getFontFace(r,style->font);
- int numlines,i;
- char **lines = msStringSplit(text,'\n',&numlines);
- cairo_set_font_face(r->cr,ff);
- cairo_set_font_size(r->cr,style->size*96/72.0);
+ if (style->outlinewidth > 0) {
+ msCairoSetSourceColor(r->cr, &style->outlinecolor);
+ cairo_set_line_width(r->cr, style->outlinewidth);
+ cairo_stroke_preserve(r->cr);
-// for(i=0;i<numlines;i++) {
- cairo_translate(r->cr,x,y);
- cairo_rotate(r->cr, -style->rotation);
-/* if (style->shadowsizex !=0 || style->shadowsizey != 0) {
- msCairoSetSourceColor(r->cr, &style->shadowcolor);
- cairo_rel_move_to(r->cr, style->shadowsizex, style->shadowsizey);
- cairo_show_text(r->cr, lines[i]);
- cairo_restore(r->cr);
- int nglyphs = msGetNumGlyphs(text);
- unsigned long *glyphs = malloc(nglyphs*sizeof(long));
- char *utfptr=text;
- for(i=0;i<nglyphs;i++) {
- utfptr+=msUTF8ToUniChar(utfptr, &(glyphs[i]));
- renderGlyphs(r->cr, 0,0,glyphs,nglyphs);
- if (style->outlinewidth > 0) {
- msCairoSetSourceColor(r->cr, &style->outlinecolor);
- cairo_set_line_width(r->cr, style->outlinewidth);
- cairo_stroke_preserve(r->cr);
- msCairoSetSourceColor(r->cr, &style->color);
- cairo_fill_preserve(r->cr);
- cairo_new_path(r->cr);
- return;
+ msCairoSetSourceColor(r->cr, &style->color);
+ return;
-void renderGlyphsLineCairo(imageObj *image, labelPathObj *labelpath,
+void renderGlyphsLineCairo(imageObj *img, labelPathObj *labelpath,
- cairo_renderer *r = getCairoRenderer(image);
- const char *string_ptr;
- char s[11];
- int i = 0;
+ int i,unicode;
+ FT_Face *f;
- if (&style->outlinecolor != NULL && MS_VALID_COLOR(style->outlinecolor)) {
- string_ptr = text;
- for (i = 0; i < labelpath->path.numpoints; i++) {
- double x, y;
- double theta;
+ &facekey);
+ for(i=0;i<labelpath->path.numpoints;i++) {
- if (msGetNextGlyph(&string_ptr, s) == -1)
- break; /* Premature end of string??? */
- theta = labelpath->angles[i];
- x = labelpath->path.point[i].x;
- y = labelpath->path.point[i].y;
- cairo_move_to(r->cr,x,y);
- cairo_rotate(r->cr, -theta);
- cairo_text_path(r->cr, s);
- cairo_stroke(r->cr);
+ cairo_translate(r->cr,labelpath->path.point[i].x,labelpath->path.point[i].y);
+ cairo_rotate(r->cr, -labelpath->angles[i]);
+ glyph.x=0;
+ glyph.y=0;
+ continue;
- double x, y;
- double theta;
+ /* NOT SUPPORTED
cairo_save(r->cr);
- cairo_fill(r->cr);
+ return;
More information about the mapserver-commits
