[mapserver-commits] r8992 - in trunk/mapserver/mapscript: csharp java
Fri May 1 15:44:13 EDT 2009
Author: tamas
Date: 2009-05-01 15:44:13 -0400 (Fri, 01 May 2009)
New Revision: 8992
   trunk/mapserver/mapscript/csharp/Makefile.in
   trunk/mapserver/mapscript/java/Makefile.in
Removed the AGG_LIB references in the csharp and java makefiles
Modified: trunk/mapserver/mapscript/csharp/Makefile.in
--- trunk/mapserver/mapscript/csharp/Makefile.in	2009-05-01 19:38:06 UTC (rev 8991)
+++ trunk/mapserver/mapscript/csharp/Makefile.in	2009-05-01 19:44:13 UTC (rev 8992)
@@ -46,7 +46,6 @@
 # Optional Anti-Grain Geometry Support.
 AGG=     @AGG_ENABLED@
-AGG_LIB=  @AGG_LIB@
 AGG_INC=  @AGG_INC@
@@ -188,7 +187,7 @@
 CCFLAGS   = @CFLAGS@ $(FLAGS)
 # Link flags and shared libs only
-SUP_LIBS =  $(GD_LIB) $(AGG_LIB) $(PDF_LIB) $(TIFF_LIB) $(PROJ_LIBS) \
+SUP_LIBS =  $(GD_LIB) $(PDF_LIB) $(TIFF_LIB) $(PROJ_LIBS) \
           $(JPEG_LIB) $(SDE_LIB) $(GDAL_LIB) $(MING_LIB) $(POSTGIS_LIB) \
 	  $(MYGIS_LIB) $(CURL_LIB) $(ORACLESPATIAL_LIB) $(GEOS_LIB) \
 	  $(THREAD_LIB) $(ICONV_LIB) $(ZLIB_LIB) $(XML2_LIB) $(XTRALIBS)
Modified: trunk/mapserver/mapscript/java/Makefile.in
--- trunk/mapserver/mapscript/java/Makefile.in	2009-05-01 19:38:06 UTC (rev 8991)
+++ trunk/mapserver/mapscript/java/Makefile.in	2009-05-01 19:44:13 UTC (rev 8992)
@@ -51,7 +51,6 @@
 AGG=     @AGG_ENABLED@
-AGG_LIB=  @AGG_LIB@
 AGG_INC=  @AGG_INC@
@@ -185,7 +184,7 @@
 	$(CURL_INC) $(MING_INC) $(ORACLESPATIAL_INC) $(GEOS_INC) $(ICONV_INC) $(XML2_INC)
 	  $(MYGIS_LIB) $(CURL_LIB) $(ORACLESPATIAL_LIB) \
 	  $(THREAD_LIB) $(XTRALIBS) $(GEOS_LIB) $(ICONV_INC) $(XML2_LIB)
